Question about Brother XL-6562 Mechanical Sewing Machine
Feed dog not moving fabric forward
This machine is new to me and I have to pull the fabric through, the feed dogs move up and down but not forward to feed the fabric
  • Brother Master
  • 7,365 Answers
It would be a good idea to have the feed dogs checked to see why
they are not moving the fabric
Posted on Jan 07, 2013
5 Suggested Answers
MakikiChris
  • 84 Answers
SOURCE: My fabric won't advance.
Hi Jodyk...Remove your flatbed so you can access your bobbin area. Open the cover of the bobbin area. The shiny/bright components consist of the Bobbin, which snaps into the Shuttle Hook, which is contained in the Race. Immediately right of the Race is a pewter/matte silver colored lever. Press the lower portion of the lever to raise the Feed Dogs. Pressing the upper portion drops the Feed Dogs, and is commonly used to accomplish free-hand applique work......good luck my friend.
Posted on Aug 02, 2007
mohammed387
  • 1952 Answers
SOURCE: feed dogs stuck in down position
that the feed dog lever is in the up position. When the lever is in the down position, the feed dogs will show on the top if there is no pressure on them at all. Make sure that the machine makes one complete cycle to check this. Just throwing the switch does not make them come to the surface.
If this does not work, then the feed gear is broken and you will need to take it to a mechanic.
Posted on Aug 26, 2009
bargainbox
  • 1388 Answers
SOURCE: feed dogs dont move fabric thur
Have you changed the stitch length selector to zero ? If there is no lint trapped under the needle plate between the feed teeth, then the length selector is likely set too small,.
Posted on Oct 04, 2009
  • 980 Answers
SOURCE: needle pulls fabric down into
Chek first of all that the end of the needle has not burred over then chek the needle pkate for any damage, failing that it will mean a shop repair
Posted on Sep 09, 2011
Singer model 518....the material won't feed through.It wants to sew but won't feed cloth through. Thks
Be sure you have the stitch length set high enough that the fabric will actually move instead of sewing mostly in one spot.
One other thing to check is the presser foot applying enough pressure to the fabric so that the feed dogs can grab the fabric? On the top left side of the machine, there is probably either a dial or a push-type button. That would most likely be the pressure adjustment. The tighter that is set, the harder the pressure the presser foot will apply and the more the feed dogs will grab the fabric.
Check that the feed dogs are in the "up" position so they will pull the fabric through the machine. Are the feed dogs actually moving forward, raising above the needle plate, pulling toward the back of the machine, and then dropping below the needleplate before moving forward again? If not, then the problem could be with the feed dogs.
Your machine appears to be a mechanical model. If so, it could be the machine needs a good over-all cleaning and oiling--a couple drops of fresh, good quality sewing machine oil every place that metal rubs on metal (no plastic parts, belts...). Feed dogs are frequently affected when the sewing machine does not receive regular maintenance.
Jun 04, 2016 | Singer Sewing Machines
Cant get the feed teeth to come up and grab the cloth -- the cloth wont move --do I have it set on darn ?
it is possible that you have the feed in the neutral position ( halfway between forward and reverse ) from your problem discriotion
Apr 24, 2016 | Singer Sewing Machines
Material won't move? How to adjust feed dog if that is the problem
Is the feed dog raised into sewing position and not dropped as for darning? Feed dogs need to be in the raised position in order to pull the fabric through the machine.
If the stitch length is set too short, it will cause the fabric to barely move thereby causing the machine to stitch in one place.
Raise your presser foot and gently rotate the handwheel and watch the feed dogs. Do they rise when coming to the front of the machine, move toward the back of the machine, drop down below the needle plate, and move forward to the front of the machine again? If so, the feed dogs are working properly.
If the feed dogs never rise, they are in the dropped position for darning or free motion quilting when you would move the fabric manually.
If, on the other hand, the feed dogs do not move at all, then they are seized and you should probably get your machine serviced.
Apr 09, 2016 | Sewing Machines
Prelude. How can I adjust a feed dog to go left to right?
Sewing machine feed dogs generally do not move sideways. They move only forward or backward. Embroidery machines will stitch in all directions but only because they use hoops and not feed dogs to move the fabric. If you need the stitch to go a different direction, you can try rotating the fabric. Free motion quilting uses your hands to move the fabric under the needle but the feed dogs are not in use.
Mar 10, 2016 | Sewing Machines
Feed dogs will not move fabric
So right! You are brilliant!
Jul 03, 2015 | Sewing Machines
Fabric won't move threw machine, feed dogs are working.
Try adjusting the pressure on the presser foot, or make sure your feed dog are in up position and moving forward
Jan 06, 2013 | Sewing Machines
My necchi mod.910 i cannot get the machine to do zigzag stitch, and straight stitching is a problem - i have to pull the material in order for it to move
The Necchi machine has a lever in the bobbin area that lets you move the feed dogs up and down. If you accidentally moved that, the feed dogs are in the down position and won't feed the fabric forward. Make s ure you can feel the feed dogs slightly above the plate. If they aren't move the lever until they do. :)
Jun 22, 2009 | Necchi 3101 Mechanical Sewing Machine
My kenmore 385 won't feed fabric
Check to see what pattern is selected. Be sure it isn't the buttonhole.Select straight stitch.Move the stitch length setting to 4.Turn the handwheel and see if the feed dogs move forward. Press the reverse lever and see if they move backwards. Select straight stretch stitch and turn the wheel to see if the feed dogs move forward and backward.Check the presser foot release on top of the machine and make sure there is pressure on the foot.
Sometimes the reverse assembly on this machine stops working because it has the wrong type of grease on it and it turns into a hard gummy mess that won't let it work.
sewman7
May 14, 2009 | Sewing Machines
Why would my Singer 6235 not feed the fabic:
h! there,
fabric moves forward when machine run due to movement of feed dogs,feed dog has a teeth, when your foot presser goes down attached to fabrics the pressure hold the fabric between pressure foot and feed dogs that why when machine run feed dogs pushed fabric when recieved stitch.try to check adjustment of feed dogs it maybe set at rest or neutral.reset it to upward towards needle.check also bobbins thread if accumulation was build up under feed dogs.regard and have a nice day.
Apr 03, 2009 | Singer 118 Mechanical Sewing Machine
Kenmore Model (385.15108200) Fabric not moving
hi! there if your feed dog does not move the fabric forward or backward,if this is so try to run machine w/o the fabric check if feed dog move on cycle,the teeth should be moving upward and downward rotation pushing action on your fabric,the teeth should come out to the plate slot of feed dog.if not adjust upward, and adjust also the presser foot of needle.if your feed dog is not moving when machine running,thre is a mechanical disengage or loosen in shuttle assymble and feeder dog mechanism they link together ubder the machine,as the shuttle move on one stroke the feeder also move also with the needle.Chesk the adjustment and link mechanism.in addition to this try to clean feed dogs by brush chips thread and fabrics sometimes stored on mechanism of feed dogs and shuttle.
Mar 19, 2009 | Kenmore 15208 Mechanical Sewing Machine
Brother XL-6562 Mechanical Sewing Machine Logo
534 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
