Question about Samsung RS2630SH Side by Side Refrigerator
Samsung model # rs2630sh side by side fridge. center strip is hot
Both the refrigerator and freezer door close against a metal strip. The metal strip is the entire lengh of the doors. That metal srip is very, very hot to the touch. Why? Should it be this way? What causes it? What is the solution if any?
2. The outside enclosure of the freezer compartment is also very hot to the touch. Same questions as above.
  • 3 more comments
  • cowboys88 Jan 22, 2009
    I too have the same problem. Usually there are door heaters behind the metal, but they should not get that hot. I posted a question "if there was possibly a limit switch or a t-stat (thermostat) in series with this heater?
  • tapaya Feb 03, 2009
    I also have the same problem. Also the borders of both doors are extremely hot. Water stopped circulating, no ice.
  • sdineen Feb 04, 2009
    I have the same thing. HOT HOT. I burned my hand. this is the worst refigerator I have ever owned by far. Anyone have the solution? Anyone want to try to sue these Samsung folks?
  • Anonymous Mar 28, 2014
    Door casing hot and metal stripe in the door frame is very hot.
    Door frame and doors rubber casing is hot
I had the same problem, and it was the condenser fan motor. I ordered mine from www.partstore.com. It was half the price of sears.
I would suggest ordering the 2 "plastic bushings" for front and back of motor. I was able to reuse mine, but for a few dollars more it's worth it.
Posted on Feb 04, 2009
  • 4 Answers
It seems that from my own problem, and what else I've determined surfing, that the problem is the result of the condenser coils and fan having issues. My coils were very dust covered and the Fan - dead. I have vacuumed, took the back plate off and have a house fan blowing across the back of the unit. I notice it's already a little cooler on the inside walls, although still somewhat hot (but not burning hot as was before). New fan motor, and blades are on order. Yes, two separate items. Why would Samsung make it easy?
    Oh, and if you think you can harvest the fan from the existing motor, make sure you try to do this FIRST before placing your order. Samsung has identified that the original "fan" part is discontinued, and my guess is because it breaks into little pieces when you try to gently remove it from the existing housing. Try it first, and hopefully you will have the newer less brittle fan. Otherwise, order up.
Post between freezer and refrigerator doors is hot
I have seen a programme on TV which showed a cable between the doors which over time with constant opening and closing became worn. I should contact the manufacturer.
Apr 21, 2012 | Samsung RS2630SH Side by Side Refrigerator
My samsung rs2630sh is very very hot to the touch
The fan you should replace is called the condenser fan. It's the one that blows air across the outside coils. When it fails, you'll usually notice abnormal heating of the front of the divider between freezer and fridge.
Oct 26, 2009 | Samsung RS2630SH Side by Side Refrigerator
CENTER METAL SURFACE THAT DOOR SEALS TOUCH WILL BURN YOUR SKIN
go to partstore buy the part # DA97-01949A and fix it you can put the fan in back refrigerator keep it cool when the part come and fix it
May 11, 2009 | Samsung RS2630SH Side by Side Refrigerator
Both Freezer door and cooling door and a metal strip were hot
That is a good thing. you want that to happen what it does is it avoids condensation to form around the doors
Apr 26, 2009 | Samsung RS2630SH Side by Side Refrigerator
Both Freezer door and a metl strip were hot
There is a sweat control heater around the front edge of the fridge and freezer. It has a switch that will turn it off, usually by the other controls. It just wastes electricity.
Apr 23, 2009 | Samsung RS2630SH Side by Side Refrigerator
Kenmore 596.50692000 refrigerator. Every time I shut the refrigerator door, the freezer door pop open. What can I do? Do I need to replace the magnetic strip around the door? Who can give me instructions?...
Replace a door gasket on a refrigerator....
Replace a door gasket on a refrigerator: The first thing to do when changing a door gasket is to check and see if you have the proper part before taking the old gasket off. Hold the new gasket up to the fridge door to make sure the gasket is the same size as the old one. Next step is to remove the wrinkles in the gasket caused by folding for shipping. Instructions with the gaskets say to soak the gasket in hot water. Another way is to use a hair dryer to heat the gasket and remove the wrinkles. Be careful not to burn the gasket with the hair dryer. Almost all gaskets in use today are magnetic. I am placing instructions here for the most common one. They have strips of magnetized material inside the gasket material to adhere to the cabinet when the door is closed. Therefore there is sometimes no up or down on the gasket. Some fridge's have magnets on only 3 sides and the side without a magnet is the hinge side gasket. But to be safe, check this before installing. You will certainly want to check for this on older refrigerators that have magnetic door latches. Some of these have no magnets on the latch side of the gasket. There are about three different ways of attaching gaskets. All will be addressed on this page. Remove the food from the shelves on the door. Loosen the screws that hold the metal strips that keep gasket in place on the top half of the door. Back the screws out about 1/4 inch. The gasket has a lip on it that seats in a groove under the top part of the metal strip. Pull the old gasket off. Work the groove on back side of the new gasket under the cutout in the metal strips that holds it on the door liner. Straighten and get good install before tightening screws. Run screws back up against the metal holding strip snugly, not fully tight. Go to the bottom and do the bottom half. By doing the top half first and tightening, then doing the bottom half, you will minimize any warping of the door. If there is warping of the door, we have not yet fully tightened the screws. so you can realign the door easily and then tighten the screws. Check the alignment of the door and be sure the gasket is sealing properly before fully tightening the screws. If the door is warped, (see picture) simply warp it back to a sealing position, then tighten the screws. There are instances where the gasket is too tight on the hinge side, and you may have to shim the door hinges out from the cabinet to keep the gasket from scrubbing when closing. .also use a little petroleum jelly on the gasket on the hinge side will allow the gasket to "settle" better. The hinge side must slide along the cabinet edge while the other 3 sides just close up against the cabinet. The jelly will allow the gasket to rub smoothly and also prevent squeaking noises. Maintenance of the gasket is important also. It should be cleaned on a regular basis. Clean the gasket and the mating cabinet surface with warm soapy water, rinse clean and dry it good. Putting a little baby powder on the sides (except the hinge side because we put the jelly there) will prevent the gasket from sticking and tearing. The heaters in the refrigerator used to keep moisture from forming on the cabinet attracts airborne materials and make the gasket sealing surfaces sticky. The powder will help stop this. Probably 75% of the fridge's made a few years ago use this edge under the metal track....some American made fridge's use the U shaped metal strip and the gasket pushes into the metal strip, (see a picture) the screws that hold this metal strip do not have to be removed or loosened. A lot of fridge's also use the metal strips with out the edge. Some Maytag's and Woods come to mind. The screws go through the metal strip and the gasket as well. The screws have to be removed completely to replace the gasket.
Gasket sheet to assist you in replacing a common door gasket.
Freezer door pops open when I shut the fresh food door:
This happens because the refrigerators of today are air tight, the fresh food door pushes the air into the cabinet as it closes and the air has no place to go but up the air vent into the freezer and "pops" open the freezer door. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly.
Let me know if this helps, Thanks, Sea Breeze
Mar 25, 2009 | Kenmore Refrigerators
Kenmore Frig-bottom freezer/freezer door pops open
I hope this helps, and if you need more information On solutions just let me know, Thanks Sea Breeze
Feb 06, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Front metal piece that the seal goes against - between freezer and fridge
ED5VHGXMQ10 Whirlpool Fridge
I have the same problem. Too hot to touch between the freezer and refrigerator door. Is
this normal?
Jul 07, 2008 | Whirlpool GS6NBEXR Side by Side...
Front between doors is VERY HOT
Had the same problem. I opened the "meat" lever controlling the "hole" between the freezer and fridge compartments (mine is next to the crisper trays at bottom) and put my finger in it to clear any blockage. It's been 24 hours and the center post is no longer hot. Think maybe I had a blockage or the hole was closed off and whatever is in that middle wall needs the cold air flow for cooling. If you discover some other remedy, please let me know.
Dec 29, 2007 | Samsung RS2630SH Side by Side Refrigerator
Samsung side by side center divider front extremely hot
That sounds like you may have something in your condenser fan motor.. piece of bag, paper and may have stopped your fan altogther.. that would be the first place to check.. right by your compressor in the back of frig.
Aug 21, 2007 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
603 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
