Question about Echo Pb-251 Leaf Blowers
Pb 251 primer bulb not working - Echo Pb-251 Leaf Blowers
2 Suggested Answers
rycgl
  • 1545 Answers
SOURCE: My echo pb 251 will start momentarily if I push
There is a small diaphragm inside the carburetor that uses the intake pulse from the engine and the rise and fall of air pressure to pump the fuel. Here is how it all works. The pulse passage is very important and is fairly small, going from a hole in the carb to a hole in the carburetor adapter to a small hole in the engines' cylinder. Of course though, the pulse signal is created by the engine.
You need to check the condition of your in-tank fuel filter, the fuel lines and the carburetor itself. The small parts in the carb tend to dry out over time and cease to function. Gasket and diaphragm kits and complete rebuild kits for the carbs are available. Here is how they work.
http://www.zamacarb.com/pdfs/TechGuide_2007.pdf
Posted on Apr 04, 2011
- how do I stop the piston from hitting the spark plug on my echo pb-251 blower?
You either have the wrong plug in it or the aluminium sealing washer is missing.
Feb 26, 2016 | Echo Pb-251 Leaf Blowers
Purge bulb not working on echo pb-500t,gas leaf blower
get a new primer bulb and diaghram and rebuild your carb or buy a new carb,same price,gas and ethanol and oil kill carbs, echo A021000781
Echo PB 230LN 05001001 05020818 Handheld Parts
May 26, 2015 | Echo Garden
Echo PB-251. Wont run full speed,changed ,plug,filters
I'm 99.9% sure it's the fuel line. The ethnoll in gas really shrinks the oem fuel lines
Jan 13, 2015 | Echo Pb-251 Leaf Blowers
Echo pb 251 leaf blower leaks oil
You need to check your gas line and the primer ball itself and make sure you don't have a split in the lines or in the ball, also check the fuel filter in the gas line to ensure it is not plugged up.
Apr 24, 2014 | Echo Pb-251 Leaf Blowers
My Echo PB-251 will not start.
I know you checked the plug, but it can fire outside the cylinder and then not fire under compression.
If you have compression, fuel, and spark at the right time you should get combustion.
Jun 28, 2012 | ECHO, Inc. PB-251C Handheld Blower
No fuel in primer bulb on my echo PB 2100 blower
The primer bulb pulls fuel from the carb into the bulb and dumps back to the tank, so either the tubes are not connected too the correct conections on the carb, or there is bno fuel getting to the carb from the tank ( fuel filter ) or if the primer is on the carb itself there in a red one way valve under the bulb which maybe faulty.
Jun 16, 2012 | Echo Pb-2100 Pb 2100 Leaf Blower Inner Fan...
I cant get it to start. The primer bulb wont refill with gas
The bulb pulls fuel from the carb into the bulb and back to the tank, if the bulb does not fill it is because there is a fuel blockage, either in the fuel filter in the tank, or the screen in the carb itself.
Jun 03, 2012 | Echo 135 mph 390 CFM Gas Blower PB-250C
Echo pb251h. Blower will only stay running if i pump primer knob. Carb was rebuilt, changed fuel filter, checked exhaust port, insulater appears to be ok, compression test around 100psi,new fuel lines and...
when the carb was "rebuilt" Did you pull out the screen and clean it out and also did you pull needle and diaphragm out and clean it out good, because if the needle is not working or the neoprene tip is swollen your needle adjustment will be out of whack,sometimes carb cleaner will make it swell up to where it won't open enough to get fuel through it....suggest you replace the needle and adjust your height of the tab to flush with the body of carb and make sure you have a good diaphragm in it along with new check-valve diaphragm, then make sure your primer is hooked up right ..it should be pulling fuel through the filter to carb and through carb and back to tank,your problem is definitely in the fuel system, keep trying different things you will figure it out
May 26, 2011 | ECHO, Inc. PB-251C Handheld Blower
My Echo Leaf Blower (PB-251) will not run at high speed. It is running to rich. Help please. Charlie
I've been fighting with an Echo PB-251 blower and an Echo SRM-225 string trimmer since near the end of last lawn season (this is the forth season I've had them). Along comes a thread on a firearms forum and lo and behold the answer to the problem is spelled out in terms even I can understand.
After reading that thread (which attributes the problem of the engine bogging down when throttle is activated to collapsing fuel lines) I was going to just replace the fuel lines, but I discovered that there are kits that include new fuel lines, rubber grommets, filters, clips and cap seals for about $13.00 each. Hell, the kit for the SRM-225 even provided a new primer bulb. Ten minutes after the UPS truck delivered them to my door I had both machines running like new again. If you've tried other things and it still hasn't worked I highly suggest you try this.
Jan 05, 2011 | ECHO, Inc. PB-251C Handheld Blower
Echo Pb-251 Leaf Blowers Logo
35 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
