Question about Philips 21PT6818 21 in. TV/DVD Combo
NO POWER ON MY TV SET PHILIPS 21PT 3952
THE DISPLAY OF THE SCREEN IS CUT IN HALF ONLY THE BOTTOM HALF HAVE PICTURES AND WHEN I TAP THE SET ON THE SIDE THE PROBLEM IS FIX FOR A WHILE,BUT IT KEEPS COMONG BACK...AND THEN NOW WHEN I PUSH THE OFF BUTTON THE SOUNDS SUDDENLY GETS LOUD AND WHEN I TRY TO SWITCH IT BACK ON THERES NO POWER...WHAT SEEMS TO BE THE PROBLEM?
  • 20 Answers
You have an electrical malfunction inside the unit which can NOT be repaired by tapping, nor can it be repaired by a person who doesn't have extensive experience repairing consumer electronics devices. It is imperative that you have a professional repair the device... or throw it away, if you don't feel the repair cost can be justified. This problem will NOT get better on it's own or by tapping, and could conceivably result in the unit self-destructing and burning your house down in the process.
Posted on Jan 20, 2009
My 5 years old Plasma TV found half of the screen picture view not very clear.. The half colour seen blur..
Your Buffer boards or the YSUS main are bad. THe YBU-Y Buffer upper controls the top half of display, the YBL-Y Buffer lower controls the bottom half and the YSUS Main controls both those boards. They are located to the Far Left on and opened Set.
Jun 21, 2010 | Philips 42PF9966 42 in. HD-Ready Plasma...
Bottom half of the screen goes black frequently.
You can start here: http://www.support.philips.com/support/catalog/catalog.jsp;jsessionid=87CE21B6A8264B83B8D00501ADACA8BF.app107-drp1?_dyncharset=UTF-8&country=&categoryid=FLAT_TV_CA_US_CARE&userLanguage=en&navCount=1&groupId=TV_GR_US_CARE&catalogType=&navAction=push&userCountry=us&title=Flat+TV+(plasma%2C+LCD)
Enter the exact Model Numbere in the search text field.
First verify the exact Model Number of your TV. Mine is a 42PF7220A/37.
go to:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=42PF7220A/37&scy=us&slg=en
On this page I found listed under "Software2.gif & drivers" the Firmware Upgrade Software 42PF7220A/37 v1.5.0.0
I downloaded the compressed file and extracted it to a USB Flash Drive2.gif.
After you extract the file you will have 2 files...."autorun.upg" and a "readme.txt".
Make sure the USB Flash Drive2.gif has only one file on it (autorun.upg)
Make sure the TV is turned off.
Put the USB Flash Drive in any of the USB ports on the TV.
Turn the TV power on with the Power Button on the righthand side of the TV.
The TV will display an Update screen.
Let the TV run through all 3 processes.
Turn the TV off and remove the USB Flash Drive.
Power the TV back up.
Hopefully the Updates fixed the problem.....
Jul 27, 2009 | Philips 42PF7220A 42 in. Plasma Television
Black vertical bar about 4 and a half inches wide down center of screen
hi...
It sounds like an Intergrated Circuit (IC) has fried.
Your best bet in this situation is to contact ur tv service operator and let them recommend an authorized service center in your area....
rate me!!
Jun 01, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
On switching Philips Tv type:21PT 240B/94R no sound,picture
I have Philips CTV 21 PT 240B/94R. and this time a problem are when set on chenel are not stop to change only forward and bottom right side Display Scan+
Jan 29, 2009 | Televison & Video
Phillips 42 inch Plasma -Screen Issues!!!
intermittent loss of picture on either bottom or top half of screen is specific to y buffer boards located on left side of screen going from top to bottom when looking at back of tv. the y lower buffer would be the board to replace to resolve the loss of bottom half of picture. if the top half also is going out intermittently could tied to upper buffer as well but just a note the y main board to right of these buffers drives those two boards so in some cases could also be part of the problem. if only bottom half is affected i would recommend replacing lower buffer only
Aug 07, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
42" Philips plasma screen goes black
You have a Ysus problem. Sounds like a cold solder joint or loss connections on ysus main board.
Jun 03, 2008 | Philips 42FD9954 42 in. Plasma HDTV
Philips wide screen 32in Digital TV
You probably have a component breaking down on one of the circuit boards. It would have to be checked out to find out which one. Stargazer
Feb 13, 2007 | Philips Magnavox 20MT133S 20" TV
Philips 21PT6818 21 in. TV/DVD Combo Logo
381 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
