Question about Samsung Audio Players & Recorders
HT TX 500 samsung home cinema does not power on . the red power light just flashes on and off , and when i press any buttons nothing comes on its being doin this for months now .
SOURCE: Samsung home cinema system HT-THX25 Multiregion hacks
Turn on the HT with no DVD. Press the following buttons on the remote: ENTER 8, 4, 2, 6, 9 ENTER
It will turn off. When turned again on it is a region free HT.
Posted on Nov 26, 2008
ginko
  • 19396 Answers
SOURCE: SAMSUNG HT-TZ212 home cinema kit comes up with protect
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Posted on May 04, 2009
SOURCE: SAMSUNG DIGITAL HOME CINEMA SYSTEM MODEL HT-Z110
Maybe the audio amplifier Ic are damaged and need to be replaced
Posted on Aug 14, 2009
  • 3 Answers
SOURCE: how can i listen to my tv through my cinema system
Use a fiber optic cable
Posted on Dec 27, 2009
  • 5 Answers
SOURCE: when i turn samsung HT-TZ212 home cinema system on
Hi , your amp board need to replace , get one from ebay.
Posted on Apr 04, 2010
Samsung home cinema wont turn on
Sounds like it's stuck in it's power saving mode. If you've tried reset, checked all the connections, and kicked out the plug for a Cold Reboot and it's still no go, open the back, spit in it 3 times and hit it with a rock - or take it to a TECH because you've already done ALL that you are capable of, or you'd already know that.
Jan 25, 2014 | Samsung Ht-c550 5.1 Dvd Home Theater...
Samsung Home cinema HT-TXQ120 system won't read CDs and DVDs.
Hi.
I have had the same problem.
Just unplug the systme and plug it back in.
Jan 03, 2010 | Samsung HTP-1200 System
Samsung hiome cinema protect error message
you need to change 5q tranzistor.if you dont have short circuit on pin 9 to ground on flat who comes from amplifier
Aug 04, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Protection displayed and shuts off When I press the power button Protection is appear on screen on my home cinema system dvd player
check wiring on speakers it sounds like you have some wires touching together somewhere or you have a bad speaker.
Jun 15, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Hi, I have Samsung HT-X50 connected with SWA-4000. It was working fine, then for somereason I had to remove and reinsert Tx card. After doing that SWA-4000 is not connecting to HT-X50. Blue light blinks...
You have to reset the connection:
With the home theater system off, press the 0-1-3-5 buttons in that order on the home theater's remote control.
Power on the home theater system.
With the wireless module on, press the [ID SET] button on the back of the wireless module for five seconds.
If your home theater continues to display rear check after you have tried the steps above, call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Have your model number and serial number on hand to set up service.
Hope this helps!
Jun 09, 2009 | Samsung HT-TZ515T Theater System with...
Samsung HT-A100 Home Cinema system plays cd only with tv on!
You need to put away the remote for your TV and use only the remote for your HT system. Your HT remote should work on your TV by default. Your Samsung HT remote should have a TV button and a DVD/Receiver button (or HT button). When using only the TV, press the TV button and then use it for just the TV and when using the HT system, press the DVD/Receiver button and then you can use the HT system.
If for some reason your TV is not set on the Samsung HT remote by default, your HT users manual should have a list of codes that you can use to program your HT remote. Hope that helps you. Gary
Mar 18, 2009 | Samsung HT-A100T Theater System
SWA-4000 doesn't adquire signal of HT-TX500 Home Theather
I was having poor audio from the back speakers and didn't even know it; intermittently I'd hear them jump in volume, so myself being a little adventurous, decided to push the ID set button on the back, totally losing my ilnk... after digging and playing, I figured it out:
1.) Turn off the Head (main) Unit 2.) Power on the wireless receiver, being sure it is away from routers, other BT devices, etc. 3.) Push the "ID Set" button on the back of the wireless device and hold it until the lights on its front panel flash. 4.) Point the system's remote control at the Head Unit and punch in 0135.  Its light should turn from red to blue. 5.) Perform step 3 again. 6.) Power on the head unit.
Should link up.
Might be some redundancy there, but it works :)
Also I found that after a few cycles It seemed to work better (perhaps cycled to a better channel?)
Oct 06, 2008 | Samsung SWA-4000
Feb 02, 2008 | Samsung HT-X20 Home Cinema 600W Theater...
Swa3000
  1. With the home theater system off, press and hold the REMAIN button on the home theater's remote control for 5 seconds.
    Note: You can release the REMAIN button when the POWER LED blinks blue/Red depending on model.
  2. With the SWA-3000 turned on, use a ball point pen to press the RESET button on the back of the SWA-3000. The POWER LED in the front of the home theater blinks two times.
Feb 14, 2007 | Samsung HT-Q70 Home Theater System System
160 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
