Question about Kenmore Washing Machines
Kenmore washer model # 11028732700 - won't spin (will drain water) makes buzzing noise instead of spinning- what needs fixing? Can't find drive belts on parts listing for that model.
I want to try to fix it myself, but need to know part needed and where to find it on washer.
Jimster
  • 240 Answers
SOURCE: How can I open back panel on Kenmore Ultra Fabric Washer
On this design, the front would be the area you would need to remove. Start by unplugging the machine. On the console, you will see 2 screws on either side of the front of the console. Remove these 2 screws with a phillips screwdriver. After you do this, grasp the console on either side, gently pull the front bottom out, then when it releases, flip the console up, and swing it back over the rear of the unit. On either side of the top, you will see a gold latch. Put a regular screwdriver in the groove along the front of these latches, down in the hole in the top, and pop it out. Do this to the other side as well. Grab the cabinet, and gently swing the top back towards you until the bottom slides out. Then set the cabinet aside. On this model, there are no belts. The drive system is made up of a motor, a drive coupler, and transmission. The drive coupler is between the transmission and motor. Sounds like you may have a problem with the basket drive system, which is located between the transmission and outer tub. This can be replaced, but will take a special spanner nut wrench to remove the inner basket and drive block. Let me know if this helps you out some or need me to break it down a little more for you. Good Luck!!! Jimster
Posted on Sep 05, 2007
  • 132 Answers
SOURCE: top load washer machine will not agitate
Hi There,
Check to see that the belt is being driven by the motor when it goes into the wash cycle. Let me know if this helps and thank you for using FixYa!
Posted on Mar 30, 2009
  • 68 Answers
SOURCE: Kenmore Washer: Noisy Spin Cycle
if this sound is similar to a jet engine then it may be best to get a quote from your local repair man to see if repairing the unit will be worth it. there are a lot of steps in fixing this problem and you may be able to do this yourself but it is pretty difficult.
sound like you need a new rear bearing and a spin support shaft
Posted on May 01, 2009
  • 32 Answers
SOURCE: Kenmore front loading washer won't drain or aggitate, just buzzes
take the front bottom panel off. inside there is a drain pump. you need to remove filter from drain pump its look like a knob. be careful because their is water inside your drain pump so use some big thing for water. clean your filter. put filter back tight. i hope will solve your problem.
Posted on May 24, 2009
  • 153 Answers
SOURCE: there is power to the washer, water will drain
Try unplugging machine for 30 seconds then plug back in then lift and close the lid 5 times which will reset the motor. Try the spin cycle if it works you may have had a power surge which took the motor out and just needed reset. If it fails you may have a bad inline fuse or motor.
Posted on Feb 28, 2010
Kenmore washer Model 110, Serial No. 27602690 won't spin
If wash cycle operates and water drains as should before spin indicates motor spinning. Chances are bad timer If your a real fixer you can remove timer control from panel check and clean all contacts internally making sure none are stuck closed . (Have had 3 110s in my time).not easy but can be done or buy new about 150$ reassemble and check operation.
Mar 28, 2013 | GE WBSR3140DW Top Load Washer
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
Kenmore 90 plus series washer won't spin, barely agitates, will drain - but makes loud noise
It sounds like the transmission is done. Can't pinpoint what it is exactly, but I would start there.
Aug 21, 2012 | Kenmore Washing Machines
Kenmore 80 didn't drain during the spin cycle and leak underneath machine. Makes buzzing noise in the wash cycles.
The pump is likely damaged if it was leaking. Look for a ring of melted plastic on the face side of the pump. Check to make sure the hole is not rounded where the motor shaft enters the pump.
I'd replace the pump just to make sure the washer doesn't flood some time in the future even if the pump turn out to be ok now.
Vlad,
First Choice Appliance Service. Sacramento, CA
Jul 05, 2012 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore washer doesn't drain
This is likely a pressure switch issue.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 27, 2009 | Kenmore Washing Machines
Top load washer machine will not agitate
Hi There,
Mar 10, 2009 | Kenmore 24902 Top Load Washer
Kenmore model 22432100 - it won't drain or spin
sounds to me that something is stuck in your pump check the pump if you open the pump have lots of towels on hand the machine will not spin if it does not drain
Dec 29, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
18 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
