Question about E-Machines T3120 PC Desktop
E machine T3120 hard drive sector bad no boot up
Turns on, goes though process of starting then blue screen with hard drive error
    Habit-Forming:
  • 98 Answers
I am going to paste some steps, but you need to follow them with extreme caution. After completing each step, you are advised to check if your problem is fixed (i.e. if your system boots...) If not, you can go on with the rest steps... Ready? Let's go for it...
Boot from either your Windows 7 Installation DVD or Windows 7 System Recovery Disc or into Windows recovery mode, enter the following command at the command promptand then press enter:
bootrec.exe /FixMbr If successful, you should be greeted with the message "The operation completed successfully". That's it! Your Master Boot Record has been repaired.
While the above command fixes the MBR and sometimes that is enough, there still might be an error with the system partition's boot sector and Boot Configuration Data (BCD). This might occur if you have tried to install another operating system alongside Windows 7. To write a new boot sector, try the following command:
bootrec.exe /FixBoot
If your Windows 7 installation not being detected during start up, or if you wish to include more than one operating system choice to your system's boot list, you can try the following command in order to rebuild your BCD:
bootrec.exe /RebuildBcd
The above command will scan all your disks for other operating systems compatible with Windows 7 and allow you to add them to your system's boot list. If this fails, you may need to backup the old BCD folder* and create a new one in its place with the following commands: bcdedit /export C:\BCD_Backup
c:
cd boot
attrib bcd -s -h -r
ren c:\boot\bcd bcd.old
bootrec /RebuildBcd
Now, if you get the message "
BOOTMGR is missing" error during your system's start up that prevents Windows from starting. then you need to change your active partition back using the Windows 7 recovery disc or Installation DVD... Follow the steps below.
Step 1: Follow steps one to four in the above guide. This should take you to the Command Prompt in the Windows Recovery Environment.
Step 2: Type DiskPart and press Enter.
Step 3: Type List Disk now and press Enter. This command will list all disks attached to your computer and assign them a disk number.
Step 4: Type Select Disk x, where x is the number for the disk containing the partition you wish to make active. Press Enter.
Step 5: Type List Partition and then press Enter. You will now be shown a list of the partitions on the selected disk. Determine which partition you wish to make active.
Step 6: Type Select Partition x, where x is the number of the partition you wish to make active.
Step 7: Now, just type Active and then press Enter. That's it! The selected partition is now active.
Hope this helps!
Posted on Mar 05, 2014
  • 3,799 Answers
Replace Hard drive and Re-Install the Operating System.
Posted on Jan 07, 2013
3 Suggested Answers
  • 1584 Answers
SOURCE: E MACHINE 2862 WONT BOOT UP WITHOUT HITTING ENTER
Need to run scndsk for any bad sectors.
If you have altered the drive bay loom at all sounds like you may have got jumper in wrong position
Posted on Feb 17, 2010
SOURCE: My mothers T3120 emachine scrambles after booting up and then the screen becomes black. I noticed that the fan attached to the motherboard, reduces speed when this happens. After attempting to restart
Sounds like a config problem and how to fix is hit F8 at boot, then go in safe mode.When you get on your desktop, go to the run box type msconfig/startup and uncheck all but network.Need more help come to my website at http://www.ezsystemrepairs.com/.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_70466cb634a57543
Posted on Jul 04, 2012
My acer wnt start up or boot is bios missing dll blue screen is all i ger
If you have a boot menu the problem is likely not the Bios. No beep codes? Some PC's will give hardware error codes in the form of long and short beeps through the MB speaker. Otherwise a bad boot sector on the hard drive would likely give you an error message, like ; NTLDR is missing
Press Ctrl+Alt+Del to restart
Check the power and ribbon wire connections to the hard drive. If you have recovery disc/'s, doesnt hurt to try! Otherwise its a new operating system, new hard drive, and searching for drivers. Good luck to you!
Aug 13, 2014 | Acer Aspire 7540G Compatible Laptop Power...
Failed Windows XP Setup
sounds like a bad hard drive or it has bad sectors.hard drive regenerator software may help
Jun 25, 2017 | Computers & Internet
How to fix error 08-0a4b-0000
Getting this error during the set up process indicates a hard drive failure, usually a bad sector or the wrong system is trying to load; GPT instead of MBR and a partition cannot be created. Generally it will load and then be unable to read from the bad sector or just will not boot, creating a problem, system glitch, or blue screen error. You will have to replace the hard drive.
Nov 27, 2013 | Toshiba Satellite A215-S7422 Notebook
Hello, I have a problem with my Western Digital it's a WD3200AAJS-56M0A0 model. I noticed that Windows 7 was taking very long to boot, it would stay 5 mins at the Win 7 logo screen and after that my comp...
The low level format that you are using will identify the bad sectors and put an "X" on them so that no data ever gets stored there. Ergo no critical file(s) will ever be corrupted or not work and your machine should work good as new until the drive starts going bad again. The low level format always takes time especially on the large drives when it can sometimes take up the better part of a day. But it will restore the drive to an as new condition for no dinero. No brainer.
However, I would not really trust the drive for long periods of time and if I continue to use it I can expect other bad sectors to develop. So it would be wise for you to on a monthly basis do a backup to prepare for the eventuality of the drive finally dying.
Apr 10, 2017 | Western Digital WD Caviar Blue WD3200AAJS...
I have an acer laptop. I downloaded service pack 2 and service pack 1. The computer was working well until the service pack 1 was installed. When it restarted my computer, it went to a black screen that...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
also you could run the chkdsk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
then defragment your hard drive also
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
hope this helps
dont forget to vote
Feb 04, 2011 | Acer Aspire™ T180 PC Desktop
On my laptop i have a problem with the blue screen. When I turn my laptop on it loads for a few seconds then it gives me the blue screen, what do i do?
Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart then
once you have your computer running try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive then you might test all leads that are attached from your motherboard to your hard drive or just replace them there probably old and faulty
hope this helps
Oct 24, 2010 | Computers & Internet
Dell lid was slammed bad sectors and slow processing...
Honestly even if you were to get lucky and be able to get vista back onto the laptop, your going to get even more bad sectors quickly cause the hard drive is going bad.
Get a new hard drive put in there and then get the laptop restored back to factory defaults.
Jul 08, 2009 | Dell Inspiron 1525 Notebook
Lap top wont boot up past the windows screen
This generally indicates that a sector in the hard drive has failed, and the hard drive will need to be replaced. With a bad sector the drive reads to the point of the bad sector and past the bad sector, but can't put the info together, so it tries to boot, but can't. Unfortunately, your only option is replacing the hard drive.
Aug 01, 2008 | HP Computers & Internet
Im getting an error code 08-0E89-0000 how do i fix this I had Toshiba A305-6844 after removing all the partition from the HDD using Recovery Disk I get Error #08-0E89-0000 while recreating the partitions...
I had the same message, replaced the hard drive, still got the same error code, took the hard drive back to best buy and they game me a new one, put it in and got the same message again...
Jul 02, 2008 | Computers & Internet
SATA 80GB Seagate HDD
When your 80GB SATA Seagate HDD complains of bad sectors while booting, this is a sign of a failing hard drive. Today's hard drives will actually self-correct a certain amount of bad sectors before you get any kind of error message. If you are getting "bad sector" errors, this is because the drive has so many problems that it can no longer self-repair. You asked if this may have happened because you have formatted the drive many times. No, bad sectors was not caused by formatting. Your drive did not become "dead slow" because of the formatting. It became slow because your cpu now has to do much more processing to "work around" the bad sectors on the drive. You also asked if you could recover your hard drive to normal state. Please understand that once a drive shows bad sectors, it will not be long before the drive fails completely, at which point you will no longer be able to access anything at all on the drive. No, this drive cannot be recovered. Instead, you should save all the data you can from this drive, and you should do this as soon as possible, before it fails altogether.
Mar 27, 2007 | Seagate 80GB 7200 rpm SATA/150 8MB Serial...
E-Machines T3120 PC Desktop Logo
73 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
