Question about Grilling
How do i clean the interior of the bbq? - Grilling
    New Friend:
  • 51 Answers
An oven cleaner foam will work. make sure grill is in an area where dripping cleaner will not be a problem or place tarp or liners underneath to catch the mess dripping out. Spray on the metal areas, wait the recommended time on the can for cold ovens, hose or wipe off. Check warnings on the can first to see what, if any, surfaces need to be avoided
Posted on Feb 07, 2013
On a sonoma sgr30lp do you have to dissemble the entire interior of the bbq to replace the burners ?
No take the bars off the top and the burner covers , the burners might be screwed in at the back , other wise they will lift out .
Feb 24, 2017 | Grilling
Managemylife com
Use a BBQ meat thermometer to check the interior oven box temperature against the dials. These thermometers are generally are designed to take high heat, are cheap and not electronic.
Other than that; a multimeter. But that require some knowledge of use.
Nov 17, 2013 | Washing Machines
My weber grill is not putting out enough heat--both burners ignite, but I can't turn them up to get a higher flame/higher temparature. The grill is about 5 years old. How can I clean the burners to get a...
follow the below procedures on how to clean the burners for your grill:
Shut off the gas. It is very important that you turn off the gas valve to your BBQ before you can begin to clean it. This is found on the hose that attaches to your propane tank, simply turn the valve all the way to the right.
Escape any remaining gas. Next turn all the burner knobs to the highest setting and allow the remaining gas, if any, to escape. Make sure you have the grill hood in the open position before doing this.
Let the Grill vent for five minute: In order to ensure that the remaining propane has ventilated properly, leave your grill open and do not begin to clean it for at least five minutes.
Brush grill bars. Using your grill cleaning brush, firmly brush the surface of the grill bars in a forwards-backwards motion with the steel from the brush sweeping across the surface. Once you have brushed the surface flip each grill bar over and brush the other side.
Saturate with grill cleaner spray and repeat. Using your grill cleaner spray thoroughly saturate the surface of the grill bars and brush both sides. Set the grill bars aside after you finish so you can access the interior of the BBQ to clean it.
Remove burner plates and clean. All gas grills have metal plates which cover and protect the flame pilots during cooking. These will typically become covered with ash, and burnt grease and sauce over time. Simply remove them from the grill and brush them down. After you have brushed them once, saturate them with the cleaner spray and brush them down again. Set the plates aside so you can finish cleaning the rest of your grill.
Clean interior of grill. The plates will only catch so much, still sauce and grease will fall to the bottom of the grill and turn to ash. Using your grill brush, jar all of this ash free. Douse it in cleaner spray so it condenses and scoop it up with the paper towels.
Clean grease catch. Many newer gas grills will come with a grease catching plate. You can usually access these through the rear of the BBQ. They generally have a small metal handle and will easily slide out. Remove this grease catch, and brush and clean it thoroughly.
Clean exterior of grill. Using your grill cleaner spray, saturate the exterior of the grill and wipe it down with the paper towels. Repeat this process until the exterior is entirely clean.
Reassemble the grill. Now you can put all the pieces back together in your grill and turn the gas valve on again.
I hope the above helps to solve your problem.
Good luck.
Aug 18, 2010 | Weber Grilling
We have the Weber Genesis Gold and it seems to be burning itself. Even though there may be nothing on the grill and we've given it plenty of time to burn off anything that may be left, there is a thin...
My Genesis after a year or so begin to blister the inside of the lid
Also if you BBQ with lost of sauces your flavor bars could be your issue Try celaning them
Mar 08, 2010 | Weber Genesis Gold C (NG) Grill
Ignitor on gas BBQ no longer works. Replaced battery and cleaned out chamber (light rust). I've tried to remove the ingnition housing, but the entire front panel of the BBQ needs to be removed. Suggestions...
Check to see if the probe where it sparks to the burner inside the grill is clean and not shorted by grease or other gunk and the burner itself in this area is not too heavily rusted or corroded. If not, short of disassembling the whole grill and replacing the spark module, spend $2-3 and buy one of those pistol type grill lighters. The ignition systems on BBQ grills rarely seem to last long.
Feb 24, 2010 | Grilling
Weber Silver BBQ has 3 burners only 1 has normal flame.
you may have to remove the burners and clean the inside of them. they could have insect webs inside preventing the flow of gas. hope this helps. also, try opening the tank really slowly.
Oct 12, 2009 | Weber Grilling
Should there be fake coals in my gas weber bbq
Get rid of the fake coals they will only collect grease and cause a fire.
Jun 29, 2009 | Weber Genesis Silver B Grill
Brinkmann BBQ
It sure sounds like it's blocked. Purchase a venturi tube cleaner (about $5) or try removing it and lightly tap on the ground to try and unplug the little holes that have filled with debris. If you have access to some air tools, try blowing it out-similar to an air filter of a car.
Jun 20, 2008 | Grilling
Grilling Logo
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
