The problem is that the dial goes around for the setting required and water fills up, but the agitator doesn't move.
This doesn't happen all the time and seems spasmodic.
    Sergeant:
  • 291 Answers
Can you provide a complete model number? If this is a top loader check the lid switch. You should hear a click just after opening and a click just before it's closed.
Posted on Jan 07, 2013
  • 1294 Answers
SOURCE: Whirlpool filling and washing, not draining, rinsing or spinning
Check out your outlet filter, probable it is clogged. Clean this out and refit. Most cases when the drain or spin does not work, it is the filter. This is a suggestion.
Posted on Sep 04, 2007
SOURCE: Actual model is WWA3650SALWH
I got this straight from the GE service people. If you have the model that has the magnetic strip sensor under the lid (to signify if the lid is closed or not) and not the pin kind...try this:
1. unplug the washer for about ten minutes, then plug back in.
2. open and close the lid five times.
Seriously, this worked for me and I was having the same problem (the washer would fill but wouldn't agitate or spin). I guess this combination resets the electronics within the washer.
Hope this helps!
Posted on Oct 16, 2007
  • 12 Answers
SOURCE: washer fills but won t advance to the next setting for all cycle
Do you hear the ticking of the dial moving? if so it could be that the points aren't getting connection to cycle it threw the various cycles
Posted on Nov 22, 2008
hiltonjug
  • 612 Answers
SOURCE: Washing machine is Kenmore mod. 110 22422100.
You have a broken point inside the timer. I hate to say that there is no cheap solution. You will have to replace the timer. There is no rebuild kit or anything like that to repair the timer. I know of two suppliers where you can buy a replacement. I use these sometimes when I regular supplier hasn't got a part in stock. I checked the price at both for you and found the best price at www.appliancepartspro.com . their cost if $123.08 plus shipping. They ship same day if before 4:ooPM. Their Part Number: AP3020181 . When you go to their site enter either your model number or this part number. If you enter you model #, scroll down until you find the timer, Th part # will take you straight to it. I sure hope this helps.
Please rate solution
Posted on Sep 07, 2009
lancaster5
  • 245 Answers
SOURCE: Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Posted on Aug 23, 2010
Washer fills with water but doesn't begin to agitate to wash. It also drains but doesn't spin when we set the dial to that
Your agitator pindle. has come loose From the spline. Try to lift up on the agitator. If it lifts off the spindle easily then it has worn out the spline. That is what connects the agitator to the s
Feb 06, 2013 | GE Profile WPRE6100G Top Load Washer
Wash cycle
What is the model number of the unit?
Dec 02, 2012 | Washing Machines
How to move around brandt wm 550
see this causes and fix it. God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Sep 22, 2012 | Washing Machines
Water won't quit filling and agitator does not engage into the cycle.
Did you solve this problem -have one doing the same-feed back -please!
Mar 22, 2012 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer won't fill
Hi pollystepp.
Without knowing the make and model, a basic answer to this problem is that the fill switch has gone bad. If your machine proceeds to agitate and spin without water, the washing machine 'thinks' it has water in it and this happens when the fill switch is stuck open. Rarely, the tube that goes from the tub to the switch may be clogged which may cause the switch to remain open.
Good luck from Detroit, MI.
Oct 20, 2011 | Washing Machines
I have a Maytag Model A412, series 11 washing machine. After the machine fills with water the machine appears to start its cleaning cycle but the agitator doesn't work. The water starts & the...
if this is a two piece agitator,it should behave like a ratchet turn freely clockwise and catch counter clockwise if it doesn't catch the agitator "dogs " are shot this is a verry inexpencive repair
Jun 08, 2011 | Washing Machines
Aug 23, 2010 | Kenmore Washing Machines
Water level sensor in an Amana LWA65AW Washer?
What likely happened is when you replaced the belt you may have disconnected the hose to the water level switch. It is (usually) a clear hose that attaches to the side of the washtub and goes to an air pressure switch that senses the water level to tell the machine to shut the water off and go into agitate mode.
If the hose is not disconnected you may either have a bad water level switch, it may have been accidentally unplugged electrically when replacing the belt, or there is a hole in the hose, connection to the washtub or on the switch.
Oct 29, 2009 | Washing Machines
Washer fills but won t advance to the next setting for all cycle
Nov 22, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
