Samung le37r87bd turns itself off
Its keeps turning itself off and back on again
3 Suggested Answers
  • 3 Answers
SOURCE: I have a 32" HD AKAI TV that keeps turning itself off
If the service shops didn't charge people $200 to fix this I would not post.. But since they do - here's the $8 fix.
If you are electronically inclined, replace the three 1000uf 16v electrolytic capacitors in the power supply board located above the power switch. They are likely bulging out at the top and failed. They are the three in a row at the top - center of the board, located between the two black heat sinks. Make sure you get caps rated for 105c degrees! I recommend replacing them with 1000uf 25v caps. 35v caps will work but might be a tight fit as they are larger diameter.
Should cost you about $8 for the parts shipped. You can get them from partsexpress or digikey or any good local electronics store. Your local radio shack may have them but they won'y be 105c and thus may not last long.
Not handy, ask around, there is usually some electronic tweaker guy around that will install them for a few bucks.
This has solved the turns on / then off problem every time in the 3 I've done.
Posted on Jan 11, 2009
  • 5 Answers
SOURCE: Samsung 4254 Plasma keeps shutting
I just picked up the same tv today I noticed after a couple min it shuts off and clicking same as yours. I took the cover off and it seemed to stay on longer but same thing. Then I tried running a small fan next to the power supply and It ran no problem for an hour straight you can try this without taking the cover off and aim it at the top air vent on the back cover. Runs flawlessly now. I am going to Look into stealing a fan out of another plasma I have laying around or ordering one that will match a voltage I can splice into off the power supply board preferably the smaller the voltage the better. It's a pretty crappy design for a samsung. I don't know if this will help you or not but good luck.
Posted on Apr 19, 2011
My computer keeps switching itself off and won't swtich back on again? What can be the problem?
Hello
By know you should of fixed the problem .
1. keep the inside cabinet clean.
2.If the unit keeps shutting down by itself after a certain time and it is not dirty inside the cabinet .Also all the intact screens are clean . Check your Personlization settings By right clicking on your screen . then right click Screensaver and then power settings . Then check to make sure all the settings are turned off unless you want the computer to shut down after a certain amount of time
Oct 30, 2012 | LG Computers & Internet
Machine turns on and off by itself and keeps doing it
Hubby says it could be a stuck button. Otherwise there could be a fault with your front control panel. Feel special, he's never come across that before!
May 20, 2010 | DeLonghi EAM3500 Espresso Machine/Coffee...
My almost new Keurig (which I LOVE) keeps shutting down
I am having the same problem and will report back here if I find an answer. If I keep turning mine back on, wait for it to go off by itself. Turn it back on again...and again. Eventually I can get a cup of coffee. But my one-minute coffee cup usually takes 15 or 20 minutes.
Mine was a gift, so I'll probably just see if I can swap it out.
Cuz that's some good coffee.
Dec 13, 2009 | Keurig B100 Coffee Maker
We have a Henry hvr200 keeps turning off
could be overheating, when its cooled down will go again, make sure your filter is cleaned and the hose is not blocked
Sep 29, 2009 | Vacuums
My TV shuts itself down by itself
Poer supply is the cause of the shutdown and would need to be replaced. These cost around $150 bucks just in parts the labor you would need to find someone that knows just what there doing or you could wind up into the hundreds, Thanks
May 25, 2009 | Mitsubishi VS-6055 60" Rear Projection...
Tv shuts itself down
This is due to bad caps read here what a cap is www.badcaps.net see you tv is getting hot as normal but the caps cannot stand it any more thus shutting the tv down. The bad caps would be more or less in the power supply unit of this TV. So you can buy a new psu or get it repaired by a expert.
RCA 24V414T KEEPS TURNING OFF tv works great,channels, color, remote control etc just turns on about 5 mins and then shut down, again 2 minutes off, and then turns on back again, sometimes work all the...
it could be a ghost but most likely a bad solder connection , crystal(controls the eprom)(menu chip) , or the eprom chip itself will need to be replaced
Dec 01, 2008 | Televison & Video
Tv keeps turning itself off
you must contact service bycouse you need the asistance
May 25, 2007 | Toshiba MD20F51 20 in. TV/DVD Combo
TV keeps turning itself on and off, onto standby
Right i had this same problem for ages! i cannot explain why but when i uplugged my DVD player (which was flashing its light at the same time as the tv for some reason) the TV has worked fine.
Aug 24, 2006 | Philips TV Tuner Video Capture PCI Card -...
Televison & Video Logo
108 people viewed this question
Top Televison & Video Experts
Electro Med Services...
