Question about Meade LS 8" ACF 08100310 Telescope
When I turn on the telescope nothing happens. It's lit up red, but no message or alignment?
I was given this awesome telescope but without the manual. I looked it up on line, followed the instructions but nothing happens. However I did only put the batteries in no 12 v DC adaptor. Do I need that? The manual only says "when" using an adaptor. When I flip the switch on, I hear a beep and it lights up in red, and that's all.
SOURCE: MEADE LX90 TELESCOPE
Had the same problem. Took it to a dealer and we put a new controller on but the funny thing was that my old controller worked fine on another scope but it would not work on mine. Agreed with "Guest" above - Mead's after sales service is bad.
Posted on Apr 08, 2008
  • 3 Answers
SOURCE: Meade LX 90 AutoStar problem
One thing you can do is to completely reset the controller and reinput everything back into it.
If that doesn't work then you need a new hand controller.
It would be nice if you can take it to a local telescope shop and have them try your controller on one of theirs.
Tom Net
Posted on Apr 10, 2008
SOURCE: insutrction manual
I also have this telescope with no manual!
I called the Meade customer service number at 1-800-626-3233
and they are going to email me the manual for this model.
FYI - it's now called a Jupiter 114EQ-D.
Hope this helps you!
Posted on Sep 10, 2008
  • 36 Answers
SOURCE: can't focus my telescope
If there is nothing on the objective lenses or eyepiece lenses then it most likely needs collimation. This is where you adjust the secondary mirror while viewing an out of focus star. You need stable sky conditions to do this.
There are most likely three small screws at the front of the telescope and these are what you use to adjust it. As one screw is loosened then another is tightened. Do this in very small increments. If you have your manual it should outline how to perform this. If not go to this web site: http://www.astrosurf.com/legault/collim.html. It will show examples of how objects look both in and out of collimation. There is a section further down the page for SCTs.
A very handy tool for this is to replace your screws with Bob's Knobs (http://www.bobsknobs.com/) . These replace the screws and allow you to adjust it by hand instead of a screwdriver.
The other focusing problem I've experience with my Celestron SCT is to have the focus knob loosen up and then slip as I turned it so that I could never focus with it.
Good luck and clear skies!
-jodair
Posted on Mar 30, 2009
  • 36 Answers
SOURCE: Need user manual for Meade Telstar 76700 telescope
Try this web site for a manual: http://www.meade.com/manuals/index.html.
I did not see the part number 76700 listed but they had several Telstar models listed and did not always show the part number, instead opting to show the model number. If the exact one is not listed, you might find one very close to it.
I hope this helps.
-jodair
When I turn on the telescope nothing happens. It's lit up red, but no message or alignment? I hear a beep and it lights up in red, and that's all.
Connection between controller and scope is bad. This happens often. May have to open scope base and clean or re-solder connector
Feb 03, 2015 | Meade LS 8" ACF 08100310 Telescope
I cannot see anything through the lens of my brand new 6 SE. What should I do?
During the day, point the telescope at a part of the landscape about 100 yards away. Use the lowest power eyepiece (highest number) in the focal tube. Center the landscape object in the telescope. Align the finder scope so that it points exactly where the main telescope is. At night, leave the scope out to reach thermal equilibrium (about an hour). Point the finder at the moon. The moon should be in the main scope also. Practice finding the moon before you start on the planets Once you are comfortable with the moon and planets, you can go for the deep sky objects
Dec 28, 2012 | Celestron NexStar 6 SE (354 x 55.88mm)...
We are trying to test out viewing land based objects using the 30X eyepiece, which according to the instructions, should appear right side up and not upside down! This is not happening.
It's NOT really a problem. ALL reflector style telescopes show upside down images. This will not affect your star gazing since there is no UP OR DOWN in outer space. Read my tips on my profile page.
You can buy an "erecting diagonal" for terrestrial viewing- BUT this is not what an astronomical telescope is actually used for.
So align the small finder scope on a distant object like the top of a telescope pole during the day time. Point the main tube at the pole and get the tip top in the main tube's eyepiece. Without moving the telescope adjust the crosshairs on the finder scope on the exact same spot. The moon should be your first target at night and you can check and refine the finder scope on the moon.
Mar 12, 2011 | Bushnell 3" Reflector Telescope 60% OFF w/...
I have a newtonian telescope 76mm with SR4, H12.5 and H20. I have aligned the crosses up and can see through the viewfinder but nothing through the eye piece. Ive placed all the other lenses into the eye...
YOU MUST align the small finder scope with the main tube.
Point the scope at a distant object like the top of a telephone pole. GET the top in the center of the eyepiece in the main scope.
Then without moving the scope-- adjust the cross-hairs in the small finder scope so they line up on the same object.
Feb 09, 2011 | Bushnell Deep Space 78-9003 (525 x 76mm)...
On alignment, get message "There are no objects
RESET the hand controller and then re-enter, Time, Date, and Site, and Standard Time.
After the above do another alignment.
If nothing -- then reload the hand controller firmware.
Jan 30, 2011 | Celestron CPC 800 (480 x 50mm) Telescope
How do you turn on the red dot finderscope
There is usually a switch on the side-- turn the knob.
There will be 3 knobs the other TWO are to align the red dot.
Dec 25, 2010 | Bushnell NorthStar 78-8831 (525 x 76mm)...
I was given a Tasco 675 power reflector telescope model #40-114675, but didn't get an instruction book or dvd. I was able to find a star in the finder scope but couldn't see it through the eyepiece. it...
You must first ALIGN the finderscope with the main tube. Locate a bright object with the main telescope. Get it in the eyepiece- then without moving the telescope, align the finder scope on the same object.
Now you can use the finder like a gun site to center targets on the crosshairs. By the way the Fixya picture in your question always makes me laugh- the telescope in the picture is mounted BACKWARDS and pointed toward the ground!
Jun 01, 2010 | Tasco Luminova 40114675 (675 x 114mm)...
The Red Dot finde scope on my 78-8831 doesn't look like depicted in the user manual for this telescope. It looks like on the picture for 78-8840. Oh, by the way, the user manual is just about the worst...
Bushnell is NOT known for their quality telescopes. Sorry.
The red dot finder must be aligned with the main tube, you can do this during the daytime.
Focus on a distant object using the telescope like the top of a telephone pole. Without moving the telescope, adjust the red dot so it falls on the exact same object.
This may help you also:
http://www.cloudynights.com/item.php?item_id=810
Nov 01, 2009 | Bushnell NorthStar 78-8831 (525 x 76mm)...
Red Dot Finderscope doesn't do anything when turned on
Sometimes there can be a plastc tab to take out so as the battery isn't drained while it's in the factory, store etc. just pop the battery out and check.
Jul 27, 2009 | Bushnell Voyager 78-9945 Telescope
Red dot finder scope
Simple-- you can also do this during the day on an object at least 100 yards away-- but at night; get the moon centered in the eyepiece and without moving the telescope center the red dot on the moon. This will get you almost aligned-- then put a bright star in the eyepiece and readjust the red dot to center the star.
Jan 09, 2009 | Bushnell NorthStar 78-8831 (525 x 76mm)...
Meade LS 8" ACF 08100310 Telescope Logo
41 people viewed this question
Top Meade Optics Experts
Experi
Level 1 Expert
Joe Wright
Level 1 Expert
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Meade Optic Expert? Answer questions, earn points and help others
