Anyone know how to dismantle MX5021 power - Audio Players & Recorders
Anyone know how to dismantle MX5021 power transformer? it was glued on the panel.
Got 40 in apex lcd flat screen tv and looks like its missing the power supply board anyone help me
some models have a external transformer like power supply. Cable plugs in wall socket goes to power supply transformer, cable from transformer connects to TV with a male female probe type fitting. It appears the power supply is missing.
Mar 04, 2016 | Televison & Video
Need a power mother board for a emerson 32 inch tv model number lc320em2
does anyone have the part # for the power inverter transformer for the LC320EM2 A the board #BA1AFGF0102 2. The transformer I am looking for is the largest yellow transformer, thnks.
Sep 03, 2012 | Emerson 32-inch 720p LED TV Refurbished
The transformer of my sub-woofer is burnt. When i take it to the repair shop, they say that the transformer is not available. I badly need to fix the speaker as i love them very much and the new ones are...
Sub woofers have small amplifiers , not transformers. The amplifier is removable and replaceable. The The overall size and the output wattage are the spec's you need . The output wattage is on the label which is attached somewhere on the speaker. You do NOT need to replace the amp with the Altec Lansing brand. Have you contacted Altec Lansing to purchase a replacement Amp? That's where I would start. If they cannot help you I would Google replacement amp sub-woofer, Altec Lansing model MX5021.
good luck
Apr 15, 2011 | Altec Lansing MX5021 System
My altec lansing mx5021 speakers problem
The problem I have found is the contact glue between the back panel and circuit board inside the sub woofer. The glue becomes conductive after some time (2 years..!!) and needs to be scraped away from across tracks, you can tell the problem areas as the glue is pale yellow but goes brown and conductive over time. Good luck.
Regards
aj
Feb 18, 2010 | Altec Lansing MX5021 Computer Speakers
Installed dayton nat gas hanging furnace in garage and have 2 wires dont know where they go one came from the back side of the transformer it was twisted with the other wire
Hopefully there is a wiring diagram glued to one of the panels to verify but on the transformer you will have 2, 110 volt wires. One is the power coming in (usually black wire) and the other is a common (white wire) and will be connected to other common leads. On the low voltage side of the transformer one wire will go to the thermostat then from the thermostat to the gas valve. The other side will connect to the gas valve. When the thermostat calls for heat it completes the circuit from transformer to gas valve back to transformer.
Dec 11, 2009 | Dayton Gas Furnace Heater
Astar MP-27BH power transformer.. will pay
Check this link to find the power supply you're looking for. The transformer itself it might be impossible to find it.
Good luck.
Nov 09, 2009 | Astar LTV-2701 27 in. HD-Ready LCD...
The selction ring on the Talea Ring Plus doesn't work anymore, does anyone have a clue?
I had the same problem, after dismantling the machine I found that the touch detector is glued to the back of the plastic front panel and had become detached, so that it was too far from the operator's finger to work. Reattached with fresh glue, checked connection to main board, works perfectly now.
Dec 26, 2008 | Saeco Talea Ring Plus Espresso Maker with...
139 people viewed this question
 Grubhead
Grubhead
