Question about Coffee Makers & Espresso Machines
The pins on the heating element protection thermostat for a Promac Green Sche2 espresso coffee machine are numbered 11,21,31 & 12,22,32. It has 6 conductors coloured red, brown & black. I know that the black conductors go to pins 21 & 31, however I am unsure where to connect the red & brown conductors to pins 11, 31 & 12, 32.
  • 2 more comments
  • Bruce Thompson Jan 08, 2013
    The purpose of the heating element protection thermostat is to control the Sirai Pressurestat. There are 6 colour coded conductors from the pressurestat that connect to the thermostat i.e. to pins 11, 21,31 & 12, 22, 32.
    Ok ... let me rephrase my problem. I am in the process of replacing a manual reset heating element protection thermostat on a Promac Green Sche2 espresso coffee machine which connects or rather works in conjunction with the Sirai Commercial Pressurestat. There are 2 sets of 3 contacts on the Pressurestat - one set n/o (normally open) the other n/c (normally closed) one suspects. In total those contacts are connected via 2 same coloured set of conductors i.e. red, black & brown. My problem is that I need to attach those conductors to the thermostat pins numbered 11, 21, 31 & 12, 22, 32. I can confirm that I know that the black conductors go to pins 21 & 22. What I need to know is what is the correct positioning of the other two sets of conductors red & brown. I do not want to attach them to the wrong pins for fear of an electrical catastrophe!
  • Bruce Thompson Jan 10, 2013
    Basically ... all I am wanting to do is reconnect the heating circuit i.e. from the pressurestat to the safety thermostat. Is there anyone out there who can help me please?
  • Bruce Thompson Jan 24, 2013
    All sorted ... thanks to all those who followed my post ... cheers!
  • 2039 Answers
SOURCE: DeLonghi automatic espresso machine
do you use the machine often oil in coffee create residue and can accumulate on the grinder and the residue is so thick that it does not let coffee trus remove the coffee bean and were the beans go u should see the grinder teet use a little tootbrush or anything that might fit in there remove the residue and try it it should be good thanks for using fixya pierre
Posted on Feb 08, 2008
SOURCE: rancilio silvia espresso coffee machine
Esprosso Parts http://www.espressoparts.com/ sells all parts for the Rancilio Silvia, including some customized and modified parts.
Posted on Jan 18, 2009
SOURCE: SL90 stopped brewing espresso
Changing the control board on a SL 90 Re: Checking and Resoldering bad Solder Joints on an SL90
Tools:
#1 Phillip screwdriver
Scissors or Wire Cutters
Soldering Kit
Step 1.
Unplug Machine and remove the water tank.
Step 2.
Unscrew and Remove the recessed Phillips screw from the top back of the machine, right where the top of the water tank sits.
Step 3.
With the front machine resting against your chest, so the faceplate does not "pop" out, pull from the back -top of the machine (cup warmer), towards the front. To remove the top of the machine (cup warmer) you only need to slide it forward until the faceplate is vertical (perhaps ¾ of an inch), we caution against bringing it any further forward than this point. This will allow you to remove the top. You may let it dangle over the back of the machine where your water tank sits as it won’t hurt the machine. Take off the faceplate by carefully unplugging it from your power board on the left side of the machine.
Step 4.
There may be a white plastic zip tie that holds down your power board. You can remove this piece using scissors or wire cutters (please be very careful!). Next, slide your power board up and out of the two black metal sleeves. Do not worry about disconnecting any wires, as you only need to look at the back of the electrical board where all the small metal dots are. Notice the picture below as it highlights the solder joints that control the heating of your machine. If any of these look discolored (brownish-black) or is a dull gray (vs. shinny silver) then it is going to need to be resoldered.
Step 5.
If you have a Soldering Kit at home, resolder these three joints, making sure to melt some of the original solder. Once you are finished, put your machine back together and test it.
Posted on May 04, 2009
wavoconqueso
  • 57 Answers
SOURCE: Green slime in coffee machine
Try running a couple cycles through of full strength vinegar. If that doesn't do it run a weak bleach solution (6 to 1 / water to bleach) through it. Repeat vinegar every week then once a month if it clears.
Posted on May 07, 2009
  • 54 Answers
SOURCE: Espresso maker doesn't work properly
It is clear that there is a problem with water supply. Check if pump works, if it does, there is blockage in water supply to pump. Check and clean.
Posted on Jul 11, 2009
I have a premier maxi which recently stopped heating the water. When the coffee is brewed, it comes out cold. not hot water and no steam. What can the problem be??
First thing I would check is the reset thermostat on the right side of the machine above the element. Turn machine switch off then push in on pin you will hear a click.
Aug 06, 2011 | Nuova Simonelli Premier Maxi Espresso...
Rancilio Silva, after working well for three years, does not heat water when powered on. Suspect heating element bad. But is there a step I can take prior to replacing elements. Also, where can I get...
Remove the 4 screws on the top panel. Make sure machine is not connected to power. Check the thermostats on the boiler, there should be 3 of them, push in on the small red pin in the middle of them one of them should click in. Now fill up your tank plug machine in and turn on.
Oct 20, 2010 | Rancilio Silvia Espresso Machine
My machine has stopped producing hot water. The lights don't even flash to show it's heating up when I switch it on, it just goes straight to ready mode & then when I brew some coffee it comes out...
Either your coffee boiler elements are damaged or the thermostats on there are damaged or tripped, use an ohms meter to check element and thermostats.
May 20, 2010 | Gaggia Syncrony Compact Coffee...
Rancilio Silvia coffee machine worked once and the
Remove the top panel one of the thermostats on the tank tripped, reset thermostat, and turn machine on.
Dec 25, 2009 | Rancilio Silvia Espresso Machine
La Marzocco Expresso g3 how do you reouble
Check the thermostat on the top of the back boiler, if the red pin is up then, make sure that there is water in the boiler then push in pin and turn machine on. Now comes the exciting part we have to find out why the boiler overheated, is it because the elements are damaged or the pressure stat is not working properly.
Nov 05, 2009 | La Marzocco Linea Group 1 Espresso Machine
Will not heat up is the heating element shot?
Remove the top panel (disconnect from power), then press the reset thermostat on the boiler(Small red pin in the middle of the electrical terminals). Fill water tank and plug machine in and turn on.
Sep 27, 2009 | Rancilio Silvia Espresso Machine
Espresso shot is c old
If the water from the wand is coo also then the machine's thermostat at the top of the boiler needs to be replaced or reset depending on the model.
Jun 30, 2009 | Solis Crema SL-70 Espresso Machine
Heating element on an lavazza expresso machine
you can call this number they will help you with your problem
1-866-526-6204
Apr 15, 2009 | Lavazza Espresso Point Capsule Machine
Coffee Makers & Espresso Machines Logo
23 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
