How can i connect my TV video in to system through USB2.0 port...
    Problem Solver:
  • 17 Answers
You need a TV tuner card to do that. There are no cables that connect TVs to USB 2.0 ports.
Posted on Jan 20, 2009
How to connect to tv
There are several ways to connect a game console to a TV. The question is, what system are you trying to connect? Some features may be available for the newer generations, that are not on older models. I'm assuming, since you have posted with a picture of a Sony Playstation 3, (PS3) that is the system you are trying to connect. The easiest way to install is to use the supplied (RCA) connection cords that comes with every PS3 system. One side connects to the corresponding port in the back of the system, and the other end has (3) multicolor plugs. They will match the colors on most TV's. Some of the older TV's do not have the RCA ports and will require an adapter to connect this way. These colors are; YELLOW (video out) RED (audio out right channel) and WHITE (audio out left channel or MONO) The PS3 also has and HDMI port, and is much simpler to connect the TV and game console together. As I stated before, not all TV's are equipped with HDMI. HDMI cables carry both the video and the sound through 1 cable. To install this way, simply turn on your TV to the correct aux port, in this case HDMI, then connect the the HDMI cable from the PS3 to an available port on the TV. After you have connected the cords, turn the system on and it will tell you that it has "Detected an HDMI connection. Would you like to use this connection?" Select yes. The rest is automatic.
Also, if you didn't know and are needing a new rca cord to connect to the TV, search for a cord from one of the older systems in the SONY family and they will save you some cash, as they are all exactly the same. PS1, PS2, and PS3 all use the same connection. I hope this helps. Good luck!
Aug 25, 2015 | Video Game Consoles & Games
How to connect a laptop to tv
The laptop has an additional connection for some type of external display. The connection will be a VGA Port, S-Video Port or an HDMI Port. The tv will need the same type of port as the laptop so that you can connect a cable between the two of them. If the connections are not the same, you will need some type of converter that will go between them to make them think they are the same.
Once you connect the two with a cable, take the tv's remote and press Select Input, then select the Input Source where the tv is to receive the signal (PC, S-Video, HDMI). Reboot the laptop and the video should appear on the tv.
The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
Jun 01, 2012 | Computers & Internet
How do i hook my computer to my tv
You will need to connect the computer and tv by using a cable and connect them. Your TV has ports such as VGA, S-Video or HDMI on it to allow it to receive a signal from some external device. Your computer needs to have the same type of port or you will need something (some type of adapter) to make the tv and computer think they have the same type of connecting ports. Most laptops have an extra port for displaying on an external device such as a tv. Most desktops don't have an extra port so you will need to purchase a video (graphics) card that has the ports on it and install it into one of the desktop's pci slots.
Once you have the ports on both devices (tv and computer) then connect them with a cable. Then take the tv's remote and press Select Input so you can tell the tv where to receive the signal from (PC, VGA, S-Video, HDMI). Reboot the computer and the image should appear on the tv.
On laptops The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 31, 2012 | Computers & Internet
What cable do I need to connect latitude D600 to a hdtv ?
The first step is to inspect both your laptop and TV and identify the connections, easily located on the back of either component. There are five basic types of jacks, or ports involved:
*Composite/phono plug (RCA)
*S-Video
*Video graphics array (VGA)
*Digital video interface (DVI)
*High-definition multimedia interface (HDMI)
*An RCA connector, sometimes called a phono connector, is used for analog audio and video components. Three round, colored sockets are standard — left audio is white, right audio is red, and composite video is yellow. These are standard jacks on older TV’s and laptops. A three-prong cable, readily available at any computer or electronics, is the easiest way to make an RCA laptop to TV connection.
*S-Video, or Super-Video, a more advanced analog video connector, uses a four-prong round plug, like those used in TV cable installations. Separate audio cables are the same as for the RCA connector, left audio/white, and right audio/red. S-Video is commonly found on older TV sets and some laptops.
With S-Video on both TV and laptop, connecting a laptop to a TV is a simple matter of a single S-Video cable. If your laptop has a great sound system, you won’t need audio cables, but for better quality you’ll also want audio cables.
RCA to S-Video cable, a special laptop to TV cable, is available when you have RCA jacks on one device and an S-Video port on the other.
*A VGA connector and cable are used to carry analog video signals plus display and graphics data. The VGA is a 15-pin connector commonly found on laptops and other devices. With this port you need a PC-to-TV Convertor to connect laptop to TV. You simply plug the VGA cable from the source into the convertor, and use an S-Video or RCA cable out to the TV. The converter is USB powered, so there’s no external power adapter to carry around, making this laptop to TV connection entirely portable.
*A DVI port is rectangular with 24 pins arranged in three horizontal rows of eight pins for digital video; separate RCA analog audio cables fit into white and red plugs. DVI ports are found on Macintosh laptops; sometimes they are smaller than normal DVI ports and require an adapter, which usually comes with the laptop.
*The HDMI port, one-half the size of the DVI port, is also rectangular with 19 pins. It provides digital audio in addition to digital video, despite it’s smaller size, for a complete TV to laptop connection. These ports are found on new HDTVs, and sometimes there are two or more. TVs with HDMI ports are the only ones that do not require additional audio cables.
TV’s with a single digital port labeled HDMI/DVI require only one cable when the source is another HDMI component. But when source is a DVI laptop, you need a DVI-to-HDMI cable for the video and a separate pair of RCA analog stereo cables.
NOTE: Whenever ports do not match, you can by adaptors and/or cables to make any connection.
Nov 22, 2009 | Dell Latitude D600 Notebook
PANASONIC MD NV 10000
i do not understand,do you connect all these cables at the same time?If yes is wrong ...Just connect in a well known pc the fire wire cable and power on camcorder.If pc doesn't capture video,THEN look after editing program...
Jul 27, 2009 | Panasonic NV-MD10000 Camcorder
Disconnected system to install new carpet now i'm stuck
Try these...
1. Identify the Video out,Audio Out ports of the player. Normally they will be marked as AV Out for video,L(Left Audio) and R Out.
2.Identify the Video In,Audio In ports of the TV
3. Connect AV Out from the DVD to the AV in of TV,Audio Out of the DVD to the Audio in ports of the TV.
4.If the TV is Mono (means, with a single Audio in), connect to any one of the Audio port of DVD.
Mar 13, 2009 | Televison & Video
Connecting tv to surround sound
Look at the back side of the TV .
There will be [more than one] composite video in & out
How composite video port looks like typical 3 RCA jacks - std color of ports are Red, White & Yellow. The yellow one is the one - which carries video signal. You can connect - a RCA cable from output of SC-HT730 [yellow] to back of TV.
Most probably there will be at least one Component video behond your TV set [ if the set is HD Ready one] - in other words, If your TV supports component in.
Component Video ports are namsed as Y Pb Pr - if you have so, connect output from SC-HT370 to back of TV.
Recommendation: choose component video - if that is supported in both. That gives much better picture quality.
Dec 16, 2008 | Panasonic SC-HT730 System
Hook up
The Bose GS can only support component video set-up for the best video definition. This video connection set-up uses three RCA cables to transfer the video signal from an output device (the Bose GS) to an input device (Your TV).
Check if the back of your GS system has a set of video out RCA ports that are titled "Comp Out". You TV should then have a "Comp In" video input RCA ports you can connect to.
Hope this helps.
Oct 14, 2008 | Bose 3 2 1 GSX System
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
