Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Water collecting inside bottom of freezer
I have a GE TFX27PRBA; at the inside bottom of the freezer, water is collecting there and becomes frozen. There is about a 1/2" of ice. When I chip it out and clean the bottom, water slowly collects again at the bottom and freezes.
  • Anonymous Jan 28, 2009
    Our profile (freezer portion) is collecting water at interior base. We Have removed it only to have it build up over time.
watugot
  • 290 Answers
SOURCE: Water collects and freezes in the bottom of the freezer
Your defrost drain is clogged. Get all the ice out and get to the defrost drain hole at the very rear bottom of the freezer. I use a piece of plastic tubing to run down them and clean them out, but you can use a piece of wire if it doesn't have a sharp end that will damage the tube. You can also remove the rear cover of the fridge and you will see the tube going from the cabinet to the drain pan and clean it from there. Post back if you need further help.
Posted on Oct 20, 2007
  • 126 Answers
SOURCE: Ge profile leaks from front of freezer
your drain will be plugged under the tray. there is a hose that runs to the drip tray. the back cover comes off you can then get at the hose
Posted on Dec 14, 2007
aborcass
  • 2651 Answers
SOURCE: Water collecting in refrigerator and ice collecting in freezer
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you access to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somewhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wire around the heater( black heater right above the drain trough) and stick it in the whole maybe an inch or so. now every time the heater comes on to defrost it will prevent the hole from freezing over
Posted on Mar 15, 2008
SOURCE: ge profile side by side model tpx2 4pryfbb serial number ls-2858840
I am having the same problem any suggestions........
Posted on Jun 16, 2008
mosesclive
  • 191 Answers
SOURCE: Bosch frost free fridge freezer
Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Posted on Sep 27, 2008
Water in the bottom freezer of a 2000 GE Profile refrigerator
look in bottom at back for drain hole, may be clogged, or even hole frozen over with collected water. Clear the drain hole.
Jul 30, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
Water collecting in bottom of freezer
Unblock the drain hose. You may have to access it from the back of the unit and it may be frozen up so you may have to fully defrost the freezer
Apr 30, 2012 | Electrolux 25.9 Cu. Ft. Side-by-Side...
I have a GSS25QGPD BB and it intermittently leaks water from the freezer side. I assume it has something to do with filling the ice trays, because it's not a huge amount of water. Even it I turn off...
your drain tray is frozen over behind the rear inside panel and when it defrosts the water cant run don the drain tube into the collector so it collects at the bottom of the freezer,its a 6" hose just "ROD" it out to the drain pan and it will be ok
May 30, 2011 | GE Refrigerators
Model CTX18GAZBRWW - (Hotpoint) no-frost - freezer on top Water collects under the vegetable drawers and must be removed every day.
Something to try....on the back wall of the fridge nearer to the top is a little cup like part sticking out. There is water in it but it usually runs down an attached tube inside back wall and ends up under the fridge and gets evaporated. If that tube or the little cup thing is plugged then it will drip in the fridge and collect on the inside bottom of the fridge. So the trick is to clean them out. Check it out ...may solve the problem.
Sep 07, 2010 | GE 18.2 Cu. Ft. Frost-Free Top-Mount...
Water is leaking out from the bottom of the freezer
Below the freezer coil is a drain trough. Sounds like it is frozen. Use a hair drier to melt it and poor baking soda with warm water down it.
Jun 02, 2010 | GE Profile PSS26NGS Side by Side...
There is water collecting at the bottom of the Freezer. It is coming out of the vent area inside the Freezer near the bottom. Can you help identify?
Check the defrost drain at the bottom rear of the freezer. If the drain is clogged or frozen, the water has to go somewhere during defrost.
Nov 14, 2009 | Maytag MSD2756G Side by Side Refrigerator
My water dispenser in my GE refrigerator does not dispense water. The same lever that dispenses water also dispenses water. I have checked the ice and water selenoids and they are working. The cooling coil...
We have an Electrolux Wave Touch with the same problem.
1 yr later, 3 new fridges, 1 new freezer door and no solution.
Yes, the line is clearly frozen inside the door.
Disconnect waterline at bottom of freezer door and activate solenoid - then you know for sure.
Oct 05, 2009 | GE Refrigerators
Ice collecting and water overflow from bottom freezer GE
IF YOU TAKE THE BACK OFF THE INSIDE OF THE FREEZER IT IS LOCATED UNDER THE EVAPORATOR COIL IN THE CENTER, IT IS A PIECE OF ALUMINUM SHAPED TO CATCH THE WATER, MELT THE ICE AND BLOW THE HOLE CLEAR
Aug 11, 2009 | GE Refrigerators
Not getting water from dispenser in door
if you can get ice but not water from the dispenser then suspect a frozen water line within the door . Check you get water to the connector at the bottom of the freezer door. Sometimes you can clear the blockage by connecting a steamer to the pipe but this will only be a temporary fix . If the pipe has frozen within 6 inches of the dispenser outlet then there is a heater mod that can be fitted WR49X10173
Nov 28, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
87 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
