Question about LG DLP Projector 1400Lum RD-JT30 Multimedia Projector
Lg 44" dlp tv
Picture freezes whether playing dvd, freeview or coaxial aerial after intermittent times. Sound perfect all the time. repair shop cannot fix - any clues.
Punch yourself in the face REALLY hard and then throw the TV out the window and buy a 60" Plasma or a 52" LCD
Posted on Nov 11, 2008
SOURCE:
Matsui problems
If this is a Freeview receiver/recorder then it could be too much signal thanks to the Freeview retunes going on. Your aerial is more sensitive at some frequencies, so there's more signal power higher up the frequency range.
A simple and inexpensive diagnosis tool is a variable attenuator. The MA1620 on this page is perfect for that job:
Splitters amplified splitters and attenuators
It will give you a way to reduce the signal level at one TV without affecting the other TVs in the house.
Sep 08, 2014 | Televison & Video
How do i stop picture breakup on freeview
This could be too much signal thanks to the Freeview retunes going on. Your aerial is more sensitive at some frequencies, so there's more signal power higher up the frequency range.
Sep 05, 2014 | Televison & Video
I have just bought a new LG 42LM620T TV. The picture is fine but every so often the sound is a little distorted. It's as though the sound has been recorded at too high a level for the speakers. It
No doubt in the audio menu for your TV there are several tweaks available in there - maybe even a graphic equalizer and perhaps other potential modifications. Access the audio menu with your remote and play around in there. You may be able to soften the audio up a bit. Good luck.
Jul 26, 2017 | Televison & Video
Problems on the freeview 21inch Tv Teknica from Tesco was working when we bought it 2 years ago cannot get all the channels and poor reception re installed channels many many times but does not maintain...
you may want to try changing the coaxial aerial cable that feeds the tv, these can go faulty. also if you are running a series of tvs off one aerial, you should be using an aerial booster, other wise you will get a signal drop (as displayed on your tv).
If these small things don't cure it, the set requires replaceing as the tuning card is knackered
Jan 16, 2011 | Audio Players & Recorders
LG DLP RU-44SZ51D Lamp Indicator blinks red
44 inch lg dlp hdtv no picture or sound press power button standby light turns yellow and then back to red
Mar 04, 2009 | LG RU-44SZ51D 44" Rear Projection...
Nintendo 64 - sound not working on new TV
Because the 64 is somewhat old I would suggest getting an aerial splitter because the system may not be able to function properly with out it. Try it and see how it turns out. Or, if you don't mind, you could play that game on the computer if you have one. Download Project64 from:
www.pj64-emu.com/
Nov 11, 2008 | Nintendo 64 Console
No Sound
presumably you have already tried powering off for 10 mins then doing a shipping condition reset ?
Jun 14, 2008 | Panasonic DMRES20D DVD Recorder
Similar problem as you helped me solve before.
OK, I think I see the problem there.
The aerial lead from the DVDR to TV should be removed.
You should have it setup the same as the other Freeview - VCR - TV
Nutshell time:
Main aerial to Freeview input.
Loop aerial from freeview output to DVDR areial input (all this does is allow you to watch freeview, or standard both out of the DVDR)
So..
Scart from Freeview to DVDR input
Scart from DVDR output to TV
Set DVDR to AV input mode.
Set TV to AV (whatever number you need for that..you now won't get anything on screen unless you have the right input selected)
If you can now see the Freeview picture on the TV and change the channels with the Freeview remote then you should be set for recording.
Having the aerial and a scart lead both going to the TV is not needed.
Apr 14, 2008 | Philips VR550 VHS VCR
407 people viewed this question
Top LG Office Equipment & Supplies Experts
jasbo
jasbo
scj103
Jaime Hernandez
Are you a LG Office Equipment and Supply Expert? Answer questions, earn points and help others
