Question about Canon Pixma Mp250 Allinone Inkjet Photo Laser Printer
Processing cannot be continued because print spooler service has been stopped
SOURCE: My Canon PIXMA MP240 all-in-one
I had the same issue!! I called up Canon Australia on 13 13 83.
The gentleman explained that even thought it was called Print Spooler, it was my laptop.
Start Menu > Run > services.msc
Long list of items > scroll down to Print Spooler
STARTUP TYPE SHOULD BE "AUTOMATIC"
AND SERVICE STATUS SHOULD BE "STARTED"
if it's not, click "Start" > then Apply
no need to reboot - try installing the drivers now.
Good luck! If this doesn't work, call Canon tech support in your country :)
Cheers!
Kayo
Posted on Apr 02, 2009
sandrew
  • 2961 Answers
SOURCE: "Error 1068 Could not start the Printer Spooler on local Computer"
Just to add to CoachTim's excellent solution, i find that removing the printer from the usb port as well as turning it off helps. But make sure you uninstall printer completely from add/remove programmes and check in the folder after that there is no canon printer listed. download this UK driver http://software.canon-europe.com/software/0024838.asp?model= Restart your pc before re installing and re connecting printer.
Posted on Feb 16, 2007
  • 15 Answers
SOURCE: Cannot install my Cannon mp 210 printer
Hi, the spooler service is usually set to start automatically when the PC starts up. It sounds as if this may have been changed.
To check this right click on "My Computer" & select "Manage" (4th one down), at the bottom of the list you will see "Services & Applications" - if you click on the + next to it you will see some more options, 1 of which is services.
Click on services & the right hand pain will list all services installed on your machine, it should be in alphabetical order so work down to the "P's" & find "Print Spooler", under startup type it should say automatic if it says anything like Manual or Disabled just double click it & on the window that appears change the setting to automatic using the dropdown box, click on start to start the service & you should be flying!
Let me know how you get on.
Posted on Jul 09, 2009
pineworks
  • 4041 Answers
SOURCE: Hello, I have problem like
Hi there
You can try see if this may do it.
Go to Start / Run and type in "services.msc" without quotation marks, then press Enter or click OK.
In the window that opens (Services) look for "Print Spooler" on the right
Right-click "Print Spooler" and select "Properties".
Click on the "Recovery" tab and change all 3 drop-down boxes to "Restart The Service".
Make sure the 2 text boxes underneath say "1" in them.
Click Ok until you are back at the Services window, close it and you're good to go.
Go back into the properties of the "Print Spooler" tab and be sure to click Start to restart the Print Spooler service and it will restart the service immediately.
The Print spooler depends on the Remote Procedure Call (RPC) service. Is this service disabled? Go to services.msc look for RPC. Check state: Automatic
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 28, 2010
Geekman
  • 32281 Answers
SOURCE: Processing cannot be continued because the print
To information on fixing print spooler problems go to theseWEB sites.
http://windows.microsoft.com/en-US/windows-vista/Troubleshoot-printer-problems
http://en.kioskea.net/faq/2349-enable-disable-the-print-spooling-service
Posted on Jun 15, 2011
I got an installed printer, and it can't print. It seems that my PC cannot read the printer, like there is no printer installed. When I try to uninstall the printer and to install again the error
When you try to install a printer and get an error message "Print Spooler is not running" then Print Spooler need to be configured. Open Print Spooler as detailed above and click on the General tab then select these items - Startup type select Automatic Service status click Start Then click OK MICROSOFT PRINT SPOOLER FIXES
http://support.microsoft.com/kb/934885
Jan 11, 2013 | Office Equipment & Supplies
Print spooler service stopped
Solution
Press START - Run - write msconfig - OK - Services - put checks on the print spooler - OK - restart
After computer restarts, to check printer spooler
press Ctrl+Alt+Delete - Processes. If there spoolsv.exe file, it means the printer spooler is active.
Nov 30, 2011 | Canon PIXMA Office Equipment & Supplies
Processing cannot be continued because the printer spooler service has been stopped.
Go to START then click on RUN. Type services.msc. This should pull up services window. Look for Print Spooler. Start the service from there. That should fix the problem.
Hope this helps.
Jun 30, 2011 | Canon PIXMA iP1300 Printer
Print job won't cancel
Thank you for posting your problem.
To fix your issue please do the following:
To start or stop the printer spooler from a command line, follow these steps:
1. Click Start - Run
2. Type the following: net stop spooler
3. Hit Enter
(this will stop the print spooler service)
4. Click Start - Run
5. Type the following: net start spooler
6. Hit Enter
(this will start the print spooler service)
Jun 15, 2010 | HP PSC 2355 All-In-One InkJet Printer
Hello, I have problem like this - Process cannot continue because the Print Spooler service has been stopped. Restart the computer to start the Print Spooler & try again. I mean, I cant even install it...
Hi there
Feb 28, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
I appreciate the opportunity to help you. Try the following:
Check dependency services on Print Spooler
1.Click "Start", input "services.msc" (without quotation marks) to Start Search bar and press "Enter".
2.Double click the “Print Spooler” service.
3.Choose “Dependencies” Tab and remember the services name.
4.In the service list window, find the dependency services and try to start them.
5.Please try to start the “Print Spooler” service again.
See if this helps. If it does, please fill in the rating of my service to you. Thanks for using Fixya.com
Jan 27, 2009 | Office Equipment & Supplies
Cant install printer
If you are on Vista, type 'Services' into the search bar, or if you have XP, Run 'services.msc' and press enter, and scroll down to Print Spooler. Right-click on it and choose Restart.
Hope this helps
Chris (ziraffa)
Jan 11, 2009 | Canon PIXMA MX300 All-in-One Printer
Spooler serivice is stopped
Overview
This article describes two methods for restarting the Print Spooler service within Vista.
Method 1: Restart the service using the services console
  1. Click Start, type services.msc in the Start Search box, and then click services.msc in the Programs list. If you are prompted for an administrator password or for confirmation, you can either type your password or click Continue.
  2. Right-click Print Spooler, and then click Stop.
  3. Right-click Print Spooler again, and click Start.
Method 2: Restart the service at a command prompt
  1. Click Start, All Programs, and then click Accessories.
  2. Right-click Command Prompt, and then click Run as Administrator. If you are prompted for an administrator password or for confirmation, type your password, or click Continue.
  3. Type the following commands at the command prompt.
    net stop spooler [Press ENTER.]
    net start spooler [Press ENTER.]
    exit [Press ENTER.]
Apr 12, 2008 | Lexmark X4270 All-In-One InkJet Printer
Canon Pixma Mp250 Allinone Inkjet Photo Laser Printer Logo
old marine
old marine
