Question about Refrigerators
I have a GE Adora refrigerator, model: DSS25KG and
I have a GE Adora refrigerator, model: DSS25KG and I started to get an aweful smell. I've been removing everything and discovered I had some meat spill and leak all over. I have the "Spillproof slide out" shelves but some blood got between the glass and the plastic that makes up the shelf. I can't seem to figure out how to remove the glass so that I can clean it all out. Any suggestions?
  • 518 Answers
SOURCE: fridge parts broken
Try checking HERE.
Hope that gets ya fixed up...
Geno
Posted on Mar 24, 2008
SOURCE: admiral refrigerator -shelf removal
You just "pop out" the blue clips. Then pull the shelf out and relocate it to your desired position. Lastly, replace the blue clip to the top of the hole where you placed your shelf.
Posted on Aug 08, 2008
lenwest
  • 150 Answers
SOURCE: Have the Kenmore Elite commercial refrigerator,
Try a sponge using gloves.Add hot water and continue with the sponge.
Posted on Feb 21, 2009
SOURCE: maytag refrigerator MSD2454GRW shelf removal
The above answer is only HALF right. The blue clips have to be removed to lift the shelf up and pull it toward you.
To remove the clips:
1. Get a screw driver or something to get behind the clip.
2. Slide it behind the clip and slowly pry it toward you.
3. Repeat for the clip on the other side.
4. Do the above; lift the shelf slightly and pull it toward yourself.
Posted on Mar 02, 2009
  • 531 Answers
SOURCE: My whirlpool refrigerator W-21 model #
clogged drain
Posted on Apr 01, 2009
Our 3 month old ge adora dishwasher stopped working properly yesterday. Made funny noise and later I started smelling something burning. Opened it and noticed no water was in it. Restarted and still n
Sounds like the water inlet valve isn't working. Check your house water pressure and make sure it's not above 80 psi. If it isn't, then call a repair company that handles GE warranty work.
Dec 02, 2014 | GE Adora Dishwasher. Built-In Tall Tub...
GE adora side by side French door ice maker keeps freezing up and led light blinks. Have had repairman several times for same problem. Can I removed unit to thaw?
  • Possible solenoid fill valve failure
  • Possible failure of the mold heater, not allowing the ice to be removed from the mold.
  • Possible failure of the mold heater thermostat
Aug 30, 2014 | GE Adora (DSF25KGTBG) Side by Side...
I have a lettuce smell in my refrigerator
Most of the time the smells get into the insulation on the unit and is near impossible to get rid of. You might try arm and hammer to keep the smell down.
Mar 11, 2012 | GE Refrigerators
GE Adora Refrigerator. On the freezer side, water seems to be leaking from the top/back of the freezer. Not sure how it's happening, as it's usually frozen when I realize it. My housemate believes...
Hello
Check fill tube that puts water into ice maker. You may need to use hair dryer to thaw out. Look for a tube that comes out of back wall of freezer behind ice maker section. Make sure its there and pushed all the way in .This is a bad GE design. (could have fallen out)
hope this helps
Aug 16, 2011 | GE Adora (DSF25KGTBG) Side by Side...
GE Adora Side-by-side refrigerator (Model: DSL26DHWSS) is making a clicking sound. Sound coming from left lower back of refrigerator. Can you tell me what could be making the sound? Thanks
THERE IS A COOLING FAN ON THE BACK BOTTOM OF THE UNIT THERE MIGHT BE SOMETHING HITING THE FAN BLADE.IVE HAD THE SAME PROBLEM JUST SLIDE IT AWAY FROM THE WALL AND REMOVE THE CARDBOARD COVER AND CLEAN OUT ALL DUST WITH A VACUME ....{.NOTE UNPLUG THE UNIT FIRST.}
Jul 15, 2011 | GE Adora DSL26DHWSS Stainless Steel
Problem is rotten smell inside GE profile fridge. I've checked for rotten food-none; taken everything out and cleaned inside plus all shelves with added bleach in water. Smell is still there. I...
Hi, pull out the fridge and remove the back panel, and clean that area. Make sure no food is stuck under the fridge also. A rotten piece of fruit or other food, once under there, will smell until it totally decomposes. You can also mix 1/3 cup of bleach and 2/3 cup of water , and pour down drain tube (rear bottom in freezer section. Too much bleach and the smell of bleach would be circulated by the fan to the room, so be sure to add water. Finally, another popular methods of removing fridge odor include washing the entire fridge out with a vinegar and water solution, placing fresh coffee grinds or boxes of baking soda on each shelf and even using trays of cat litter.
May 17, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Our GE Adora Refrigerator's ice maker isn't working properly
Perhaps your freezer isn't set cold enough - or your freezer door seal is not sealing correctly and the ice cubes are melting in the bin and sticking to one another and the spiral screw that delivers the ice.
Mar 14, 2010 | GE Adora (DSF25KGTBG) Side by Side...
Where are the coils on the GE Adora side by side?
Most coils on modern refrigerators are underneath.
In past years, some refrigerators had coils on the rear.
Oct 10, 2009 | GE Adora (DSF25KGTBG) Side by Side...
My express thaw won't turn off
You have a bad main control board problem . Stuff a shelf in the refrigerator section with crumpled up newspaper and leave running ( the ink in the paper absorbes odor . Takes several days to eliminate .
Jul 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
44 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
