Panasonic PT-50LC14 Television shuts off after a few minutes and lamp indicator lite blinks 1 time in 5 seconds but fan continues to run until i unplug the set. it has a new pure bulb about 2 months ago and i took the unit apart to clean all filters and blow everything clean, but still does the same thing. bulb looks ok, but have read alot about cheap aftermarket bulb problems. also, the cable input and the composite input don't function correctly as they have a very bad picture, but the component and dvi inputs work perfectly. any ideas as to the problems? thanks
SOURCE: I have a Panasonic PT-50LC13
Replace your Ballast Board it is what turns on Lamp call Encompass Parts 1-800-638-3328
SOURCE: Hello,
Hello well this kind of problem all the time is because you have a fan problem and you could have dirt inside of your tv and sounds also like a ballast problem i have this issue also and I got connected on the live chat that a web say has that they call discount-merchant they sell parts and lamps for TV they could help you they help me twice.
Regards
