Question about Passport 9500i Radar/Laser Detector
It power down and does not turn on any more - Passport 9500i Radar/Laser Detector
Orange light trying charge
I would try this:
take the battery out
unplug the charger
turn upside down
hold power button down for 1 min
keep holding power button down as you turn over the laptop
while still holding power button down plug in charger and try to power on
Jan 26, 2014 | HP Computers & Internet
Tip
How To Reset Your Samsung Vibrant
<span style="font-weight: bold;">Soft Reset</span><br /> <ol> <li>Turn the power off.</li> <li>Remove and reinsert the battery.</li> <li>Turn the power on.<br /></li></ol><span style="font-weight: bold;">Hard Reset</span><br />A hard reset will reset all of the settings and data. The phone will return to factory default settings without affecting the data on the SD card.<br /> <ol> <li>Turn the power off.</li> <li>Press and hold down the <b>Volume Down, Volume Up</b> and <b>Power</b> buttons simultaneously.</li> <li>When the Samsung Vibrant logo appears on the screen, release the buttons.</li> <li>Press the <b>Volume Down</b> button to select <b>Delete all data</b>.</li> <li>Press <b>Power</b>.</li></ol><br />
on Feb 15, 2011 | Samsung Vibrant
Lamp timer reset for toshiba tlpx100
To reset the lamp counter:
  1. Turn power off and unplug the power cord
  2. Simultaneously hold down these three buttons: "ON/STANDBY", "RETURN", "DOWN" (the arrow down symbol)
  3. Plug in the power cord while still holding down the buttons.
    The Projector will emit a series of beeps.
  4. Turn on power using "ON/STANDBY" button and check that "0H" appears on the lamp time in the status display.
  5. Turn off projector using "ON/STANDBY" button
  6. Unplug power cord.
I hope this helps.
Sep 25, 2013 | Toshiba TLPX100 Projector
How to turn down the deadkey on galaxy 48t to 4 watts the rf power knob will take it to 25 watts only
You can turn down VR18 which is your low power but as you turn it down your high power may go down also. If that's the case then you have to adjust L40,L42,L43,and L44 . If you don't have a scope don't even try it . 10 watts low may be the lowest you'll get. You can also try changing a few Elec. caps. to bring it down more and thats where the scope will really be handy.
Aug 15, 2013 | Radio Communications
Looking for a solution to an error 6502 on canon printer mp510
turn power switch off so green light is extinguished.
First hold down resume button and then hold down power button so both are held down at same time
When green light comes on, continue holding down power button and let resume button go, then press resume button twice. Then let power button go.
Then press resume button four times, power button should be releasedbefore doing this.
Wait until printer settles down, if power is off, turn on. If power will not come on, remove power cord from back of printer, then wait 15 seconds before plugging back in again and turn power on. This normally solves the error problem - if not go through same procedure again.
Jul 25, 2011 | Canon Office Equipment & Supplies
I have a toshiba estudio 200l wuth perform preventive maintenance on display. How do I clear off of screen?
turn off power
hold down 0 & 8 keys
turn power on with keys still held down till beep is heard
enter 252 then press start key
enter 0
press enter icon on display
power off & on
should clear service message
Feb 15, 2010 | Toshiba Office Equipment & Supplies
Monitor turns itself off
hi, you must have enabled power saving options. Thats why your monitor shut down. you can disable, just do the same:
1.Right click on desktop
2.Select properties.
3.Select "ScreenSaver".
4.Select "Power" under Monitor power option.
5.There select "never" from Turn off monitor (drop down menu).
Now your monitor will not turn off automatically.
Sep 19, 2009 | Dell Inspiron 531s Desktop Computer
No front speaker sound
Microprocessor reset.
For US and Canada:
  1. Unplug the power cord from the wall outlet, then plug it back in while holding down the POWER key.
For other countries:
  1. With the power cord plugged in, turn the POWER key OFF. Then, while holding down th ON/STANBY key press POWER.
Jan 12, 2008 | Kenwood VR-209 Receiver
Panel lock on dra 397
Speaker B and Mode buttons held down simultaneously while engaging master power, unlocked my DRA-397. Thanks!!!!
Dec 02, 2007 | Denon DRA-397
Passport 9500i Radar/Laser Detector Logo
Top Escort Vehicle Parts & Accessories Experts
John Nolan
Jason
Are you an Escort Vehicle Part and Accessory Expert? Answer questions, earn points and help others
