Question about Maytag Ovens
Maytag gas oven model number crg9800bae
Mauel model number crg9800bae
2 Suggested Answers
  • 2122 Answers
SOURCE: I have a Maytag Oven
are you saying that when you set it to bake the oven doesn't heat or are you talking about the top burners?if it's the oven you have a bad ignitor, the oven flame should lite in under 40 seconds to a minute,if it doesn't it's the ignitor,part number 12400035 and it's around 80 bucks.unplug it or kill the braker,take out the racks,remove the bottom panel or oven floor,take off the wing nut and remove the metal cover and you'll see the burner tube and the ignitor,,with a wet paper towel wet the screw threds on the two screws with water so they don't strip out and then remove the two screws holding the ignitor on,trust me it works.if you have to, unplug the ignitor or if it's not the original ignitor cut the two wires at the end of the old ignitor and connect the new ignitor with the ceramic wire caps and remove the burner tube if it's hard to get at the ignitor screws.put it back together and the ignitor should lite the flame in less than a minute.let me know how you make out
Posted on Aug 22, 2010
Please help find oven mauel
open oven doors and check behind the bottom of the doors for mod number
Nov 21, 2013 | Ovens
I have a maytag gemini mgr6772bd and the broiler in upper oven will not come on. I suspect it may be the igniter? If so, what is the part #, location to purchase and ease of replacement. Thank you. Mike
http://www.searspartsdirect.com/partsdirect/part-number/Maytag-Parts/Range-Parts/74007966/0022/464/Model-MGR6772BDB/3048/0124002?keySuffixId=NA&productTypeId=0124002&searchModelNumber=MGR6772BDB&subCompDesc=Gas%20controls&brandDesc=MAYTAG&modelDesc=MAYTAG-COOKING&blt=11 this is the link to the Sear Parts Direct web site for that broiler igniter.
Sears isn't usually the cheapest but they use the REAL PART NUMBER so you can do a search using that part number for a cheaper price.
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Range-Parts/Model-MGR6772BDB/3048/0124002/M0604022/00004?blt=06&prst=&shdMod= This link will show you what you are looking for.
They are not that hard to replace, BUT REMEMBER TO TURN THE GAS VALVE OFF FIRST. You will need a few small wrenches and some patience - along with some bengay since you will be acting like a controtionist.
Jul 13, 2011 | Ovens
Bad ignitor? I have a Maytag oven CRG9800BAE displaying F7. No oven heat. Stovetop burners work fine. Got the code cleared, clock is working fine. Is this a bad ignitor? If so, could you confirm the...
Thanks for choosing FixYa and welcome. If you have a electric oven or a gas oven that won't heat or doesn't heat properly, here are some things you will need to check. The most likely cause of a oven not heating correctly is a defetive heating element. You have two types of heating elements in your oven. The bottom element(s) are the baking elements. The element(s) on the top are the broil elements. If you don't see the bright red glow from the element, chances are they are not working or not working correctly. If a heating element is bad, you need to replace the entire element. If your oven is warm and not correctly hot, one of the elements may be bad. In most ovens, when you preheat, both elements are used. This would make the oven to appear like it is working correctly but it is not. If the elements are not working, they might not be getting power. Test the wires to the elements with a voltage meter to make sure they are getting power before you decide to change them out. Many electrical ovens have a sensor that monitors the oven temperture. Ovens that have this sensor usually contain a digital display on the oven. The sensor could be defective. Those without the sensor use the basic mechanical system to control the oven temperature. You also want to check the thermostat sensing bulb. Make sure the bulb is good and has not come loose. Now, if you have a gas range oven that doesn't heat properly, first, you want to check your bake igniter. It may have burned out or it could be not working properly. It will be located near your burner. It is also possible that you are not getting gas to the burner. If so, it may be the gas safety valve or the igniter. You need to check your selector switch and thermostat as well. They may be defective. Always make sure you test the parts for power with a voltage meter of some type before you decide to change the part. If you have a part that appears to not be working, it may not be getting power because of a bad wire or broken connection.
May 12, 2011 | Maytag Ovens
I have a Maytag Oven Model CRG9800BAE Will not ignite gas when turned on.
Aug 22, 2010 | Ovens
Oven takes forever to preheat
check to see if both broil and bake elements/gas works
May 25, 2010 | Maytag CWG3100A Gas Single Oven
Maytag gas oven wont restart after pre heat
you have a bad oven sensor /faulty connection or bad control board.look for probe coming thru inside rear wall.should read 11k ohms cold.go bad a lot part number Hope this helps ,please rate my response :)
12001655
Jun 25, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
Maytag gas oven takes long time to heat, sometimes not at all
sounds like a bad oven ignitor, part number 12400035 comes with all instructions on how to install
Dec 06, 2008 | Maytag CWG3100A Gas Single Oven
Free owners manual
hi there,
go to www.whirlpool.com
then scroll down to the bottom right and you'll see customer support and then manuals & literature.
click on that and then type in your model #.
all the manuals are in .pdf, so make sure that you have Acrobat Reader.
May 20, 2008 | Maytag CWG3100A Gas Single Oven
Oven will not work
I had same problem, My solution was to turn off the breaker switch off (disconnect the power) I kept it off for 1 minute turned it back on and it now flames.
Sep 08, 2007 | Maytag CWG3100A Gas Single Oven
Maytag oven will not light
Have you tried to broil or bake? if only one of them work you have a bad ignitor. let me know and we can go deeper
Aug 23, 2007 | Maytag CWG3100A Gas Single Oven
Ovens Logo
20 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
