Question about Air Tools & Compressors
I need an operators manual for a Husky H15123TK Air Compressor
RCtech
  • 55 Answers
SOURCE: manual for husky air compressor ''easy to go''
For what it's worth Compressors are intended to be turned on and forgot (except for the noise). just for grins lets assume you have the stapler and air hose. you need to hook up the air hose to the compressor there usually is one or to either couplers or npt fittings (threaded). attach the hose to the compressor and using a quick coupler (prefered because it allows the gun to swivel) connect the gun to the hose. turn on the compressor and wait for it to build up pressure and *******. at this point you will need to locate the regulator on the compressor. it will be a knob next to one or two dial gages. crank the regulator a quarter turn either direction while watching the gages. It (one of them) moved either up or down . now you know how the regulator works and your almost a contractor. on to the stapler, load it and find a bit of scrap (what your working on would be best.) now shoot a staple into something and see if it goes in far enough or to far. adjust the regulator to compensate. do this until one of three things happens A you find the right staple depth B the compressor kicks on again, wait for it to turn off C you run out of nails, beer or intrest in the project. once you have found the correct pressure for your needs. you may fire at will you don't need to wait for the compressor to cycle while running the stapler just during set up. now your a contractor go have a beer.
just a last tip if you find you don't have the correct couplers home depot, harbor freight or amazon (online) are great sources for parts.
good luck and mind your fingers
Rob
Posted on Dec 10, 2008
  • 82 Answers
SOURCE: HUSKY PRO AIR COMPRESSOR 30 GAL I NEED TO KNOW HOW
Depends on what plan it was made in...
If you have the glass type sight... Only to the max you can see (top of site), then run it for a few mins, let it sit for a few more mins then add more if the level is near the bottom of the sight glass.
If it's the dipstick model that pushed in, there will be an upper and a lower level mark (holes, or checkered section) Keep it between the top and bottom marks.
Finally if it's the older screw-in type, remove the dipstick and wipe it. Set it back in BUT don't screw it in. Keep within the range on the dipstick from that position. Then of course screw it back in/
Good luck
Posted on May 08, 2009
digritz
  • 530 Answers
SOURCE: husky air compressor/1.5 hp
Compressors pull a lot of juice that is why they come with a large power cord. If you use a small extension cord with it it will easily pop a breaker. So first check all your breakers. Second thing is check your manual to see if you have a reset switch on you compressor, as most do. It should be a small, red switch (rocker or push button type), located between the pump motor and compressor switch. The third is a long shot, check to see if the bleeder valve is functioning correctly. It will be the small copper tube running from the pump to the switch. Just make sure the small lever is free to move.
If this fails to resolve the problem then it is probably the main switch itself. That is a warranty issue. If it's out of warranty then your going to have to either repair or replace the switch yourself. Please feel free to ask for help if you need it in latter case.
Posted on Jul 29, 2009
ollie reece
  • 1167 Answers
SOURCE: Belt Replacement on Husky Q26 Air Compressor
YOU HAVE TO TAKE COVER OFF LOSEN THE BOLTS ON THE MOTOR SO THE MOTOR SLIDES TO THE RIGHT SO THEN PUT THE BELT ON THEN GET A CAR JACK AND PUT BETWEEN MOTOR AND PUMP DO THE JACK UP TILL BELT GETS TIGHT AND TIGHTEN BOLTS UP ON MOTOR X4 GOOD LUCK
Posted on Aug 25, 2009
brewerstool
  • 141 Answers
SOURCE: how do i repair a broken air regulator on a husky portable air
You will have to repalce the air regulator. Campbell Hausfeld is the maker of the Husky air compressors. There should be a different model number on your compressor that you can use to locate the part number on the chpower.com website. The only problem that I have come into is that the parts are not available for these models on a long term basis, and they may not offer any repair parts at all. If you can not locate the part on the Campbell Hausfeld site call Home Depot and ask them where you can get the part.
Posted on Sep 09, 2009
What oil do I use for a G Force 2 HP air compressor, model 50622
  • www.air-compressor-guide.com/.../air-compressor-oil Keep your compressor in top condition by using the right air compressor oil. Make your compressor run nice and smooth. Using the right air compressor oil for your ...
  • Oil - Air Compressor Oil ' RONA www.rona.ca > ... > Parts and Accessories - Compressors Compressor oil. 473 ml. For all oil lubricated air compressors.
  • Husky 16 oz. Air Compressor Oil-HDA10700AV - The Home Depot www.homedepot.com/p/Husky-16-oz-Air-Compressor-Oil-HDA10700AV/...
    • 5/5
    • 1 REVIEW
    • $2.49
    • IN STOCK
    Air Compressor Oil from Husky is designed to reduce carbon buildup in compressor valves to ensure a longer compressor life.
  • Air Compressor Oil & Lubricant www.ecompressedair.com/compressor-oils.aspx eCompressedair is your source for Air Compressor Oil & Lubricants for major air compressors and synthetic compressor oil brands in 5 gallon air compressor oil ...
  • Oil-free air compressors - Atlas Copco Canada www.atlascopco.ca/caus/products/air-and-gas-compressors/1472896 Oil-free centrifugal compressors. Oil-free reciprocating piston compressors. Oil-free rotary tooth compressors. Oil-free screw compressors. Oil-free scroll compressors
  • Air Compressor - Oil-Free Air Compressor ' RONA www.rona.ca > ... > Products > Tools > Pneumatic Tools > Compressors Air Compressor - Oil-Free Air Compressor. Oil-free air compressor. 26 gal. Vertical, saves 50% more space. 1.7 running HP. 120 V. 15 A. Easy to operate controls with ...
  • May 17, 2016 | Air Tools & Compressors
    I have a husky model 947265. And it won't shut off when I turn it off manually I have to wait till all the air is out before it turns back on
    Free Husky Air Compressor User Manuals ' ManualsOnline ...
    powertool.manualsonline.com > ... > Husky > Power Tools Husky
    Husky Air Compressor Operator's Manual ... Plumbing Quincy Single-Stage Air Compressor - 3.5 HP, 220 Volt, 60-Gallon Vertical Tank, Model Q13160VQ.
    Sep 04, 2015 | Air Tools & Compressors
    Need manual for husky air compressor H1820F
    Ask here, they may be able to help http://www.about-air-compressors.com/husky-air-compressors.html
    Sep 16, 2012 | Husky Air Tools & Compressors
    Looking for manuals for husky air compressor model FP204500AV
    The manual and parts breakdown for your compressor can be found at: http://www.chpower.com/IMAGES/pdfs/manual02/608800_1102.pdf
    If that doesn't work look for it on the Campbell-Hausfeld homepage at http://www.chpower.com/ under Service and Support. They have been working on the site so some links are not working correctly.
    Your compressor is an oil-less type that has very little for you to do as far as service. Mostly you just have to keep it clean and occasionally drain the water from the tank. The frequency of that is dependent on where you are (humidity levels in your area) and how ofter you use it.
    May 22, 2012 | Air Tools & Compressors
    Husky Manual for TF291201AJ
    Go to http://www.chpower.com/manualsearch/ (its the Campbell-Hausfeld website) and put TF2912 in the 'Find Model' search box and you'll get the operating instructions, parts lists and other information on your compressor.
    Oct 16, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
    I have lost my manual to a husky pro 60 gal.air compressor and I need to add more oil, can someone tell me what oil ,seems that i used synthetic 10-30 initialy
    either use air compressor engine oil,. or search out a new owners manual from online,. the details will be in there..
    Best regards
    Ck
    Jan 05, 2011 | Campbell Hausfeld Air Tools & Compressors
    Need to find out how to replace belt on WL65 cambell hausfeld air compressor
    Not sure how easy it will be to locate repair instructions if they are not in your manual. However maybe the diagram of the pump is all you need. Just click on the first link below. It will open up the pump diagram. #14 is the belt.
    I also included the link to the site where you can get a look a at the parts list and order parts for your compressor.
    Hope something here helps.
    If not please let me know and I'll try and describe the proccess for the belt remove to you.
    Pump diagram:
    http://www.mastertoolrepair.com/images/WL390100-Pump.jpg
    Compressor diagram and parts list:
    http://www.mastertoolrepair.com/wl650003-wl650102-wl650102aj-wl650202-wl650601-p-28707.html
    Pump parts list:
    http://www.mastertoolrepair.com/wl390100-p-17694.html
    Nov 19, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
    Husky Air Compressor has rattlling noise!
    buddy im an engineer on these machines for 30 years and when this problem has occured believe it or not but it cheaper to buy another pump unit or compressor plus its the hardest job getting the crank out so your choice bud
    Nov 16, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
    Air Tools & Compressors Logo
    57 people viewed this question
    Top Air Tools & Compressors Experts
    John Trevino
    Joe Garcia
    Joe Garcia
    Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
