Question about Hardware & Accessories
Intermatic very old timer does not rotate the dial, manual rotate does work
  • 5,089 Answers
1) C
Posted on Jan 07, 2013
The timer stopped working, so the system is only working on manual mode. what could be the issue?
If timer dial is not rotating, then check for power to timer.
If timer has power, and dial is not rotating, then replace clock motor.
If trippers are worn down, then replace trippers.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
Sep 21, 2011 | Intermatic R8816P101C -...
My Intermatic T104P3 timer will not turn the pump on. The manual switch works and it does turn off, as set.
1) Manual switch is working, and that says electricity, circuit breaker, wiring, and pump are good.
If timer dial is rotating and keeping good time, then order new 156T1978A trippers.
If dial is not rotating, then order 240Volt WG1573 clock motor.
2) Open following links for troubleshoot walk-thru and replacement parts list.
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#T100
3) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 04, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
I just replaced my pump and rewired it exactly as it was on my other pump. The pump works when I click the breaker on the power panel but the intermatic timer no longer works. Its like it skips it. No...
Question posted under R8806P101C 240Volt sprinkler timer.
With different timer, add a comment for possible help:
Open following links to identify timer and replacement parts, and see typical manual:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/r8806p101c%20-%20english.ashx
http://www.intermatic.com/products/ec%204%20layer/mechanical%20time%20switches/specialty%20time%20switches/r8800%20and%20t8800%20series.aspx
Your timer is stuck ON.
Temporarily disconnect ground wire at pump to make sure short is not somehow completing 240Volt circuit.
Move toggle switch to Auto position, and then ON and then OFF > Toggle should be able to switch Load on-off. If toggle is problem, then order 133T1115A switch.
Note if the timer dial is rotating and keeping good time: if dial is not rotating, then replace WG733-14D clock motor.
If dial is rotating, the trippers might be worn down. Order 156T1950A trippers.
If dial is rotating, and trippers are good, then relay might be bad. Order 143T139A relay.
Add a comment and say what you discover.
Aug 22, 2011 | Intermatic R8806P101C -...
I have an old "Intermatic Time-All." I no longer
Most time-all timers have two different trippers on dial.
Push down and rotate tripper to desired ON time and OFF time.
Then manually rotate dial until current time lines up with a mark or arrowhead.
To replace timer with new one:
Buy TN311c with 3 sets of on-off trippers that push onto dial, and 3-prong outlet.
http://www.amazon.com/Intermatic-TN311C-Heavy-Grounded-Timer/dp/B00002N5FO
Buy TN111c with 2 sets of on-off trippers, and 2-prong outlet
http://www.amazon.com/Intermatic-Appliance-Security-TN111C70-Settings/dp/B00002N5FI/ref=pd_cp_hi_3
Aug 09, 2011 | Solar Intermaticlamp & Appliance Timer...
Have a intermatic sprinkler timer that is has been reconnected to the pump. it works in the manual mode but the timer does not work looking for help on the wiring (video for dummies preferred)
No video.
If manual override works, look to see if dial rotates on time for full 24 hours. If dial keeps good time, then timer clock motor is wired correctly. If dial stops rotating after tripper passes, then wiring is wrong. If trippers are absent or worn down then timer will not turn Load on-and-off.
How to set timer, and troubleshoot timer:
http://waterheatertimer.org/pdf/How-to-Set-and-Troubleshoot-Intermatic-sprinkler-timer.pdf
How to wire timer:
You posted under R8806P101C 240Volt timer without rain sensor connections.
http://waterheatertimer.org/pdf/Intermatic-r8806p101c-manual.pdf
If this is not your timer, then add a comment with model number that appears on door panel.
The wiring block has 4 screw terminals. From left to right: 1 2 3 4
240Volts cable has two hot leads from breaker box. Hot leads from breaker box connect to screw terminals 1 and 3.
Timer operates 240Volt pump load. Cable to pump load has 2 wires. Connect Load wires to terminals 2 and 4.
Open following link for resources:
Jun 28, 2011 | Intermatic R8806P101C -...
I installed a new Intermatic 200w powerpack with 15 malibu lights using 131 watts. The lights turn on manually, but the timer doesn't work. How is this possible.
More information is needed.
Open following link for Intermatic-Malibu resources:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
You say clock doesn't work.
Add a comment with following information:
Do you have timer with analog dial?
Does dial rotate as time passes?
Does dial keep good time?
Have you put the black and red trippers in place?
Are trippers push all the way down?
Have you set current time by rotating clock dial 2 full turns before rotating dial to current time?
Intermatic/Malibu ML series timers come with 5-year warranty.
Product is covered by warranty.
Upvote the help.
Jun 01, 2011 | Malibu ML200RT - Low Voltage Power Pack...
Rotating dial no longer turns. lights come on ehrn rotated manually.
You posted under Malibu power packs:
Open following link for troubleshoot steps, manuals, warranty information:
If timer dial is no longer rotating, the clock motor is bad.
There are no replacement clock motors for Intermatic/ Malibu.
Work around problem: buy cheap plug-in timer, set power pack to override, and plug power pack into cheap timer.
Apr 16, 2011 | Malibu Hardware & Accessories
Intermatic T101 timer
T101 timer is strictly 120Volt timer
Wiring and manual show on following link
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
See another image of wiring:
http://waterheatertimer.org/images/T-101-control-120V-Load-450.jpg
Amazon sells T101:
http://www.amazon.com/Intermatic-T101-Hour-Dial-Timer/dp/B00002N5FN
If timer is not functioning, add a comment.
Grainger sells 125V clock motor and tripper for T100 series timers.
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
If manual override does not turn Load ON, and the lever snaps crisp and clean, then check electric circuit. Check if load is operable.
If override does not snap crisp and clean, then timer may be worn out.
If dial does not rotate, replace clock motor.
If dial rotates but does not click override back and forth, then replace trippers.
How T101 works:
Lift and rotate dial until current time lines up with silver pointer
Clock motor rotates dial.
ON-OFF trippers attached outer edge of dial contact a lever.
ON tripper pushes lever one direction.
Off tripper pushes lever opposite direction.
Lever opens and closes electrical contacts.
Lever also pushes manual override lever back and forth with audible click.
Dec 28, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
How to set on at 4 pm and off at 7am
You posted under intermatic 1020 timer
If this is not your timer, add a comment
How to set timer.
Remove dial from body of timer.
So now the timer is apart in 2 pieces.
Silver ON trippers and brass OFF trippers can be removed.
Place trippers in times you want timer to operate.
In this case, set silver ON tripper at 4pm
Set brass OFF tripper at 7am
Timer comes with 2 pair of trippers, so you will only use one pair.
Save the extra pair of trippers for when 1st pair of trippers wears out.
Snap timer back together.
Manually rotate dial around to watch lights come on.
To set current time, rotate dial until current time lines up with mark.
Dial rotates with passing time.
Tripper rotates around with dial.
When tripper contacts on-off lever, it physically moves lever like turning light switch on-off.
ON tripper moves lever one direction.
OFF tripper moves lever opposite direction.
Manual E-1020
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/e1020%20-%20english.ashx
Dec 11, 2010 | Intermatic Timer E1020, Single pole/single...
I having troble with my t103 timer to turn the lights on manualy i try to set the timer but for some reason doesn't work what can i do ???
T103 Intermatic timer has 120Volt clock motor and can control 120V or 240V Loads.
Wiring for timer is shown on following link:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T103
Troubleshoot T103:
1) Manual override is working correctly, and it snaps crisp and clean, and Load turns on-and-off.
That means timer is basically good.
2) Next look to see if yellow dial is rotating.
If dial is not rotating, then 120Volt clock motor needs to be replaced.
Take photo of wiring and mark wires before starting.
Remove two white wires connected to screw terminals 1 and A.
Snap timer mechanism out of box, clock motor is on back of timer.
Use small star screwdriver to remove old clock motor.
Reattach white wires on terminals 1 and A, tighten screws very tight.
Reset current time: lift and rotate dial until current time lines up with silver pointer.
Grainger sells 125V clock motor:
http://www.grainger.com/Grainger/INTERMATIC-Time-Clock-Motor-1PNK1?Pid=search
3) If dial is rotating, but gets stuck at certain times, or runs slow, then replace clock motor.
4) If dial is rotating, and trippers are attached to dial, but timer does not turn ON, then trippers are worn down and need to be replaced.
Grainger sells the T103 trippers
http://www.grainger.com/Grainger/INTERMATIC-Timer-Tripper-2E054?Pid=search
5) How Intermatic mechanical timers work:
Dial with ON-OFF trippers is rotated by clock motor.
Trippers on dial contact ON-OFF lever.
OFF tripper pushes lever opposite direction.
Lever moves electrical contacts on back of timer that turn Load ON-OFF.
Manual override lever clicks back and forth with each ON-OFF action.
Nov 20, 2010 | Intermatic T103 Indoor 120-Volt 40-amp...
Hardware & Accessories Logo
15 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
