Question about Home Security
How do we find a replacement for a 1973 Sears 53778 remote?
Father in Law has original 1973 Sears 139.6585000 garage door opener with 53778 remote. We need a 2nd remote.
  • 4 Answers
SOURCE: remotes quit working for garage door
I had the same problem with my Craftsman opener but different model. However to fix this I simply followed the instructions that came with the opener and reprogramed the remote to the opener. The instructions are in your owners manual and are pretty straight forward.. John
Posted on Dec 11, 2008
  • 3 Answers
SOURCE: garage door opener
I was having a problem with the remotes. Program one remote, and the other stops working and vice-versa. I found the solution to be as follows: Using 61LM single-button remotes for Lift-master WhisperDrive (belt drive) garage door opener, I set the dipswitches (find them by removing battery replacement cover) to identical settings in both remotes. Set the first dipswitch to the neutral (0) setting. Next -- and this is the important part -- press the learn button on the main door opening unit, and, while the small LED light is lit, press the button on ONE of the remotes. DO NOT REPEAT ON THE SECOND REMOTE. Upon doing this, I found that BOTH remotes at last worked. I then went on to program a keyless entry pad, which was accomplished by again pressing the learn button on the main unit, and then entering the number sequence I had chosen for my entry code on the keypad, and pressing Enter. Both remotes continued to function and the keypad functions as well.
Posted on Jan 17, 2009
SOURCE: How to reprogram Sears Mult-Function Keyless Entry garage opener
On the garage opener that actually opens the door the one on the ceilling has a green or orange button that is called the learn button just press and release it you have 30 seconds to punch in a 4 digit code and when your done press and hold the enter button until the lights on the garage open blink once or twice then just press the code again and it will open the door press enter once to reverse the effect and and twice to stop the door completely.
Hope that helps
Posted on Mar 17, 2009
  • 3197 Answers
SOURCE: Sears Craftman Garage door opener model # 41A3493-1
That isn't the model number you give it is the part number for the logic board. The model number is on the opposite end of the motor unit and starts with 139. If you are asking if the opener should reverse when it hits an obstacle the answer is yes. If it doesn't it is not adjusted correctly or is faulty.
Posted on Dec 01, 2009
swolfinor
  • 504 Answers
SOURCE: Need dip switch settings for Sears remote 139.53778
MATHCH WITH THE CODE ON THE BACK PANEL OFTHE OPENER AND THEY SHOULD WORK
Posted on May 30, 2010
I just purchased Liftmaster 971LM for my 139.53975srt1 Sears 1/2hp garage door opener. It will not program. I have only one working remote that was recycled from my father's unit - it says craftsman...
If the recycled remote is Security + there is no logical reason the new units should not work. If the old remote is a different technology and there have been changes to the opener or a different receiver that could be the problem.
Aug 20, 2011 | Sears Craftsman LiftMaster Chamberlain...
I really need your help. My Craftsman unit model number is 139.53615SR manufactured 1/92. I have a three car garage. The original two remote controls were lost and since then I've used the setting in my...
Have your neighbor bring over his remote and open or close your door with it. Then hold the smart/learn button in for 6 seconds on your opener. Then see if he can open your door. He shouldn't be able to because that procedure erases the memory in your opener. No remotes should work. You need to get that remote #53778 back and program it and then see if your neighbor can open your door. If he can open your door at any point after you have held that button in for 6 seconds you need to get a new door opener.
Oct 25, 2010 | Sears Craftsman LiftMaster Chamberlain...
I'm trying to program a remote to the sears craftsman garage door opener model 139.53513
The model number for the remote that works with this opener is 53778. Make sure the dip switches are set exactly like the switches on the end of the motor unit.
Oct 02, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a liftmaster security+ garage door opener. My car remote does not open the door anymore. Is there someway to reprogram the remote again? We are also having problems programing the remote in our car,...
If the instructions for programming your car remote has you using your original remote and the original remote has quit you will need to purchase a new Liftmaster remote.
Oct 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Cannot re-program remote transmitters for garage door opener
If both remotes quit at or about the same time then it is most likely the receiver that has quit. Especially if you have had electrical storms in the area. The receiver is part of your logic board.
Sep 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote to garage door opener wont work no solution on fixya
The Clicker is a hard one to program. You might try it a couple more times to be sure it won't work.
The 61LM is the Liftmaster remote that goes with that unit. There is a possiblity that the reciever on the board is bad. That board is no longer available but you can get a 635LM external reciever that is backward compatable with the 61LM remote.
Jan 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Door Opener
I posted the following answer to a similar question posed by 'dodgeya' the other day.
I'm not sure how to direct you to that thread, so am re-copying my suggestion here...
>> Do you have the option to change the electronic codes on your garage door opener system? My father-in-law had the same problem a number of years ago. He had not reset the code (equivalent to the combination on a lock) from the equivalent of 0-0-0 (which his unit shipped with). Turned out that a neighbor (or neighbour - in Canada) had the same /similar unit and when the neighbor opened 'his' door, my father-in-law's door would also open. You don't have to see the person drive by - it can be the neighbors behind you as well. You may find a solution by determining if you can change the original electronic code to a different one of your own choosing.
Hope this helps.
Jan 05, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage door opens
Hope this helps.
Dec 31, 2007 | Sears Craftsman LiftMaster Chamberlain...
Craftsman (older model)
Hope this helps.
Dec 17, 2007 | Sears Craftsman LiftMaster Chamberlain...
Home Security Logo
63 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
