Question about Acer Aspire Ax3470 Desktop Pc Amd A8 3820 2.5Ghz, 6Gb Ram, 1Tb Hdd, Dvd-Rw, Windows 7 Home Premium
Is the acer aspire ax3470 able to connect to the Internet wirelessly
  • Acer Master
  • 27,725 Answers
With a wireless connection, your PC can connect wirelessly to a network printer. In addition, you can set up your PC in a location where no phone line or cable connection exists. Outfitting your desktop to a wireless Internet connection is very easy. Just follow these simple steps and you'll be surfing the net wirelessly in a matter of minutes.
Find out if wireless Internet reception exists where your computer is located. If you're located very close to a W-iFi hotspot, like a coffee shop, you may be able to use this network to get wireless Internet for desktop PCs. Also, some apartment complexes and college dorms have free wireless Internet. Your neighbors may have wireless Internet too, which you can ask them if you can use. Buy a wireless network adapter for your desktop. You can obtain an adapter from most electronic stores. Be sure to get a wireless adapter with the proper strength, which depends on how far you are from the wireless hotspot. The easiest adapters to install are those that just plug into an available USB port. Set up your wireless Internet for your desktop PC according to the instructions that came with the wireless adapter. The usual procedure is to plug the wireless adapter into an available USB port. Windows will install the appropriate driver. After your PC recognizes the wireless adapter, select the "Connections" icon in the taskbar (represented by vertical bars). A list of available connections will appear. Select the desired connection. If you are prompted for a password, enter the appropriate password. Click "Connect." You are subsequently connected to a wireless network. Launch your browser and enjoy surfing the Internet wirelessly. If you are the owner of the wireless network, secure your wireless network with a password. To do so, navigate to the "Start" menu and select the "Control Panel." Then select "Network and Internet" and "Network and Sharing Center." Click "Change adapter settings" in the left pane. Double-click the icon of the appropriate wireless connection. The Wireless Network Connection status window appears. Click the "Wireless Properties" button. Select the "Security" tab and select an encryption type from the drop-down selection. Enter a password in the Network security key field. Make sure that the password matches the router settings. Press "OK" when done. Get a wireless internet router for your Internet connection if there is no wireless Internet already in your area. You can buy these online, or at electronic stores. You'll need to set up your router using the accompanying instructions and your own Internet service provider. This is best in a home with multiple computers.
You will have to open up your network connections Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled, If you are trying to connect through a modem/router you it should have come with a disk then you might have to connect the usb lead to your modem to get a connection then Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers. The driver might be on the disc supplied by your ISP internet service provider or the motherboard disc Click start type cmd press enter you will be in DOS mode type in ipconfig press enter you will see all o fyour internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138 Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its "Enabled"imake
Hope this helps.
Posted on Jan 07, 2013
3 Suggested Answers
SOURCE: Acer Aspire 5735-4163 PC Notebook
disable the password on your router, and connect without a key. d-link routers and acer laptops seem to have an issue connecting to wireless lan with a key.
Posted on Nov 22, 2008
robocop
  • 90 Answers
SOURCE: my Acer desktop Aspire 3400
Do you have a wireless pc card in one of your pci slots?
Posted on Jul 06, 2011
My laptop wont connect to my wifi just started a few weeks agto
Acer Wireless Not Working? - Easy Fix by Drivers.com
www.drivers.com/update/drivers-news/acer-wireless-not-working/
Jun 17, 2014 - In some Acer models you can use a combination of keys on the keyboard to ..... My acer aspire wont connect with wifi, it say windows cant connect.... I've just had a similar problem with my Acer Aspire laptop (wireless .... It is startedto happen just a month ago before it was ok I am using this since 6 months.
Acer notebook won't access the internet [Solved] - CCM
ccm.net > Forum > Network
Sep 17, 2014 - My Acer Aspire one series notebook says it's connected to my wireless... I know for a fact that my wireless is working fine, as my normal laptop is accessing it and ... it a while ago, sometime in Autumn 2010) but now it just won't work. ... 1) First make sure that you have configured the WiFi settings correctly. Can't get Aspire One D255 to connect to wifi [Solved] - CCM
Jan 15, 2015
Can't Access Internet-Wireless Working! [Solved] - CCM.net
Dec 19, 2012
My laptop Browsers won't connect to the web [Solved] - CCM
Oct 10, 2012
More results from ccm.net
wifi wont connect all of a sudden - Aspire - Laptop Tech ...
Dec 14, 2015 | Acer Computers & Internet
ACER ax3470 boot
restart computer and push F12 then select DVD/CD bootable device then you can use it DVD
Jan 17, 2013 | Acer Aspire Ax3470 Desktop Pc Amd A6 3420...
Acer Aspire 5733 Wireless connection lost
Check the wireless router and high-speed modem.
If the two are not powered on, or if the Ethernet cable connected the two is not completely inserted into both connection ports, you are unable to access the Internet on the Acer Aspire One laptop computer.
Activate the wireless Internet connection on the laptop computer.
Right-click the wireless icon on the desktop, then choose "Enable" from the pop-up menu.
Without activating the wireless receiver on the Acer Aspire One, the laptop is unable to detect any wireless network.
Select the appropriate network you wish to connect to.
Your computer may be attempting to connect to a different Internet connection, preventing you from access the network you desire. Right-click the wireless icon, select "Search for available wireless networks," then choose the network you want to access.
Restart the computer.
The system may have booted and failed to detect the wireless receiver. Restarting the computer corrects this issue.
hope this helps
Sep 13, 2012 | Acer Aspire 5733 Laptop
How to connect the wifi to a acer aspire 5733z - 4851 laptop
Check the wireless router and high-speed modem. If the two are not powered on, or if the Ethernet cable connected the two is not completely inserted into both connection ports, you are unable to access the Internet on the Acer Aspire One laptop computer.
  • 2 Activate the wireless Internet connection on the laptop computer. Right-click the wireless icon on the desktop, then choose "Enable" from the pop-up menu. Without activating the wireless receiver on the Acer Aspire One, the laptop is unable to detect any wireless network.
  • 3 Select the appropriate network you wish to connect to. Your computer may be attempting to connect to a different Internet connection, preventing you from access the network you desire. Right-click the wireless icon, select "Search for available wireless networks," then choose the network you want to access.
  • 4 Restart the computer. The system may have booted and failed to detect the wireless receiver. Restarting the computer corrects this issue.
  • Oct 09, 2011 | Computers & Internet
    Acer aspire onw - has signal with wireless connection but will not connected when clicking on browser
    Connecting to wireless signal is not the same as connecting to the internet. Verify the wireless router itself is connected. Your internet provider may be off line.
    Sep 07, 2011 | Acer Aspire One PC Notebook
    I have a acer aspire 5570Z, unable to connect online...
    Open network connections and disable your wireless connection (right click) then renable it and try to connect. What program are you using to manage your wireless connection?
    If you are using your manufaturers software then try using windows xp (or vice versa)
    Aug 25, 2009 | Acer Aspire 5500 5570-2609 Laptop
    Acer Aspire Ax3470 Desktop Pc Amd A8 3820 2.5Ghz, 6Gb Ram, 1Tb Hdd, Dvd-Rw, Windows 7 Home Premium Logo
    162 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
