Question about Sony DVDirect VRD-MC3 DVD Recorder
Dvdirect vrd-mc5 no sound records from vhs
I have audio cables set up correctly. I have tried different VHS players, different VHS tapes, and different cables, however, I cannot get the sound to record onto the DVD. I was able to previously, however, I noticed in the middle of one of my recorded DVD's, the sound just stopped. After that, I have not been able to record the sound from a VHS no matter what I have changed. I have only recorded a few VHS tapes, so it has hardly been used to record VHS tapes. It will record the sound from my Sony Handycam.
5 Suggested Answers
SOURCE: Multi-function DVD recorder VRD-MC5
I had a similar no audio issue when using the I-Link connector and 8mm camcorder. I found that if i selected "Manual" rather than "Automatic" (copy everything) that I got good audio as well as video.
I have tried using a later model Sony miniDV camcorder with A to D passthrough from my 8mm Sony camcorder that I get better Video color using RCA cables directly from the 8mm Camcorder but better audio from the I-Link passthrough above.
Pogo
Posted on Aug 11, 2008
SOURCE: Motorola VIP1216 DVR and Sony VRD-MC5 Connections for Recording?
I have the same problem currently. I have successfully recorded to the Sony CM5 in the past from my DVR, but no longer can. I have Comcast and wonder if they have changed the DVR firmware and blocked output. Also some broadcasts have something in the signal to stop recording. I got half of my program done, and can't record the rest on DVD. I will try to DVR local news, then record to the Sony, to see if it's a signal issue or something with the Sony. I haven't tried to record from a VCR.
Posted on Nov 14, 2009
SOURCE: I am trying to copy a VHS to DVD from a VHS
Is it possible the VHS you're trying to copy is copy-protected? Apparently, the MC6 displays "waiting for signal" when you're attempting to copy a copy-protected (commercial) video. I had success converting my own homemade VHS tapes. I just bought my MC6, and thought I'd pass along some tips I got from others: You know you're recording when a red ring around the large Record button lights up and it actually says "recording" on screen, and adjust HQ to SP to get 2-plus hours of video on the DVD.
Posted on Feb 22, 2011
Grubhead
  • 5342 Answers
SOURCE: I'm trying to record home
If the VHS player has a scart socket you can connect it to the Sony using one of these converting connects.
grubhead_16.jpg Check out this link too
http://esupport.sony.com/perl/support-info.pl?info_id=75&mdl=RDRGX315
Posted on Aug 21, 2011
No sound when playing dvd, connection to vhs player
tried to record coming from other tape and replace the audio cord.
Sep 15, 2012 | Televison & Video
Audio noise on some, but not all VHS tapes
First thing i would say is go for the HI-FI audio would go in and out and pop etc. Adjusting the tracking would bring in the audio, but sometimes the video would get fuzzy. Get the picture right and the audio goes out. Switch to Linear (mono on some VCRs) and the audio should be fine.
Finally if this doesn't solve your problem then i would suggest you to give it to repair and they will fix it.
Goodluck..
Feb 16, 2008 | Panasonic DMR-ES46VS DVD Recorder/VCR
How to tune up dvd player
  • Plug the power cable of the Samsung VHS/DVD player into an available power outlet near the television.
Connect a set of RCA audio and video cables to the color-coded outputs on the back of your Samsung VHS/DVD player. The colors of these cables are yellow (video), white (left audio) and red (right audio).
Take the other end of the RCA audio and video cables and connect them to the color-corresponding inputs on your television. When plugging in these cables, look for a label for the input, such as "Video 1" and "Audio 1." This will be important in Step 5.
Turn on the television and the Samsung VHS/DVD player.
Tune your television to the video input channel that you noted in Step 3. If you did not take note, you can also tune through your television's input channels until you find the one displaying the signal from the DVD/VCR player.
Insert a VHS tape or DVD into the Samsung player and press the "Play" button to verify that the unit is functioning properly.
Component Video
Connect a set of component video cables to the color-coded outputs on the back of your Samsung VHS/DVD player. These cables will look similar to composite audio and video cables, but they are instead color-coded as red, blue and green.
Plug the other end of the component video cables into the color-corresponding inputs on your television. Take note of what input number you are plugging the cords into, as it will be useful later.
Connect a set of RCA audio cables to "Audio Out" jacks on your VHS/DVD player, then connect the other ends to your television. These cables are color-coded as red and white and must be plugged into the same input number as the component video cables.
Tune your television to the component video input channel where you connected the Samsung VHS/DVD player.
Insert a VHS or DVD into the Samsung player and press the "Play" button to verify that the unit is functioning properly.
Jul 10, 2012 | 2005 Toyota Caldina
I have a couple VHS-C tapes that drag
This may be caused by a faulty adapter. 1. try playing in the camera. 2. try a different tape. 3. try a different adapter.99% this is a problem with the adapter or the tape. It really sounds like the tape isn't turning freely, which can be caused by a brake sticking, or spindle in the tape or adapter.
Mar 16, 2012 | Televison & Video
I am trying to copy a VHS to DVD from a VHS player. I have a Sony VRD-MC6 multi-function DVD Recorder. I am using the A/V cable and have verified that they are correctly placed. The Sony player will...
Jan 24, 2011 | Sony VRDMC10 DVD Recorder
I'm trying to record VHS tapes using AVerMedia 7231 capyure card. I've tried 1. Two different VHS player that both test OK 2. Different RCA cables that all test OK 3. Two different CoAxe cables that all...
This is a really common problem on ALL capture cards. It takes a lot of mucking around to find out WHICH button/setting switches the image on. Unfortunately its not a definitive answer. Its usually the hardware driver that's the problem You need ot make sure you have the driver right for your operating system... not just A driver but THE driver...
Jan 18, 2011 | Computers & Internet
Audio Problems playing VHS tapes with Denon AVR 1910
Did it EVER work as expected with VCR audio through the HDMI or are we working through that right now assuming it can?
I don't have a detailed manual, but the rear panel clearly shows some analog-only outputs (and NO digital ones) for the section called DVD/VCR. Internally, I'm sure there are proper analog-digital-converters for recording VHS to the native DVD-R, but VHS VCR's are NOT inherently digital audio devices so I'm pretty sure you need to run an analog RCA pair for the VHS video.
Feb 22, 2010 | Denon AVR588 Receiver
Vhs tapes recorded to DVD+R's
try forwarding the tape to the end and then rewind to the start again, this can help to seat the tape correctly on the spindle . the audio track part of the tape is in a specific region on the tape so misalignment may be the issue with those cassettes.
also try to press the tracking up and down when playing the video
May 12, 2017 | Televison & Video
Open Questions:
See all Sony DVDirect VRD-MC3 DVD Recorder Questions
Sony DVDirect  VRD-MC3 DVD Recorder Logo
120 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
