Question about Skil "3410-02 10"" Table Saw"
Skil 3410-02 replacement parts
Where can I get a replacement guide bushing? It is the bushing that giudes the blade/motor assembly when you tilt for a miter cut. Made of nylon, curved and broken.
  • 2976 Answers
SOURCE: both leaf springs have come off the roller wheel guide
You will have to take the case apart and push them into place. If you have access to a hemostat or a nice long, this pair of needle nose pliers, it will be helpful. There is possibly a screw inside that holds them in place. If so, get the smallest bottle of blue threadlocker that you can find. It's quite expensive and you only want enough to wet the screw threads. Only use blue, it's removeable. If you use red or black, you will not be able to turn the screws if the problem ever happens again.
Posted on Jan 03, 2009
  • 33 Answers
SOURCE: bought model 3400 skil table saw. have no manual.
This model does not have a knob on the side.
There is only a locking lever on the front next to a single rotating wheel for height adjustments. To tilt the blade simply twist the locking lever to the left and push the height adjustment wheel to the right. It can be a bit stiff at times to move.
Posted on Jul 19, 2009
  • 33 Answers
SOURCE: Skil saw motor runs but blade won't spin
The key could be sheared in the final drive shaft as well.
Posted on Jul 25, 2009
brewerstool
  • 141 Answers
SOURCE: I need the outer flange/blade clamp for my skil model 77 type 16
The replacement part is 1619X02969. And you can get it from directly from boschtoolservice.com ($3.75).
Posted on Oct 13, 2009
  • 172 Answers
SOURCE: I broke the lower blade guide
All I could find out is that your skil bandsaw is made by the Bosch Bench tool co in Mount Prospect, Il. The owners manual from skil shows the part you need as #6 lower blade guide, and Lowes does handle this line of Skil. I would suggest contacying Lowes or the store you bought this from and getting the consumer help phone number from them. They have to have this part available as I am seeing a lot of these units refurbished, so someone has the parts to them. Hope this helps and good luck. Marvin
Posted on Jan 20, 2010
The blade on my new skil 3310 won't raise. It came preassembled & has never been used, but the elevation wheel feels locked. I can adjust the angle, but turning the knob doesn't raise/lower blade.
Just as a question and I am not being smart you know that the wheel to raise the blade work counter clockwise.
The other thing you need to check is in your manual here is the part how to adjust the blade for raisin/lowering.
After five hours of operation, the blade elevation/tilting mechanism should be checked for looseness, binding, or other abnormalities. Disconnect the saw from the power source, turn the saw upside down and pull up and down on the motor unit. Observe any movement in the motor mounting mechanism. Looseness or play in the blade raising screw 1 should be adjusted as follows (Fig. 55): 1. Loosen nut 2. 2. Adjust the nut 3 until it is finger-tight against the bracket 4, then back off the nut 3 1/6 turn. 3. Tighten nut 2. The maximum allowable play of the screw rod 1 is 5/32" (4 m). Place a small amount of dry lubricant (such as graphite or silicon) on the screw rod 1 at the thrust washer 5. Do not oil the threads of screw rod 1. The screw rod 1 must be kept clean and free of sawdust, gum, pitch, and other contaminant's for smooth operation. NOTE: If excessive looseness is observed in any other part of the blade elevation mechanism or tilting mechanism, take the complete unit to an authorized service center.
Oct 21, 2015 | Skil Saws
Where can I get the parts for the upper and lower blade guides for my skil 10" bandsaw model 3104
Try to contact Skil, if they can't provide you. Check with Carter Products ; they supply bandsaw guides for all types of saws.
Jun 12, 2014 | Skil Saws
Where can I get the upper and lower blade guide parts for my skil 10" bandsaw model 3104
Inquire with Skil tools or you can also check Carter's band saw guide kit.
My saw stops rotating during cutting
does the motor stop? If not the gears are worn between armature and spindle. If it does stop you could be applying too much pressure trying to cut with a blunt blade or there is an armature fault.
Apr 24, 2014 | Skil 10-in 15-Amp Compound Miter Saw...
Blade is not square to table
There are manuals for the Skil 3400 available online.
Centering the blade to the table simply requires a screwdriver, a good square, and some patience. Basically you're loosening up the points that hold it vertically and horizontally (front to back), checking them against the table with your square, and then tightening them up when everything looks nice and ninety degrees.
It's not the best saw in the world, but with a little work, I've been able to get it to make 90 degree cuts and perfect miters with a miter sled and a cross-cut sled I built using aluminum (I think?) T-shaped replacement runners that would normally be used for the worthless miter guide that comes with it.
Apr 23, 2014 | Skil 10" Table Saw 3400
Left rear window won't go up
First do you hear it trying to work, is it like a "clack, clack, clack" sound? or you hear the motor running smoothly? You will need to remove the door panel and take a look behind the plastic water seal to see whats going on, it is either going to be the regulator ( part the motor is attached to...cable broke)/damaged or more likely the nylon bushings inside the motor itself, they run like 10 bucks on Amazon. If you take the motor out of the regulator assembly be careful not to let the cable system come apart/unwind( use nylon ties while motor is out to hold in place). The motor itself is straight forward open/replace worn/falling apart nylon bushings/relube/reassemble. The tricky part is not screwing up the regulator assembly...depends on your skills.
Mar 18, 2013 | 1999 Mercury Mountaineer
What is a compound miter saw?
A compound miter saw has a rotating vertical pivot allowing the cutter head & blade to be tilted (or beveled) sideways in addition to the horizontally rotating table. This allows vertical & horizontal angled cuts as well as cuts angled in both planes.
Jan 28, 2013 | Saws
I am having trouble inserting the blade properly
You press the lever forward all the way, insert the blade, and release. If the holder is getting worn it can be replaced as one complete assembly. Here is the user manual link. It shows how to use the holder.
Skil 9225 manual
The part number for the holder assembly is 2610938752. It is less then $10 and is held on with an allen screw so it's easy to change.
Jul 15, 2012 | Skil 9225-01 9.5 Amp Orbital Reciprocating...
Does the SKIL 91905 Router Guide Bushing Set (4 pc) fit this router
John-
Yes, the 91905 bushing set will fit the Skil 1810.
Regards,
DIYpro
Apr 29, 2011 | Skil 1810 Router
I have a dw716 saw when you first turn on the blade wobbles then straightens up. I replaced the bearing and the gear spindle still same problem.
I own a DW716. My blade wobbled. I found that the small bearing on the motor end of the blade spindle had been pressed out a bit. This bearing is right behind (or perhaps attached to) the cap that shows on the motor side of gear assembly housing. I tapped it back in so it was flush to, or even a bit inset of the surface of the gear assembly housing and the wobble disappeared! Yeah! Cheap and Easy.
Aug 31, 2010 | Dewalt Heavy - Duty 12" Double - Bevel...
Skil "3410-02 10"" Table Saw" Logo
42 people viewed this question
Top Skil Saws Experts
JOHN LAPIER
Tim Venetis
Are you a Skil Saw Expert? Answer questions, earn points and help others
