Question about Linksys Wireless-G WMP54G 802.11g/b
I have comcast cable and internet but my cords wont reach to where my computer is, I also have a wireless linksys adater on my hard drive. Am I able to connect to my comcast modem with this?
Wireless-G 2.4 GHZ
    President:
  • 623 Answers
That depends on what comcast modem you have. If it has an integrated router, yes. If it is just a modem not. Simply spoken, a modem just converts your computer's digital signal to whatever is on the other side, usually analog. It doesn't do what a router does - routing the signal.
Just reply to this post and let me know what model of modem you have and I can give you a definite answer.
Posted on Jan 07, 2013
ckdestroyer
  • 60 Answers
SOURCE: Linksys Wireless-N pci adapter model wmp300n
If it says local or unidentified network that means you are just connected to the router on the network but not through the internet. Try to go to manage wireless network, remover your network there and add it again, connect to your own network and make sure to type the correct network key., then check again. You can also try connecting to other wireless network to further isolate the problem.
Posted on Aug 24, 2008
Joed911
  • 4338 Answers
SOURCE: Linksys wireless adapter not being recognized by 2wire wireless
1. uninstall the WLAN monitor from add/remove programs.
2. restart computer. it should say "found new hardware" (for the WMP54GS)
3. insert the installation CD for the WMP54G, but make sure that you do not install the WLAN monitor. just install the drivers for the card.
Then let windows control the wireless.
Posted on Dec 13, 2008
SeanTech
  • 33 Answers
SOURCE: Adding a computer to wireless at home
1) Go to the computer that is connected directly to the Linksys router.
2) Open up Internet Explorer (or your favorite browser).
3) In the address bar, where it says "http://www...." clear out everything in there and type in the following numbers:
192.168.1.1
Press "enter" on your keyboard. This will open up a dialog box asking for your username and password. Try leaving the username blank, and type in "admin" for the password.
Now you're in a web page that controls your router. Look for the Wireless section, and make sure wireless is enabled. Check for wireless security as well, because you may need to enter a long number in your computer once it finds the router.
If you still need more help, feel free to ask.
Posted on Jan 09, 2009
fslahmed
  • 127 Answers
SOURCE: Linksys WMP45G will not connect to wireless modem
well!! I have an answer for you.your comp is loosing the IP address.
goto start - programmes - accessories - dos prompt.
type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it.
goto network and sharing center,click on view status,goto propertiesand double click on internet protocol(tcp/ip) or IPv4.type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2.
ypur connection won`t drop after this.
Posted on Jun 09, 2009
professio101
  • 158 Answers
SOURCE: My Wireless-G Notebook Adapter will not connect to the Internet
If you go to the control panel in the start menu, check the network connections. It may be a LAN connection or another wireless connection that is not connected. You can disable them by right clicking on them. If you are able to get on the internet then you are ok. Let me know. Please give good rating...
Posted on Aug 27, 2009
I'm trying to hook up a second computer in my son's room. Problem - how do I connect the second computer to my Comcast cable router which is a Motorola SB5100 so he can get internet over the cable?
In the picture, it looks like a wireless router. In that case, his computer just needs a wireless card to get the internet. Or, you can hard wire it directly from the modem to the computer, if you don't have a wireless card for the computer.
Mar 12, 2010 | Linksys Wireless-G Broadband Router
Wireless router isn't getting internet connection
I am running DSL, but I am sure the method would be the same. The BNC connection (cable) should first enter the cable modem, then ethernet from the modem to the wireless router.
Jun 12, 2009 | Linksys Wireless-G Broadband Router
Unable to get wireless connection at a new location
Hi...
Verizon uses PPOE(point to point protocol over ethernet) and Comast does not use PPOE. Therefore she needs to get inside the router 168.192.1.1(user:admin & pdw: admin) to disable the "PPOE". Oh and also, the router needs to be hard wired to the computer for reconfiguration to take place...hope this helps
May 18, 2009 | Linksys Wireless-G WRT54G Router
Linksys wrt160N router inconsistant internet connection
Check on your cables makes sure they are inserted properly and the cord should be free of kinks, scrapes or loose connections......Also check the back of your computer make sure your ethernet card (the one that has the green lights/LED's) is seated properly (not loose)....
Good Luck.....hope this helps...if not let us know....cheers
Apr 13, 2009 | Linksys WRT160N Wireless Router
No Active Internet Connection
If you want to use the wireless portion of your router, you would need a wireless adapter installed on your desktop. If you are getting internet on your desktop then this means that your wired connection is fine to the router is fine. The WMP54G adapter will work with your router, however if you are not planning on connecting to the internet wirelessly through the router then there is no need to purchase the adapter. Hope that this helps you out.
Serge C.
Mar 30, 2009 | Linksys Wireless-G WRT54G Router
Lost internet
The usb stick is replacing the job of the card in the pc so it could be faulty, but first reinstall the latest driver for it and give it another try - what version of windowns/linux to do run? What make is the card - (look in Device Manager)? Then I can help further if needed.
Thanks
Jul 05, 2008 | HP Pavilion dv6000z Notebook
Became new customer to comcast-got the bundle package, internet,phone,cable. Voice overlay modem to accomodate internet and phone lines. Did not use their wireless router-using exsiting router D-Link model...
Hi jad123,
I am sorry to learn about the problems you are experiencing with your service.
I will be happy to reach out to my contacts to assist you in resolving this issue. Please feel free to contact me so that I can get more information from you.
Thanks in advance!
Mark C.
Comcast Executive Offices
We_Can_Help@cable.comcast.com
Apr 10, 2008 | Computers & Internet
Linksys Wireless-G WMP54G 802.11g/b Logo
60 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
