Question about Refrigerators
Samsung rl33sbsw motor working but fridge and freezer not cooling
zeusfaber
  • 247 Answers
SOURCE: Samsung Fridge Freezer (Freezer on top)Model SR-52NXA wont cool
Depends a bit on whether the compressor really is running, or if it's just humming because it's got power on the run coil, but not on the start coil.
Have a careful listen to the compressor. If it's making the trilling or gurgling sounds that go with a working compressor, then your problem is probably one of lost gas. Fixing this is not a do-it-yourself job.
If the compressor sounds like it's stalled, the problem may lie with the starter. Replacements are usually cheap enough for it to be worth fitting a new one just to see if it works.
A.
Posted on Feb 28, 2008
  • 5 Answers
Possible bad defrost timer.
Posted on Mar 09, 2008
mikedurland
  • 481 Answers
SOURCE: samsung fridge freezer
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Posted on Jun 30, 2008
tborn6
  • 700 Answers
SOURCE: samsung rs2533sw fridge not cooling
soiunds like the coil on the refrigerator side is iced up.take and open the refrfigerator side and take a blow drier and after removing the 11 screws use the hair drier to slowly melt the icec behind the cover. If you pull too hard and or too soon you'll break the stryofoam ductin that has to be around the coil. then make sure that the drain line is clear reassemble and have a Merry Christmas!
Posted on Dec 24, 2008
woodchuck789
  • 4070 Answers
SOURCE: the fridge is cold but the freezer won't freeze
The grill being the condenser coil- The sealed system is low on freon or the compressor isn't working correctly.
Posted on Jul 01, 2009
My Samsung RS21DPSM is not freezing, the fridge is working and the fan in the fridge is not loud. The freezer is not freezing.
Check the condenser fan in the compressor department. The fan motor is know to fail. The refrigerator and freezer temps will be cool but not cold. I would start there.
Apr 02, 2014 | Freezers
I have a Samsung RF268ABRS Unit all food in bottom freezer thawed. Unit is running and ref is cool. I notice that the fan dosent seem to blow. Closed freezer up and its cold, but no air moving. How do...
I had a similar problem. my samsung freezer would only cool to 20 degrees, which also resulted in the freezer ice maker not functioning. (fridge door ice maker still worked) If you hold the power freeze and power cool buttons down together for 8 seconds it will a diagnostic. found the answers on http://appliancejunk.com/forums/index.php?topic=8206.0 , as too what the codes meant. Mine was throwing a freezer fan code error. ordered one online $30 and replaced it. seems to be working. TIP -The fan is located behing the rear panel in the freezer. I had two fans. The regular looking one is the freezer fan, the squirrel cage fan feeds the fridge ice maker. Also the new fan motors don't come with blades, just pull the blades off the old one and put it on the new motor. Don't push it on too far, make sure there is enough clearance so it spins freely.
Jun 28, 2011 | Samsung RF267AB (25.5 cu. ft.)...
Refrigerator side not cooling freezer sides is working i had the fan motor replaced but still fridge side not cooling.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
dygjdgh
Jul 14, 2010 | Samsung RS2534 Side by Side Refrigerator
I have a samsung SR-S2028cvw American style fridge freezer. The temperature on the dials are at the coolest but both the fridge and freezer are warming up to the warmest temperature before the motor kicks...
Try hoovering the cooling rad on the back of the fridge freezer, as this tend to clog up with dust and other matter, which reduces the cooling efficiency
Feb 28, 2010 | Samsung Refrigerators
The fridge is cold but the freezer won't freeze
It has seperate cooling circuits as you describe the problem can be a leak of refrigerant in the freezer circuit.if there is no heating up in the freezer condensing coil.It has to be check for the leakage.
Jul 01, 2009 | Freezers
Fridge side of American Fridge/ freezer not cooling down.
does the fridge have 2 motors or 1 if it have only 1 motor the gas level in the system are low. if it have 2 motors check if the fridge side motor runs
May 17, 2009 | Samsung Refrigerators
Mar 08, 2008 | Refrigerators
SAMSUNG AMERICAN STYLE FRIDGE FREEZER MODEL RS21DCNS
Sounds like u need to replace fan motor
Check fan motor for continity IF none replace fan motor
Oct 12, 2007 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
