Question about Electrolux Vacuums
Attaching wires to electrolux silverado 1505 vacumn replacement on/off switch
How to attach the switch wires to the on/off switch need a picture or good verbal description
b0sslady2001
  • 357 Answers
SOURCE: What hose gets hooked up for upholstery cleaner. The one that usually goes in front? I cant get my vacumn to turn on.
Hi!
You need to take the power nozzle off and attach the thing that looks like a little plastic "cup" with two hooks and a screen on it. This is the intake guard. Attach it to the front. Now remove the cloth bag and put the hose on the hole where the bag was. You'll have to line the arrow on the hose up with the notch on the Kirby and push the hose arm toward the Kirby until it pops on. (if the hose isn't all the way on, the vacuum will not run) If you need to, lube up the edges of the hole with a wee bit of vaseline or hand lotion. This makes the hose engage easier. If this didn't help, I have mnauals available.
http://stores.ebay.com/CLICK-HERE-FOR-GREAT-DEALS_KIRBY-OWNERS-MANUALS_W0QQcolZ4QQdirZ1QQfsubZ7656839QQftidZ2QQtZkm
Hope this helps...
Marci
Posted on Jun 02, 2008
  • 70 Answers
SOURCE: I need a service manual for an Electrolux C104A
If you talking about the part that swivels it is called the elbow and the part number is 46861.
Posted on Jul 17, 2009
  • 8404 Answers
SOURCE: the on/off switch on my kirby g-3 vacumn needs to be replaced.
Get the parts ... locally or at some place like Repairclinic.com then set aside a Saturday afternoon in a quiet place with screw driver, pliers and a box of band aids and go to it.
Repairclinic.com will also provide you with details of the actual procedure at hand.
That is what I think
a
Posted on Oct 05, 2009
VacuumRepair
  • 438 Answers
SOURCE: i need to replace power supply. where the cord
Greetings from GoVacuum.com,
Unfortunately there is no fuse on a Kirby Generation model. In my 10 years of repairing Kirby's as well as other vacuums I will tell you that 9 times out of 10, when a Kirby Generation doesn't turn on, it's the cord that needs to be replaced. This is by far the most common problem that we see on Kirby repairs.
The Kirby motor is very well built, and usually has a life of 30+ years (G3 is about 12-15 years now). The only other problem it could be on the Kirby would be carbon brushes, or the switch assembly.
I would first try testing the power cord, I think this will solve the problem for you. To test a cord on a Kirby Generation (all Generation models are the same machines, just different colors) first follow where the cord goes into the Kirby at the bottom. To access this cover easier, first remove the "boot" at the bottom of the outer bag. This is the plastic part at the bottom of the outer bag that connects onto the Kirby. You will see that there is a plastic cover over the cord. You will need to remove the screw that holds this cover on.
Now after you have removed the cover, pull the plug out of the machine. Once you have the cord disconnected from the machine, you can now test it to see if there is a short somewhere in the cord. You will need to purchase an inexpensive continuity tester from Home Depot, Radio Shack or most other electronic stores. This will tell you if there is power running through the cord, or if the cord is bad. With the continuity tester, plug the cord into the wall outlet, then put the positive, and negative testing rods into the female end of the cord that plugs into the machine. You will then be able to tell if the cord has continuity going through it. The tester will indicate if there's continuity or not.
The picture here shows that the cord is good. If your tester does not light up, or indicate that there is continuity, you'll simply just need to purchase a new cord. As I stated earlier, this is the most common reason that a Kirby won't turn on.
If however your cord tests OK, this indicates that the machine either needs a new motor (or carbon brushes in the motor) or it needs a new switch.
Chris Jones
Posted on Mar 21, 2010
SOURCE: What would cause the suction to be weak?
It sounds as though there is something stuck in the hose or outlet from the motor to the hose.
Posted on May 03, 2010
Model Silverado Deluxe 1505. When I turn the switch on it gives power to the floor brushes but the vacuum motor isn't working.
If you have power to the "electric power nozzle" but nothing in the motor, it could be a wiring issue, especially if someone has been "servicing it" lately and didn't replace the motor wires properly.
If not, given the age of your Silverado, it may be the motor itself.
I am in the business of servicing and rebuilding them if it would be helpful. mickeymackmark1@yahoo.com. Good Luck! Mick
Mar 12, 2015 | Electrolux Vacuums
How do I replace the rocker arm in the off and on switch of the Electrolux canister vacumn model 2100
This is something that can be very difficult to explain, much less perform without prior knowledge of this particular model.
With 30 yrs. experience, I have a legitimate store front business and do service by mail at a reasonable cost if interested.
mickeymackmark1@yahoo.com. Hope that helps! Mick
Mar 09, 2015 | Electrolux Vacuums
How do I get hand held vacumn to work without attaching it?
Sounds like the dirt container if full and overflowing.
Aug 31, 2014 | Vacuums
Carpet beater not turning on, rest of vacuum ok, reset button down
Is the PN motor not working, or just the brush not spinning. If it's the brush, a new belt is needed.
If the motor isn't working, it could be due to several things. Follow the trouble shooting steps below.
1. Check all connections from hose handle to PN for discoloration. Any parts showing discoloration or melted plastic need to be replaced.
2. Attach PN directly to the hose. If the motor works, there's a problem in the wand wiring/connections.
3. Attach the Sidekick directly to the hose. If it works, but the full sized PN doesn't, there's a problem in the PN. Problems could include: wiring, connections, bad motor, bad switch.
4. If neither Sidekick nor PN work, the problem is likely in the hose. Potential problems include: bad wiring, connections, or bad switch.
5. You can try another hose known to be good to test the PN. If it still doesn't work, the problem could be in the canister itself.
I strongly recommend taking it to an authorized Aerus Electrolux store for diagnosis and repair if needed.
http://www.aerushome.com/storelocator/
Apr 09, 2011 | Electrolux Epic 6500 Vacuum
May 03, 2010 | Electrolux Vacuums
I have a 5.5 hp craftsman 20 litre wet Dry vacum . I have lost the manual. & have 2 questions 1) how do I change to wet vacum from dry? Also could i use the wet mode with some water in it and let it...
# 1 myou just take the bag out make sure ytou sponge filter is in place athe top and turn it on the power switch just turns on ,machine ther is no wet dry switch just an empty bagless cannister is all you need make sure the ball outlet in vacumn is working it stops water from overfilling cannister # 2 just use the proper bag and attachment to vacumn up the drywall dust a good building supply store has special sanding attachments for vacumn so you can sand and vacumn at the same time
Dec 18, 2009 | Vacuums
Bissell Healthy Home Vacumn
On the Healthy Homes Vac, did you check the switch for the vac, there are 2 on the handle, and the one could be open. Check the wiring at the motor, could even be the motor itself. If at the motor there is a thermostat, it could be bad, but comes with the motor.
Jan 06, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Vacuums Logo
123 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
