Question about Jensen CD3720 CD Player
I have the jensen cd3720 cd player and it stop playin music and comes back on by it self what can it be that makes the radio do that
    President:
  • 720 Answers
Are you losing complete power? Or do you have power, but losing sound only?
Loss of Power:
If you can access the wiring loom of your Jensen, check the RED ignition wire to ensure its secure - this wire is responsible for powering the unit ON (with key ON) and OFF (when key is OFF). A multimeter will be a useful tool to check for power when key is ON.
If the RED wire is fine, then there could be an issue with the power supply on the unit. Check the fuse on the Jensen unit - if ok, then there is a fault in the Jensen unit.
Power, but no sound:
The unit is faulty and will require service (or replacement).
Posted on Feb 22, 2013
SOURCE: Jensen CD3720 car stereo unit face plate LCD display blanks out.
The substrait is probably cracked, that's the circuits inside the pc board of the faceplate. It will cost you too much to try to have it repaired. If you will wait for a few days I may have a face for it as I'm currently trying to fix one that is blowing fuses. I'm not going to spend a whole lot of time on it. I'll let you know.
Posted on Apr 08, 2008
SOURCE: how do i reset the
reset the clock on am fm cassett jensen radio
Posted on Jan 28, 2009
  • 85 Answers
SOURCE: we hAVE A JENSEN UVA RADIO PLAYS SOUND THE CD DVD
it is a very common problem with the recoton/namsung companies. which make jensen,dual,qwestar,and etc. the cd player was built cheap and the cd player of course is not the best. inother words you need to replace the cd drive or send it back to jensen if still under warranty
Posted on Sep 08, 2009
trububbles1
  • 54 Answers
SOURCE: Jensen KDC 9520 Car CD player lost speaker conection
sound chip inside is fried
Posted on Sep 25, 2009
guru_fixya
  • 944 Answers
SOURCE: Jensen CD3720 CD Player All of
Hi Sonia,
There are many internal fuse that controls the flow of current it is being blown so you have to replace the one accordingly.You should do continuity test to find out the which fuse is blown using ohm-multimeter.Check for any burn sign or for the fuse which is getting to heated.That is the defective one you have to replace the one.It will be of this shape.
In some fuse the internal lining will be broken so you can easily find it out.
The reason why the internal fuse blows out is due to the following reasons.
Make sure power wire is not pinched.
Make sure speaker wires are not pinched.
Install fuse of correct rating and size.
Sometimes The battery and ignition wires are not connected properly. The yellow wire is for the battery and the red wire is for the ignition/ACC.
The volume reaches upto some level and it is not able to supply the required volts because of the defective fuse.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 05, 2010
I just installed a jensen CD3720 on 87 camaro and there is 2 problems 1)i had nowhere to connected the negative wires on cd player.2)the volume is low i have to turn it to around 70 for it to sound...
http://www.the12volt.com/
I would hook ground up to ashtray or other metal. Double check your wiring.
http://www.the12volt.com/info/diagrams.asp
Oct 29, 2009 | Car Audio & Video
My sansa express radio stopped working. The other music still plays.
which sansa model do you use?
one having radio + mp3 play feature?
so mp3 playin' works but the radio-receiver seems to be broken? please give some more details and come back.
Jun 17, 2009 | SanDisk Audio Players & Recorders
Light burnt out on Jensen 311x cd car radio with removable face.
You will have to Open it up. These are Very small LED Lights and will need to be Soldered on to the Main Board inside the Unit. You can get these Bulbs at Radio Shack. Please Rate My Response! Thanks!
Feb 05, 2009 | Jensen CD3720 CD Player
Reset the clock on jensen am fm cassett model night glo . thanks
press and hold 'disp' button until the time flashes. you might have to press once, then press and hold. when the time flashes, the 'back' or left arrow button does the hour, the 'forward' or right arrow does the minute.
Jan 28, 2009 | Jensen CD3720 CD Player
No Sound
check for a short. I experienced the same thing in my '86 F-250. Wires were replaced using a larger gauge, and crimped connectors with heat-shrink. Worked great.
Jan 18, 2009 | Jensen CD3720 CD Player
Acceptable disks
SO USE TDK....THEY ARE CLOSE TO THE BEST...
Jan 09, 2009 | Jensen CD3720 CD Player
Feb 28, 2008 | Jensen CD3720 CD Player
Jensen CD3720 CD Player Logo
66 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
