Question about Kenmore Elite Washing Machines
F05 code on Kenmore Elite Model 110.44932.201 15 ohm on heat element 9 ohm at temp sensor What do I check next?
I have a Kenmore Elite showing F05 code. Getting 9 ohm at heat sensor, 15 ohm at heat element, and 0 ohm at HE2 of CCU. Does that mean my CCU needs replaced? Thanks, Matt
2 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: F05 Error Code on Kenmore Elite HE3T Washer Model 11044932200
First of all, make sure you unplug the washer before making any measures, and make sure you unplug any connectors from the CCU, so you aren't reading parallel paths. Isolate the components you wish to test from the CCU or you may get inaccurate readings.
The reading across the heating element terminal should read 15 ohms. Make sure you aren't grounding your probe against the case, or you will get improper readings.
The NTC will read approximately what you have at room temperature. Was the connector plugged in before you began troubleshooting? A common problem is the connector falling off and generating the error code.
As far as the connector plug on the CCU is concerned, plug layouts can differ between models. Make sure you have the correct connector plug to the NTC. You may have to hand over hand it to find it. Unplug the connector at the CCU and leave it plugged in to the NTC. Perform a resistance check across the PLUG terminals. You should get the same readings as you mentioned before if the plug and wires are good. This not checks the resistance of the NTC, but also proves continuity of the wires.
Doublecheck your readings and let me know what you have. I would like to rule out a CCU problem. It is not common for this error code. I hope this helps you.
Posted on Sep 05, 2008
How does the NTC Sensor on my Kenmore Elite HE 4t come out?
Turn it, then it just pulls out. It just slides into a rubber washer. Wet it with water easy the slide.
Nov 09, 2012 | Washing Machines
Tip
F05 Error Code
This advice is for Whirlpool Duet and Kenmore Elite model FRONT LOADERS displaying the “F05” Error Code.
"F05" is an indication of a water temperature sensor (NTC) error, or Heating Circuit failure. Check the Water Temperature Sensor and check connections to the Water Temperature Sensor. To access, you will have to UNPLUG your washer and remove the lower access panel under the door. The panel comes off by removing the screws under the bottom edge. HINT: If you place a block of wood under each front foot of the washer, it will make access to the screws much easier. If the panel sticks, a tap on the sides will knock it free. The panel will drop down then come off. The sensor (NTC) is located at the base of the wash tub in the front on the heating element. This will be a small square shaped plug between the heating element terminals. Unplug the wire harness and take a resistance check. Readings will be as follows:
Temperature Meter Reading
32°F (0°C) 35.9 K ohms
86°F (30°C) 9.7 K ohms
104°F (40°C) 6.6 K ohms
122°F (50°C) 4.6 K ohms
140°F (60°C) 3.2 K ohms
158°F (70°C) 2.3 K ohms
203°F (95°C) 1 K ohms
Roughly...around 9K ohms at room temperature if I'm reading the chart correctly. Take readings as listed and also double check the connector to make sure it is not oxidized. Try cleaning the plug and reconnecting to see if the error code goes away. If not, you will probably have to replace the sensor. If the sensor checks good, take a reading across the heating element terminals. It should indicate about 15 ohms.
Lastly, remove the washer top panel by removing the three screws holding the panel in place in the rear. Once the screws are removed, slide the panel back then off. Locate the Central Control Unit (CCU) directly behind the wash tub. Take a resistance check at the Heating Element Solenoid by removing connector 9 from the CCU (this is the second connector from the RIGHT as facing from the front). A reading across test points 1 & 2 should also read 15 ohms.
I hope this information if found to be helpful.
on Dec 09, 2009 | Washing Machines
Tip
F05 Error Code on Whirlpool Duet & Kenmore Elite Front Loader Washing Machines
I hope this information if found to be helpful. If you have questions, or need assistance locating parts, please click on the following link and use the “ASK ME” feature for a quicker response.
http://www.fixya.com/users/jsrock516
on May 28, 2008 | Kenmore Elite 45986 Front Load Washer
Start wash runs for aprox one minute goes in to f05 mode hit pause and open and close door hit start goes through cycle?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@@@@
Jun 15, 2010 | Kenmore Elite 45986 Front Load Washer
F05 error
May 14, 2010 | Kenmore Elite 45986 Front Load Washer
What does the error code F05 mean on the he 4t front-loading washer?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
May 13, 2010 | Kenmore Elite 45986 Front Load Washer
What does the error code F05 mean on the HE 4t front-loading washer?
Mar 22, 2010 | Kenmore Elite 45986 Front Load Washer
What is the F05 error code for on my Kenmore elite he 4t washer
Jun 16, 2009 | Kenmore 44932 Front Load Washer
F05 error duet washer
this is a water temperature sensor error check the: water temperature sensor, heating element and, element relay
Jun 09, 2009 | Kenmore Elite 45986 Front Load Washer
Error code F05 after the start of wash cycle
F05 is a water temp sensor error ,could be a bad heating element, or the temp sensor may be faulty, try checking the connection's to the temp sensor and heating element, also check the element relay.
Apr 20, 2009 | Whirlpool GHW9100L Front Load Washer
Washing Machines Logo
54 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
