Question about Frigidaire GLTF2940ES Front Load Washer
Frigidaire washer (model number GLTF2940E) starts when you push the Start button. Water starts to fill in but then stops after 15 seconds. Please adivce.
    Sergeant:
  • 291 Answers
If it starts to agitate after water stops filling check the pressure switch and hose. If it doesn't agitate check the supply hoses behind the machine make sure they are not kinked. If they look ok turn off supply valves and remove hoses from washer. They are connected to the watervalve. The valve has screens to catch lyme deposits and other debris. Use a toothbrush or spray bottle to flush debris clear. Reattach hoses carefully. Hand tight only and then a 1/4 turn more with pliers. Do not overtighten. Do not use teflon tape. Do not crossthread the connection. Turn supply valves back on to test. If problem persists watervalves may need replaced.
Posted on Jan 07, 2013
SOURCE: frigidaire washing machine
OK Check elec plug at motor . Mine was doing exac same thing . Take belt access panel off back and pull wire plug off motor and push back firmly on . This plug does not have a tab so vibrates off . Good luck .
Posted on Mar 12, 2008
SOURCE: frigidaire front load washer will not start
You need a new front controller board part # el1347360
Posted on Jan 22, 2009
  • 4 Answers
SOURCE: frigidaire affinity front load washer doesn't start
mabye there is something keepin the door open, thats usually why most washers dont start
Posted on May 11, 2009
localwonder
  • 6784 Answers
SOURCE: Frigidaire Front Load washer Model FWT645RHS1 wont fill with Water
The drain hose might be too low. Make sure the drain hose is at least three feet above the floor.
Posted on May 31, 2009
  • 4 Answers
SOURCE: Frigidaire washer starts to fill with water then stops
That is not the solution.
Start the machine and immediatly press the "Start" and "Pause/cancel" button at the same time. Then you will get and ERROR code. Look on the cheat sheet packed with the machine to find out what is really wrong. That will give you the real answer.
Appliancepartssuppliers.com
Posted on Dec 22, 2009
Code in digital display does not have a E in front of it
Please let me know if you can get a number after this - if so what number shows up?
Model differences:
• Better models have a digital readout display
• Good models do not have a digital readout display
In the Better Models line, the failure codes will appear in the display as an E followed by two numbers, a number and a letter
or two letters. The control will beep and the Door Lock, Wash, Rinse, Final Spin and Control indicator lights will flash.
Example: E14. To stop the flashing and beeping, the customer may touch the Pause Cancel button. The error code remains
stored in the control but once the problem is corrected, it does not effect the operation of the washer. If the failure is something
that the customer can correct (such as the water faucets being turned off), the washer will operate normally the next time it is
started.
In the Good Models line, the control signals the failure code by flashing the five indicator lights of Door Lock, Wash, Rinse,
Final Spin and Control for the first number or letter after the E and the Start indicator light for the second number or letter
after the E. When a failure occurs, the washer stops or pauses and the control beeps and flashes the five indicator lights to tell
the customer that a failure has occurred. To stop the flashing and beeping, the customer may touch the Pause Cancel button.
The error code remains stored in the control but once the problem is corrected, it does not effect the operation of the washer.
If the failure is something that the customer can correct (such as the water faucets being turned off), the washer will operate
normally the next time it is started.
To recall an error code,
• Wake the machine by pressing any button
• Wait 5 seconds
• Press and hold the Start and Pause Cancel buttons simultaneously
• All LEDs will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking
LEDs. The control will repeatedly signal the code, as long as the Start and Pause Cancel buttons are pressed.
A two-second pause between repeats affords you the ability to make accurate counts to identify the correct error codes.
Please Note the following...... on a small number of washers with serial number prefix XC4,
if the previous procedure does not perform as specified, follow the option below:
• Follow all previous steps but instead of pressing Start and Pause Cancel buttons,
press and hold Options and Pause Cancel buttons.
If the washer is a Better Model, the error code will appear in the display. Troubleshoot problem by using charts on the
following pages.
If the washer is a Good Model, the five indicator lights of Door Lock, Wash, Rinse, Final Spin and Control will flash the
number of times for the first digit of the code and the Start indicator light will flash the number of times for the second digit.
Take
separate counts of each indicator light, then repeat to confirm in order to be accurate in identifying the proper error code.
The code is obtained by counting the number of times the lights flash. Example E24: The five indicator lights would flash twice
indicating the 2 and the START indicator light will flash four times indicating the 4. The five indicator lights and the START
indicator light start flashing at the same time.
The control will pause for 2 seconds, then repeat the code as long as the two buttons are pressed and held.
Note: A letter appearing in the code stands for a number higher than nine:
A = 10 B = 11 C = 12 D = 13 E = 14 F = 15
Example Code F1: the first digit would be 15 and the second digit would be 1. If this code would appear on a washer in the
Good model line, the five indicator lights would blink fifteen times and the START indicator light would blink once.
May 13, 2014 | Frigidaire ATF6000ES Front Load Washer
The dryer just stopped and now wont turn on
WAKE THE WASHER BY PRESSING ANY BUTTON.
WAIT 5 SECONDS.
PRESS AND HOLD THE START AND PAUSE/CANCEL BUTTONS SIMULTANEOUSLY.
ALL LED'S WILL GO BLANK AND AFTER A FEW SECONDS THE CONTROL WILL SIGNAL THE STORED CODE USING AUDIBLE BEEPS AND BLINKING LED'S. THE CONTROL WILL REPEATEDLY SIGNAL THE CODE, AS LONG AS THE START AND PAUSE/CANCEL BUTTONS ARE PRESSED. A TWO-SECOND PAUSE BETWEEN REPEATS AFFORDS YOU THE ABILITY TO MAKE ACCURATE COUNTS TO IDENTIFY THE CORRECT ERROR CODES.
PLEASE NOTE THE FOLLOWING: ON A SMALL NUMBER OF WASHERS WITH SERIAL
NUMBER PREFIX XC4, IF THE PREVIOUS PROCEDURE DOES NOT PREFORM AS
SPECIFIED, FOLLOW THE OPTION BELOW:
* FOLLOW ALL PREVIOUS STEPS BUT INSTEAD OF PRESSING START AND PAUSE/CANCEL BUTTONS, PRESS AND HOLD OPTIONS AND PAUSE/CANCEL BUTTONS."
*THE CONTROL WILL PAUSE FOR 2 SECONDS, THEN REPEAT THE CODE AS LONG AS THE TWO BUTTONS ARE PRESSED AND HELD."
NOTE: A LETTER APPEARING IN THE CODE STANDS FOR A NUMBER HIGHER THAN NINE: A=10 B=11 C=12 D=13 E=14 F=15 "
"EXAMPLE CODE F1: THE FIRST DIGIT WOULD BE 15 AND THE SECOND WOULD BE 1. IF THIS CODE WOULD APPEAR ON A WASHER IN THE GOOD MODEL LINE, THE FIVE INDICATOR LIGHTS WOULD BLINK FIFTEEN TIMES AND THE START INDICATOR LIGHT WOULD
Jul 28, 2012 | Frigidaire GLET1031FS Top Load Stacked...
Frigidaire gallery series front loader will not spin or drain
You really should recall the error code from the unit. Try the following and let me know if you can figure out the alpha numeric code.
WAIT 5 SECONDS.
Jul 28, 2012 | Frigidaire ATF6000ES Front Load Washer
My moms front loader is a frigidaire gallery series. when she tries to start a load itll bring in a lil water and then just stop. don't understand why it is doing that
Turn off the machine then unplug it for at least 5 minutes and plug it back. Turn on the washer then press any button and wait for 5 seconds. Press and hold the START/PAUSE and CANCEL buttons simultaneously and the most recent error code will appear on the display as an "E" followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. Post back the error code to determine the problem and necessary actions to be undertaken in order to address it.
Jul 19, 2011 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
I have a Frigidaire Gallery 3.5 Cu. Ft. King Size Front Loading Washer, GLTF2940E and t dont work anymore. at start it fills some water and than stops with continius humming sound and when i do the...
it indicates a communication problem between the central main control and the motor speed control.
The two control boards are not talking to each other.
The first step to resolving this problem is to check the wire connections at each of the controls. The main control under the top panel and the speed control behind the rear panel. See the images below for help with this. Pull and push on all of the connectors.
Remember to unplug the washer first.
If all connections are tight then most likely the main control will have to be replaced.
If you do not feel confident repairing this problem yourself, then you can have it repaired at your home by a Sears technician.
Jan 10, 2011 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
During any cycle washer will stop and beep and flash E10. after pushing start it will continue, sometimes will do this several times in a load.
i believe that code is water related not getting enough water maybe drain hose is too far down drain and unit is siphoning
Apr 18, 2010 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
My Frigidaire front load washer model no. GLTF2940E, is about 5 years old. It has always worked fine. Last week the spin cycle left some cloths wet and now when I start it, it only allow about 5 seconds...
Sounds like you have faulty water inlet valves. They may not be opening fully. You can test the power to the valves with a voltmeter to see if the power is quitting or if the valves are malfunctioning
Mar 12, 2010 | Frigidaire ATF6000ES Front Load Washer
Wahser does not stop filling water
replace the water inlet valve
May 03, 2009 | Washing Machines
Frigidaire washer will not start. Get err and LOC codes.
All the lights are on, but the door lock. We have unplugged it, doesn't help. Our washer is the front load, model LTF 2140ES0.
May 18, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire GLTF2940ES Front Load Washer Logo
61 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
