Question about HEALTHRIDER S600 Treadmill Motor Control Board : 152004
My speed control dont work i need a board - HEALTHRIDER S600 Treadmill Motor Control Board : 152004
    Top Expert:
  • HEALTHRIDER Master
  • 12,223 Answers
You can go and buy it from
www.fitnessrepairparts.com
or
www.treadmilldoctor.com
God bless you
Posted on Jan 07, 2013
Condensor fan goes on low speed on hot days resulting in poor cooling, some days works fine, i checked pressures on days it was working normal.
Does it have a Motormaster feature? Motormaster controls condensor motor speed to control high pressure. A condensor thermal sensor signals the control board, don't forget to test the thermistor, stick it in ice and hot water and look for a speed reaction.
Heat pumps have a relay that switches the outdoor fan to low speed on Heat mode, this relay or its signal may need some checking.
May 18, 2015 | Filter Heating & Cooling
Error e9f
Hello - Typically error code E9F indicates a communication problem. A certified technician will need to check the wiring between the main control board and the speed control board. Depending on the diagnostic either the wiring, main control board or speed control board would need to be replaced. Contact a professional to move forward accurately.
Oct 26, 2012 | Frigidaire Affinity ATF7000E Front Load...
Mixer doesn't work on all speeds
First the K45SS does not have a hall effect sensor. the pro series the epicurean seines and the pro series 5 use them, The K45ss system uses a phase control board a speed control plate and a governor for speed control. the governor rarely goes out the phase control board is a likely culprit but the system would work only in high gear if it was bad. I agree with the guest above in that it sounds like the retaining nuts on the adjusting screws of the speed control board have worked themselves loose and the adjustment screws themselves have vibrated out of proper position.
Sep 20, 2012 | KitchenAid K45SS Classic Stand Mixer
Motor noise
It has been my experience with knocking kitchenaid is one of three reasons all related to the speed control of the mixer1 speed control board adjust speed screws2 speed Phase control board, needs replacing3 The motor governor behind the speed control board needs replacing
Speed board = $9.00Phase Board = $20.00Governor = $10.00Your time + one week for ordered parts asnd one hour to remove and replace.
all work is performed at the rear of the mixer and you need only a phillips #2 screwdriver, a pair of needle nose pliers, an 11/32 open end wrench (you will need this to adjust your speed control board after new install) and that's it. easy work all remove and replace. Oh! make sure that you pit some thermal paste behind the phase control board to avoid burn out.
But!!! before you buy parts and do all that, try adjusting the speed contol board first. Go here for a parts list for your model.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=KV25G0X&siteCd=KAD&userType=Servicer
then go here for instructions on tuning the mixer speed.
http://www.youtube.com/watch?v=pUo_ZU5xh3o
if after you tune it you still get the knocking then use the parts list to order parts. two good parts sources are goodmans.com and mendingshed,com, they are reliable and have the parts in stock.
Aug 26, 2012 | KitchenAid KV25G0X Stand Mixer
Top speeds don't work
Referring to the following parts description:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212369.pdf
The speed is controlled with a combination of the governor assembly #24 which mounts on the motor shaft, and the phase control board #27 which is mounted on the back of the mixer.
They operate in conjunction with item #25, the control plate assembly.
WARNING SHOCK HAZARD. FOLLOW THESE STEPS ONLY IF YOU ARE COMPETENT WORKING AROUND HOT ELECTRICAL COMPONENTS AND FOLLOW ALL SAFETY PRECAUTIONS!!!
Remove the rear cover screw #37 and the rear cover #36 and examine the governor when it is running. Also watch the speed control lever mechanism as you move it from off to the highest speed watching for binding etc.
If the governor appears to be opening and closing as the speed increases and the linkage is not binding then the problem is most likely the Phase Control Board, item #27.
Apr 18, 2010 | KitchenAid K45SS Classic Stand Mixer
Mixer only operates at high speed regardless of the speed setting
the triac solid-state component on the board for the motor speed control is shorted and you need a new control board, unless you can find an outsource replacement triac,most companies won't sell you parts because of liability issues on internal parts of the unit
Apr 02, 2010 | KitchenAid K45SS Classic Stand Mixer
My 1999 Dodge Caravan will not shift out of 1st. gear.
YES the speed sensor is first to check, but dont just go buy one and put it in. does the odometer work? if so, its getting a signal. The insrument clusters are common to fail, ususally a cracked solder joint in the circuit board. it will need to be removed and resoldered. if the odometer does not work, then check and verify that the spped sensor is indeed not putting any signal to the dash.
Oct 16, 2009 | 1999 Dodge Caravan
2000 saturn lw2 the wipers won't park
you may have a bad wipermotor.some motors have a control board (electronic)which control speed,pulse, and park,if wiper work but dont park then this may be your problem.
Sep 27, 2009 | 2000 Saturn LW
The latch/switch on the speed control board is stuck
You need to take the back cover off and then split the gear cases to find the mechanical reason why the lever is stuck. Take the motor off the pedestal, remove the planetary and undo the 9 screws that hold the bottom gearcase to the top housing. You will need to unplug the white and the black wires from one side of the speed control plate.
Jun 14, 2017 | KitchenAid K45SS Classic Stand Mixer
HEALTHRIDER S600 Treadmill Motor Control Board : 152004 Logo
64 people viewed this question
Top HEALTHRIDER Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a HEALTHRIDER Exercise and Fitnes Expert? Answer questions, earn points and help others
