Question about Singer Confidence 7469 Mechanical Sewing Machine
Feeddogs won't come back up
I put the feed dogs down and now they won't come back up.
  • 29 Answers
SOURCE: feed dog is stuck
I have the same problem...this is a work around, not a fix. You need a small flat-head screwdriver. 1. Remove the clear bobbin cover. 2. Make sure the feed dog switch is in the DOWN position. 3. Slide the screwdriver under the feeddogs from inside the bobbin area & lift the feed dogs. 4. While holding the feed dogs in the up position, return the feed dog knob to the up position. You have to do this every time you put the feed dogs down...bummer, but I can find no broken part or adjustment that corrects this. If it's inside the machine body, I don't mess with it... I did take off the bottom plate in the feed dog area..one screw holds it.... there is nothing there to indicate a problem.
Posted on Jul 14, 2007
  • 1788 Answers
SOURCE: Feed dogs will not raise. After putting feed dog
go to singerco.com and look under frequently asked questions for Futura
Posted on Sep 12, 2010
  • 1788 Answers
SOURCE: how to put feed dog down on HD110
You either have a cover in your accessories pack, or there is a lever next to your bobbin case door. I suspect with the drop in bobbin that you have a little dark plastic cover to put over the feed dogs when you darn etc. Your manual should explain all of its uses. If, you didn't get a manual with your machine, call Singer and complain because it is a very important piece. Their number is 1-800-4singer. Make sure that you register your machine with them, also on their site www.singerco.com Good luck and happy sewing.
Posted on Dec 30, 2010
  • 1788 Answers
SOURCE: I let my feed dog down to stipple, and not it
I think that there is something disconnected, maybe a belt or a switch has broken. Try taking your machine cover off and check it out. I hope that it is something just disconnected, making the switch not respond. Good luck, I have my fingers crossed for you. I am a 50 year sewing veteran and have seen all sorts of strange things. I anwer for free.
Posted on Mar 31, 2011
Tally Girl
  • 1129 Answers
SOURCE: I have a Singer Quantum
Have you actually put fabric under the foot, and started sewing a few stitches? On some machines the feed dogs do not reengage until the machine has gone through a full stitch sequence. So it looks like they are still down and nothing is happening until you've actually pressed the pedal and tried to stitch again. Also some computerised machines, try turning off and leaving off for 30 seconds, then turn on and try to stitch, sometimes this will work too.
Posted on Sep 11, 2011
My machine will not advance on it's own what do I need to do to fix it??
it sounds like the feeddogs are in the down position, look at the
area where the needle plate is and see if you can see the feeddogs?
you can even run your finger over that area and you should be able
to feel the teeth. if you can feel the teeth or see them, then check
the feed dog lever to see if it's in the up postion.
the feed dog control lever should be in close to the bobbin area,
the question is under the necchi 4575 catagory, so that's the
information I'm putting in for the machine, if the lever is up then it's
possible that something is wrong with the lever or the feed dogs
them selves and they need to be checked at a sewing machine
shop
Oct 23, 2012 | Necchi 4575 Mechanical Sewing Machine
My fabric dosnt move foward or back wards with the petal or manually ..
if the fabric won't move then there is something wrong with the
feed dogs, check in the needle plate to see if you can see the feed
dogs. you should be able to see them & touch them with your finger
since they are not moving the fabric it would be a good idea to
have the machine checked
I'm putting a link for a free manual for the machine, you can check
in the manual to see if it show where the feed dog lever is on the
machine, if it doesn't show a lever, or the lever is not responding to
movement then the machine needs to be checked to see what's
wrong.
http://www.singerco.com/uploads/download/463_2932_esf.pdf
Sep 04, 2012 | Singer 2932 Mechanical Sewing Machine
I dropped the feed dogs and they won't come back up.
Ignore all the other comments, they are wrong.
The feed dogs are driven by the feed driver mechanism, turn the hand-wheel forward and the feed dogs will come up. (Providing you have the feed dog switch to the up position).
Aug 28, 2012 | Brother PC-420
Janome feed dogs
then the feeddogs need to be check to see if they are attached to the lever & to see if they're out of time
May 04, 2012 | Janome Sewing Machines
Frozen feed gears singer sewing
the machine needs to be checked when the feeddogs don't move
but first check to see if the feeddogs are in the up position & if the
feeddogs are up, then the machine needs to be checked
Apr 28, 2012 | Singer Sewing Machines
Feed dog not pushing fabric
then the feeddogs need to be checked at a sewing machine shop to see
what wrong with the feeddogs
Apr 27, 2012 | Bernina Bernette 75
The feed dog in the brother cs6000i wont stay up
sounds like the feeddogs or the feeddog lever needs to be replaced
if you want parts try
sewingpartsonline.com
premiersewing.com
Mar 24, 2012 | Brother CS6000i Computerized Sewing...
I put the feed dogs down and now they won't go back up, what do I do now?
Feb 11, 2012 | Baby Lock Ellure
Feed dog wont feed the fabric
Remove the needleplate and clean between the teeth of the feeddogs.
Ensure the feeddogs are not lowered for free motion sewing.
Don't know the make/model to be any more specific, so post back here or to the Contact Us page at  www.bargainbox.com.au if there is more to do.
Nov 24, 2008 | Brother LS-2125 Mechanical Sewing Machine
Singer Confidence 7469 Mechanical Sewing Machine Logo
24 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
