Question about iBuyPower Gamer Supreme WA944SLC Desktop PC with Intel Core i7 950 Processor, Windows 7 Home Premium (811121014049)
ReBoot Problems When my computer reboots it seem to say that it can't find my hard drive but it works if I unplug it and plug it back in.So if you can help please tell me. Thanks
    Scholar:
  • 58 Answers
Hard drive failure can be cause of computer is bumped or jostled while it is running;the electric motor which allows the platter to spin fails due to bad bearings or other components;filter on your air intake gets too clogged or the filter isn't working properly;Extreme heat while running causes the electronic circuit board to fail;There is a sudden power failure while the disk is writing. If your computer got one of the issues above, you can fix it by the following steps:
Firstly, create a bootable CD/USB to be a tool for fixing ntldr is missing.
Secondly, set the computer boot from CD/USB after enter into the BIOS menu.
Thirdly, Fix it with the CD/USB created at the first step.
You can also use some software to deal with the problem, like Windows Boot Genius, Throttle...
Posted on Jan 07, 2013
I have a emachine unplugged it plugged it back in now its telling me to reboot and I can't get my computer to work how can I reboot without disk?
It sounds like your hard drive is not being recognized. I hope you didn't unplug it while it was still turned on as that can cause hard drive corruption. The hard drive or some other critical component may be failing, or just the OS or hard drive corrupted. If you have files that you do not want to lose, you could try this... Pull the hard drive out, and use a "USB Hard Drive Adapter" (available fairly cheap online) to connect the hard drive to a friend's computer, and save all the personal files (documents, pictures, etc.) you can to a folder on the friend's computer or an external hard drive.
Then, you could try to do a Factory Restore on the computer, and if that works, copy your personal files back to your newly restored computer.
Good Luck
Jun 23, 2014 | Computers & Internet
Tip
External Hard Drives
Most problems involving "external hard drives" have 1 thing in common: "Machine won't recognize the hardware". This has been an issue ever since they were introduced to the market. In most cases, this involves a hardware conflict amongst USB devices. To verify if this is the case:<br /> <ol> <li>Unplug all USB devices</li> <li>Reboot the computer</li> <li>Plug in the external hard drive</li></ol>The hard drive should now be detected. Once detected, you may now plug your other USB devices back in. <br /><br /><br />
on Mar 19, 2011 | Computers & Internet
Computer Won't Let Me Past Disc Check?
if you have any external devices plugged in such as mice or hard drive or usb unplug them and then try to reboot. check online for the brand name of your computer for "safe Mode" typically its hitting the F buttons or the delete button and going into safe mode then if it will save the file you really need. then try to reboot
Nov 12, 2017 | Dell Computers & Internet
Can not boot up computer
possible your hard drive
A hard disk failure can be catastrophic if it jeopardizes the data stored on your computer.
In addition to rendering a laptop inoperable, a failed hard disk can damage other files stored on the drive as well.
It is critical to determine whether an actual drive failure has taken place, and there are several steps to troubleshoot a drive before hard disk failure can be declared.
Unplug any devices such as printers, speakers, cameras and other external peripherals. Boot the laptop by pressing the power key.
If this does not result in a successful boot, try booting Windows in "Safe Mode."
Reboot the computer, and hold down the F8 key this will vary depending on your computer and operating system
From the menu choices, choose "Boot Windows in Safe Mode".
If the boot up progresses, then the computer is likely experiencing a software issue, not a hard drive failure.
Reset the hard drive.
This will involve turning off laptop (removing the battery is a good move, too) opening the laptop unit, and unplugging all connections and cables from the hard drive.
If possible, replace the hard drive with another drive.
This will help determine if the hard drive is causing the problem.
Plug all connections back in to the hard drive, and reboot the computer.
Repeat Step 2 if necessary.
If the computer does not reboot, the laptop is more than likely experiencing a hard drive failure and will probably have to be repaired by vendor.
hope this helps
Oct 09, 2012 | mpc X3000 Laptop Transport 14.1" Barebone
Media test failure message. Reboot and Select proper boot device
hope this helps
How to reboot computer
hi
  • Decide what kind of reboot you are going to do. A soft reboot is performed the way you are “supposed” to do it. For a soft Windows reboot, go to the Start menu and select “Shut Down” or “Restart.” The computer will then shut itself down. Clicking “Restart” makes it boot up without further intervention from you.
  • Step 2 Perform a hard reboot by pushing the computer’s power button and holding it until the computer shuts down. Wait 45 seconds and restart the computer by pushing the power button again. You may have to start up in safe mode, but that also allows you the chance to restart properly or work on programs in a safer way. This method may cause you to lose data or mess up the operation of some of your programs. But it may be the only option if your computer's hard drive is frozen.
  • Step 3 Power down all of the computer's components. Shut off all of the peripherals you have attached to your computer, and disconnect the cables. Then, plug all of the peripherals back in, and restart your computer. This can often solve problems with your hard drive.
  • Step 4 Purchase and install a program such as Drive Reboot Restore PC 6.0 that streamlines the hard drive reboot process. These applications help prevent the problems that can develop after repeated computer use. They also ensure that your hard drive maintains the configuration you want each time you turn it on.
  • Step 5 Investigate what the problem may be with your hard drive. Because of its delicate nature, your hard drive can very easily be thrown off.
  • Jul 04, 2010 | Compaq Pavilion ZT3280US Notebook
    My hard drive got unplugged without being stopped and now keeps running into read errors
    Hopefully, the read errors are not from physical damage.
    These are the steps that you need to take, and the instructions on how to do it:
    1. Reboot into Safemode
    2. Run a virus and spyware scanner
    3. Defrag
    4. Scandisk
    5. Registry error repairing
    6.Reboot into regular mode windows
    Here is how to do it:
    Reboot yor machine while holding the F8 key right as it boots back up. A menu will apear. Choose -->"start windows in safe mode with networking".
    Windows will start in safe mode. Run an AVG virus scan, then run Defrag by exploring your computer, right click on C: drive, click PROPERTIES, then the TOOLS tab, click the "check now" button, and both checkboxes,both 'fix file system errors', and "scan for and attempt recovery of bad sectors" then click ok, the computer will then tell you it will scan upon next reboot (which upon reboot will take about an hour). Now click the DEFRAG NOW button. then choose defrag. After Defrag runs for about an hour and it is finished, restart the system. If is still won't run normally, go back into Safemode buy pressing F8 on reboot, then run a registry fixing program such as uniblue registrybooster, then reboot again. If it still won't run right, you may want to format the hard drive and reinstall Windows and see if that works. If reinstalling windows doesn't fix it, it is definitely a hardware problem.
    PRINT THESE INSTRUCTIONS AND KEEP A COPY NEAR YOUR SYSTEM FOR FUTURE PROBLEMS. THIS SERIES OF STEPS CAN FIX MANY PROBLEMS
    Good luck.
    James.
    ------PLEASE RATE THIS ADVICE WITH 4 THUMBS UP!!!-----
    Apr 26, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
    Keyboard not working after being unplugged & used on another comp
    Close down computer and reboot and pray. I mean to close down not reboot, not hibernate, not sleep.
    Why? The electronic chips chatter before the operating system boots up. BIOS asks who is here? Any Keyboard, and other internal bits.
    For readers... Cold rebooting fixes a multitude of problems with not working. OK, it does not fix everything, but it is a good first try
    Sep 08, 2017 | Dell Computers & Internet
    Western Digital hard drive problem
    Ok.  I have a WD 500 and I have ran into similar problems.  First, shut your computer down.  Unplug the hard drives USB cable and the power cable.  Wait for about 2 minutes.  Plug the USB cable into the computer, plug the power cord in...wait for 30-45 seconds and then start your computer.  That hopefully should solve your issues.
    Mar 01, 2009 | Western Digital My Book Essential Edition...
    iBuyPower Gamer Supreme WA944SLC Desktop PC with Intel Core i7 950 Processor, Windows 7 Home Premium (811121014049) Logo
    59 people viewed this question
    Top iBuyPower Computers & Internet Experts
    NOEL
    NOEL
    Yagon
    Level 1 Expert
    Robin Hill
    Robin Hill
    Are you an iBuyPower Computer and Internet Expert? Answer questions, earn points and help others
