Question about Hardware & Accessories
I have an Intermatic PF 1102T that is about 15 years old. The timer (clock) has quit keeping time. It will come on if you manually turn it on. You have to manually turn it off as well. How difficult is it to replace the clock part?
  • 5,089 Answers
1) Copy following link for timer module model numbers and wiring:
PF1100 series appears to use PB913N84 timer module.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#PB
2) Timer module for PF1100 series is held in place using phillips-head screws.
It should be easy to replace, although I have not fixed this specific product. You may need new terminal connections from hardware if existing timer module is hardwired.
http://waterheatertimer.org/Terminals.html
3) Add a comment and attach photos of work
Posted on Jan 07, 2013
protek480
  • 1714 Answers
SOURCE: Intermatic pool pump timer, time clock won't turn
Check your wiring, it sounds like it's not right. The clock needs 120 volts to run.
Posted on Jun 30, 2009
  • 94 Answers
SOURCE: INstruction manual needed Intermatic HB800RCL
To download the file you need Acrobat reader 7 at least. I just tried it and I was able to get it. It was slow but got it. Go for it and hop this was helpful!
Posted on Aug 23, 2009
SOURCE: how to replace clock in intermatic timer
I need to replace the timer on a model #ML600TW
Posted on Oct 19, 2009
  • 760 Answers
SOURCE: Wiring of Intermatic T8845pv
I believe the number you gave is fir the 14 day timer. Here is a link to the manual for it. Notice the not to use only one silver pin.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t8845pv%20-%20english.ashx
Posted on Aug 10, 2010
SOURCE: Set up Intermatic outdoor timer 7day/7event
I have misplaced and forgot how to set a Model HB65R timer, can you help, thanks, Murray
Posted on Dec 24, 2010
Intermatic R8806P101C timer hesitates when turned on manually
1) Copy following link for troubleshoot:
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timers.html
http://waterheatertimer.org/How-to-replace-Intermatic-clock-motor.html
2) Blow out timer with compressed air.
Turn power off and spray highly flammable WD 40 vapor onto gears
Buy new 240volt WG733 clock motor, and timer will be good as new:
3) Add comment dec 2012 and say what you discover
Dec 14, 2012 | Intermatic Hardware & Accessories
Clock on T1905 timer switch has quit working. Fixable, or need a replacement?
120Volt T1905 Intermatic timer uses WG730 clock motor and 156T1950A tripper.
Timer will last many year by replacing parts, and keeping lubricated with touch of white grease, and not over-amping the 20 amp contacts
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
http://waterheatertimer.org/How-to-wire-T1906-Intermatic-timer.html
This timer can be converted into 208-277Volt timer by installing WG733 clock motor instead of 120Volt WG730.
Nov 13, 2012 | Intermatic Timer T1905 24 Hour Dial 120V...
My t104p turns on/of every 15 minutes. works fine manually but will not work with trippers.
Problem is not clear.
What is turning on-off every 15 minutes? The clock motor? Or the Load controlled by the timer?
If the dial is not rotating and keeping good time, then replace Intermatic T104 240Volt WG1573 clock motor
If the Load is turning on-off every 15 minutes, then that sounds like possible electrical short and not the timer, but more information is needed. Add a comment.
Open following link for troubleshoot checklist:
Add a comment for more help.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 07, 2011 | Hardware & Accessories
I installed a new Intermatic 200w powerpack with 15 malibu lights using 131 watts. The lights turn on manually, but the timer doesn't work. How is this possible.
More information is needed.
Open following link for Intermatic-Malibu resources:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
You say clock doesn't work.
Add a comment with following information:
Do you have timer with analog dial?
Does dial rotate as time passes?
Does dial keep good time?
Have you put the black and red trippers in place?
Are trippers push all the way down?
Have you set current time by rotating clock dial 2 full turns before rotating dial to current time?
Intermatic/Malibu ML series timers come with 5-year warranty.
Product is covered by warranty.
Upvote the help.
Jun 01, 2011 | Malibu ML200RT - Low Voltage Power Pack...
I have two 220 Intermatic time clocks in a raintight box operating a pool pump and a sweep (cleaning) pump for my pool. The clock motor quit operating--it is an Intermatic WG1573 5 60Hz 3W. The front of...
1) Order 240V T100 series clock motor.
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
http://www.amazon.com/Intermatic-Clock-Motor-Leads-WG433-20D/dp/B0031DOHLG
2) Order extra trippers too since they are designed to wear down so they don't damage tripper lever.
Put dab of white (bicycle) grease on the tripper lever.
3) Turn power off.
Mechanism snaps out using thumb-spring located inside box at top.
Clock motor is held with two star-screws. Buy bit at auto parts store.
Clock motor wires attach to terminals 1 and 3
Reattach terminal screws very tight against copper wire and make sure wire-insulation is not caught under screw clamp.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
To re-set current time, lift and rotate dial until current time lines up with silver pointer.
4) See next generation of Intermatic pool timers that snap into same box.
New timer controls 3 separate circuits with different schedules for each circuit, so the single timer can replace both mechanical timers. Wiring is complicated, programming is complicated. I am still reading the manual, and it makes sense to me, so you can trust fixya to help in event that you replace your timers next ten years.
http://www.amazon.com/dp/B001DSEC7A/ref=asc_df_B001DSEC7A1417045?smid=ATVPDKIKX0DER&tag=dealt581-20&linkCode=asn&creative=395093&creativeASIN=B001DSEC7A
5) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Feb 04, 2011 | Intermatic T10404R - Two 220 time clocks...
The dial on the intermatic water heater timer is not rotating on it's own and is easy to turn in either direction-without pulling it out and setting the time. The unit is only 1 year old..Can I replace the...
You can replace clock motor on many Intermatic timers:
Snap mechanism loose using metal spring top inside box.
Tip mechanism out and get clock motor number off motor.
Google search specific clock motor number.
Aplus sells many clock motor:
http://www.aplussupply.com/intermatic/timermotors.htm
Electric supply online sells clock motors
http://www.electricsupplyonline.com/prod/intermatic-motors.php
Grainger carries inexpensive clock motors for T101, T103, T104 timers.
T101 and T103 use 125v motor
http://www.grainger.com/Grainger/INTERMATIC-Time-Clock-Motor-1PNK1?Pid=search
T104 uses 240v motor
http://www.grainger.com/Grainger/INTERMATIC-Time-Clock-Motor-1PNK2?Pid=search
Dec 01, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
The clock does not move forward. If I manually turn it, then it will work and turn on the system where the pins are. I haven't tried anything to fix it because I don't know where to start. Intermactic...
Sprinkler and irrigation timers are 14 day.
Intermatic has a page with manuals:
Open page, click plus next to timers and scroll down to sprinkler and irrigation timers
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
It's good to have the manual on hand in case the product is discontinued
That being said, it sounds like the clock motor is bad.
Snap timer free from box and tip out to see clock motor located on back of timer.
Get the number off clock motor
Intermatic site shows pages of clock motors: They are priced high, but cheaper than new timer.
https://www.intermaticstore.com/ASPI700W.pgm?task=menucntrl&menuopt=TM
Aplus supply sells assortment of Intermatic clock motors.
To search these pages quickly for your clock numbers, use browser Find (Click edit at top of bowser, click Find)
Nov 08, 2010 | Intermatic R8806P101C -...
Timer is working but stops but stops at the on and off points like it don't have enough power to engage switch, timer is less then year old.
The pins push the lever.
New T-104 comes with a bit of white grease on the lever.
The lever is connected to the manual override.
Click the manual override back and forth. It should click firm and crisp.
If the manual override is sluggish or it sticks, then timer might be bad ... buy a new T-104 and snap the new insides into the box without changing out the box ... and if you bought it at the local store, then return the new timer with the old insides.
If the manual override works crisp and clean, then the clock motor may be bad.
Clock motors and Intermatic timers run for years, but the clock gears are plastic.
You can buy a T-100 series 240Volt clock motor at WW Grainger for $16
I think you need a small star screwdriver to change clock motor
Finally, the main dial gears are steel. If timer is exposed to moisture and dirt, the gears can get rusty and that might cause dial to stall. Snap out the insides and clean out the dirt, spray a bit of WD-40. Turn off electricity because WD-40 is extremely flammable.
Up-vote if this information helped. Thanks for the feed back.
Oct 14, 2010 | Intermatic T104R 208-277Volt 40-amp Timer...
Once T101 Timer Shuts Off will not turn back on
you have the hot and load reversed. the power source should connect to terminal 1. the wire going on to the pool pump should be hooked to terminal 2.
the clock motor is powered off terminal 1 and A is the neutral.
what u have done is hooked the power source to #2 and the load to #1, simply switch them and everything should be fine, here is a link to the wiring diagram for the timer.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t101%20-%20english.ashx
Aug 22, 2009 | Intermatic T101 - 24 Hr. Dial Time Switch...
Hardware & Accessories Logo
142 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
