Question about Stiebel Eltron TEMPRA 24 Tankless Water Heater
How to wire tempra 24 plus
2 power lines into unit, ( from left to right looking at it from the front ) frist line, ground, then black, then white ? then the next line ground ( to same as frist ) ground,black,white ?
  • Stiebel Eltron Master
  • 5,245 Answers
1) Copy following link for wiring tankless electric water heater:
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
2) Look at label on side of unit for total KW
3) Product manual shows 24 Kw or 24,000 watts
24,000 watts divided by 240 volts = 100 amps
So your service panel must be about 250Amp rating to support this tankless electric water heater.
http://waterheatertimer.org/pdf/Tempra_tempra-plus-Tankless-electric-water-heater-manual.pdf
4) Look inside the unit to see how many L1L2 terminals show.
You should have two sets L1L2 terminals
http://waterheatertimer.org/images/Terminals-2-tankless-200.jpg
5) You need TWO 60 amp double pole breakers to supply power to this unit.
This means you need TWO #6 wires from one breaker going to L1L2.
And you need TWO MORE #6 wires from 2nd breaker to other set of L1L2 terminals.
6) Add comment for more help Jan 2013
Posted on Jan 07, 2013
0 when i check it i only get 120 on both when i ground then in 0 when i check the white to black is this right the make is a ge 19.9 hot water heater
You did not post the make and model of the unit. However you should have three wires on a 120 volt heater. Black is HOT. White is neutral and green or bare copper is ground. Anything that you check with a meter connected to black should show 120. white connected to ground across the meter would show 0.
Mar 03, 2017 | Water Water Heaters
Tempra 24 installation. No hot water. No power led on fron cover. Is the led supposed to be on all the time or just when water is ran?
First, check the circuit breaker. Also, did you upgrade to heavier wiring and a double 60 circuit breaker when you had this installed?
Aug 15, 2014 | Stiebel Eltron TEMPRA 24 Tankless Water...
I have a tempra 24 plus and i have no pressure.
Check power make sure you have enough going to it as well as make sure the filter in it isn't plugged up.
Dec 03, 2013 | Stiebel Eltron TEMPRA 24 Tankless Water...
We purchased a new electric hot water heater we installed it on a 220 line and we are not getting no hot water
check with a vom set on high voltage setting. for power... black wire to black wire,, white wire to red wire on heater ground wire to tank ..on 220v there is no neutral like on 110volts..check red reset button under top panel / control push on it resets it,,,
Apr 17, 2011 | Whirlpool Water Heaters
PowerStar AE9.5 isn't working. Bought new. Water lines are hooked up to the correct water lines. The 240V wire coming from the breaker is hooked up as follows: Uncovered copper wire connected to ground,...
The unit will not owrk unless you have 240V ACROSS the black and white wires...if you do not have that coming to the unit then you have a bad breaker...
heatman101
Feb 19, 2011 | Bosch PowerStar AE9.5 AE9.5 Point-of-Use...
Had hot water this morning, then a leak in public water lines about block away, caused pressure drop. No hot water. Shut breaker off, and found 2 safety thermal shut-offs (couldn't tell if they had been...
It is possible that when pressure dropped from city supply that it created syphon and sucked water from your heater back into city lines. This could have caused unit to burn out heating element. I don't know if your unit has any backflow prevention to prevent this from happening.If you can I would suggest that you check incoming power to your heater. It should be around 240 volts. I also would check reset or limit switches again. Hope this helps. Thanks
Nov 06, 2010 | Stiebel Eltron Electric Tankless Water...
Water heater electric
if its a 240 volt unit,then yes they are both 120 volts for each phase and the 240 volts for combined pair to each terminal on the units thermostats terminals,hope you have a white or green or both for a safety ground though just in case there;s plastic water lines between the supply and the unit
May 24, 2010 | RELIANCE ELECTRIC WATER HEATER
Installing new flomaster xp2 pump. what color wies
Are you asking about the cord from themotor to the control? If so It should either be Green Black and white or all those plus a red. The green is the ground and it goes on the green screw. White goes to the common or line(1) post, and usually red is Hi and Blk low for the speeds. If it is a single speed only no red and black will go to the other line(2).
If this does not answer your question please post a comment with what wires and where you are dealing with.
Dec 18, 2009 | Water Heaters
Where do I find the reset button on the Stiebel Eltron Tempra 15?
On the Tempra 29 there is a "safety thermal cut-out" on the top of each of the heating elements within the box. I have had to open it up before to push the breaker. They are a small red plastic push button on the top. Carefully press the braker button without touching the electrical wiring inside. I hope that works for you.
Sep 15, 2009 | Stiebel Eltron TEMPRA 24 Tankless Water...
Stiebel Eltron TEMPRA 24 Tankless Water Heater Logo
184 people viewed this question
Top Stiebel Eltron Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Stiebel Eltron Water Heater Expert? Answer questions, earn points and help others
