Question about Toro Garden
I have a toro snow thrower 622 that is leaking fuel. its coming from under the unit fast. any ideas to why and how to repair?
Snow Thrower. fast fuel leak
    Novelist:
  • 157 Answers
A rapid volume leak could indicate a cracked/rotted fuel hose. Not uncommon for a gasoline engine that sits for long periods of time between use. If all hoses seem in order a stuck float valve(needle & seat) in the carburator would also cause rapid overflow of fuel. This willm require a carb overhaul to repair
Posted on Jan 07, 2013
boscia
  • 163 Answers
SOURCE: snow thrower won't throw snow
the problem could be the snow is to heavy for the motor to keep up, if thats the case you may need to upgrade to a more powerful model or try not to overload it. take it a little slower so the motor can keep up. but try tightening the belt. with your pointer finger push down on the belt it should have about a half inch give, if it moves more than that its too loose and probably slipping under load
Posted on Dec 13, 2008
  • 44 Answers
SOURCE: Toro Max 1028LXE Snow Thrower will not travel.
thank you for the reply. with the belt drive take a ruler and push the belt down you can use your finger as a referance point if you can push it past the half inch mark the belt needs to be tightend you can do that by adjusting the belt tensioner thats done by losening the bolt that holds it in place then moving it so there is no more then half an inch of play in the belt and retightning the bolt. and if the tensioner is at its stops then the belt needs replacement.
Posted on Dec 21, 2009
  • 506 Answers
SOURCE: Craftsman single-stage snow thrower hard to push
You can adjust the guides on the side of the blower so that it rides on those. If they are set to low you will see the problem you have now. If they sit to low for a long period of time you can wear out the blade on the bottom.
Posted on Dec 23, 2009
SOURCE: My toro 1128 OE snow blower wont throw snow the
I have a toro 98 cc powerlite snowblower model 38182 it was running fine one day then bog down and died after that i cant get it to start it has a good fire on the plug plug isnt very wet it pops threw carb once in a while help
Posted on Dec 27, 2009
rycgl
  • 1545 Answers
SOURCE: when i tip my toro
The primer bulb is replaceable (it is held in place with a ring with small tabs around it, behind the bulb). The carburetor's bowl may be loose and the bowl nut need to be tightened or the bowl nut (called that, but it is actually a small brass bolt) has an exterior washer that needs to be replaced. Another thing that may be causing your problem is the carburetor bowl-to-body gasket may be leaking and finally, the needle valve may not be completely shutting off the fuel going into the carburetor bowl. All of these parts are replaceable and the carburetor can be fixed to where it will not leak. The key is to determine exactly what carburetor the machine has. The manufacturer and model of the the engine and the year made are key here.
Posted on Dec 13, 2010
Where can I get parts for it.
I recommend eBay.
Jan 12, 2016 | Garden
Snow Thrower does not self-propel
Did you check under the handle area, near the blower itself for a transmission lever? This will engage & disengage the transmission.
Jan 25, 2009 | Mowtownusa Snow Thrower Starter Switch for...
My snow thrower wont start
Change the spark plug being sure to set the spark plug gap as recommended in the owner's manual. Then clean or change the air filter. Finally use new high test gasoline. good luck.
Jan 12, 2009 | Mowtownusa Snow Thrower Starter Switch for...
Garden Logo
110 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
