Question about Tools & Hardware - Others
Model number p2mpd14n08001 york furnace runs but will not start up
2 Suggested Answers
SOURCE: york diamond 80 fan starts running blowing cold
OK so you replaced the Thermostat huh? OK well then did you also replace the Thermistor Temperature Sensor? or whatever is used? As often it's BOTH, also check the wiring from the sensor to the host, in any event if it's NOT that then all it can be is the controller board, most likely the Micro? Check any and all sensors first though.. try to get a service manual too, it's hard without one?
Posted on Oct 20, 2011
The modal number and serial # for my furnace is MODEL # F+RPQ24HQ6A SERIAL # EEGS13264Q OUR FURNACE IS IN A METAL BOX AND WE CANT SEE THE BRAND NAME IS WE JUST BOUGHT THIS HOUSE BACK IN DECEMBER 2016
That's an older YORK product. The serial numbers are all coded by the alphabet. York or Luxaire parts house can help you. Probably about a 1980's unit. Hope this helps!
Mar 18, 2017 | Heating & Cooling
Where is the model number located on the York diamond 80 furnace
Behind access panel, or on left side of furnace on inner wall
Mar 17, 2016 | Heating & Cooling
Need a ignitor part number for York propane furnace model # p2udd20p13301c
Found it on repairclinic website:
Manufacturer Number S1-47320937001
Dec 09, 2014 | York Tools & Hardware - Others
York diamond 90 furnace burners won't ignite ... igniter glows for a few seconds then clicks off, no burner ignition. Tried resetting the furnace by powering off and then setting thermostat to call for...
The thermocouple could be defective. If this is a high efficiency York furnace, the stack blower should start and run first. If it doesn't the blower controller may have failed.
Dec 06, 2013 | Heating & Cooling
Furnace will run, put out heat, turn off and doesnt start again.
What is model # & serial # of this furnace, it may have a diagnosis led indicator light located on the control board, behind bottom door of furnace which will blink and tell you a fault code. Also check furnace filter, make sure its clean, check through out the house to see if all registers are open and not blocked by any objects, make sure cold air return grill is not blocked, the unit could be over heating and shutting off on high limit, good luck.
Feb 15, 2010 | York Furnace Draft Inducer Blower Fasco #...
York 92 % eff. furnace shuts down on # 3 error (pressure switch)
i have fixed almost every one of pc9 -----we have installed in our company,code three{flashes} at first new presure switches installed, same thing,york knows about this,induction motor bearings,could be bad.our local york dist, has boards,inducer, ***.motor, dual press.switch,free.as is known as the only way to fix.after all else is ruled out.one local competator called us if we wanted to join class action suit . good luck.furnaces work good at first, season or two then bam
Nov 28, 2009 | York Furnace Draft Inducer Blower Fasco #...
Loud noise when furnace starts but furnace won't come on.
Your fan delay relay has failed and must be replaced.
Jan 16, 2009 | York Yankees Bedding MLB Comforter
Tools & Hardware - Others Logo
55 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
