Why does curser freeze with windows 7
Curser and screen freezes 30-45 seconds after startup from the hibranate or sleep mode. runs fine after shutting down and restarting. runnng windows 7 ultimate. thanks
  • Tony Morris Sr. Jan 07, 2013
    Thanks for the response Brown Kendy. This freeze issue only started after I installed Windows 7 Ultimate. No other changes were made to the Laptop. As long as I shut down and restart it does not freeze.
    Scholar:
    New Friend:
  • 58 Answers
Computer freezes is usually related to hardware, meaning the video card, random access memory (RAM), or another component may be underperforming. Software also can lead to a frozen computer, as can issues with drivers, the operating system, and malware; A virus or spyware infection on your computer might also be the source of freeze issues.all these things can stop a computer from working properly.
1.If the freeze happens every time a certain hardware device is plugged in or switched on, the device itself might be to blame. Check drivers update for the device, and download and install them to erase any bugs that might exist in your version. Similarly, if the freeze only happens when using one particular application, that program might also be the root cause.
2.Run the System Restore utility from the System Tools section of the Accessories folder on the Start menu to roll back Windows to a previous version of the registry. This will fix prior registry issues without affecting personal files and settings.
3.If your computer still keeps freezing up after you take the solutions above, I suggest you to download a software to deal with it. The choice is sure to be more effective and simple, but there are few free utilities for this issue. Windows Boot Genius is a excellent one if you wanna take this solution.
source:http://windows-repair.net/computer-freezes.html
Posted on Jan 07, 2013
  • 883 Answers
SOURCE: SONY VAIO notebook freezes on xp splash screen every 2-4 mos.
first, ensure your system restore is turned on and make a restore point right now!...assuming you have run a thorough disk check and de-frag. then, trust the system restore. I have used it with success 100% of the 20 or so times I have used it. Next, start using the "Hibernate" power down mode. I have found this to work wonders with third-party driver problems. It seems that once a good startup happens, then freeze it (and continue to get a good startup) with hibernate from then on. Last, check about every month for the quantity of restore points that have taken place automatically by Windows. Sometimes, depending on the size of the hard drive, too many points can begin to encroach on your free space that you want for virtual memory or data. So for example, I see 15 restore points in the last month, I will dlete them all by cancelling system restore. Then I use "clean disk" scandisk and defrag. Then I turn restore back on.
Posted on Jun 12, 2007
shugster
  • 93 Answers
SOURCE: IBM T23 Freezes
have you tryed update on the bios ?
i had the same problem with a toshiba lap top
and a bios update solved it
Posted on Nov 04, 2007
  • 162 Answers
SOURCE: My computer does not shut down
Ok
Gonna try and teach you some basic programming :-).
What the following will do, is create you a Desktop Shutdown Icon, which when you double click on it, will hopefully shut down your PC rather then restart it.
So here's how to do it :-).
1. Right click on your desktop and select new > shortcut.
2. In dialog box type “shutdown –s”
3. Click next to continue and then type a name for shortcut (IE Shut Down PC) and click finish.
Now you should see the shortcut on your desktop and will hopefully solve your problem.
Posted on Dec 09, 2008
  • 38 Answers
SOURCE: acer 7720 will not boot
Do you want to try and see if a 'Linux LiveCD' boots? This is the way I test if the computer works. You burn this CD to a disk, and then boot off of it when you're computer starts. I will not modify anything on your computer as long as you go to 'Try Ubuntu with out installing'
http://www.ubuntu.com/getubuntu/download
Don't worry, I'm not trying to get you to install anything, just see if it boots into the 'live environment' (means you are running it off of the cd) If this works, that means that it is only your windows installation is messed up, and a reinstallation of windows should work fine with a Windows install CD NOT the recovery cd.
Posted on Jan 31, 2009
nilutpalsono
  • 238 Answers
SOURCE: have a acer aspire 5520,it
1. Check your power cord & adapter.
2. If its working then check the battery, reseat the battery & check.
3. If available then check with another battery
4. If no, then remove the battery & switch on the PC in AC mode.
5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
7. If still no display, connect an external monitor, check if display is comming.
8. If Display is coming then your LCD need to replace.
Posted on Aug 21, 2010
Acer Aspire One D257 13450 with windows 7 starter will start up in 5 minutes will freeze control alt delete mouse or curser freezes only way to shut down is hold the power button until it shuts off.
Have you checked how much space you have left on your drive? When I went over one time that happend to me..so I deleted 100GB and it was fine after.GOOD LUCK
Jun 06, 2015 | Acer Computers & Internet
Imac g4 freeze restart
This is a sign of memory issues with your Mac. Replacing the memory should not be very expensive.
Oct 10, 2012 | Apple iMac G4 Desktop
Compaq nc6220 freezes during POST
Start in Safe Mode by pressing F8 during boot. Then...
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig > Startup tab and uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running.
This just disables them in startup. Programs will still load, but when you initiate.
Oct 04, 2012 | HP Compaq nc6220 Notebook
Dell inspiron 1520 laptop keeps freezing after a few minutes after being turned on. It wont respond to Ctrl +Alt+ Delete and doesn't sleep when its closed. The screen turns black if you keep clicking the...
boot the computer in safemode. check if it will still lock up. if it does then run a hardware diagnostic test. if it doesnt clear the startup by opening the system configuration utility then disabling the items under the startup tab then rebooting to normal mode. regarding the computer not going to sleep mode when closing the lid, visit the power options in control panel and check the settings on what the computer does when you close the lid.
Mar 27, 2011 | Dell Computers & Internet
Satellite A505 laptop running windows 7 64 bit when using shutdown options and selecting sleep mode system does not go to sleep it freezes and must be manually shut down which generates a windows was...
Sleep and hibernate options are part of Bios. what i mean by that is if these is an issue with Bios these features wont work. Sometimes there has been known issues with cordless mice and other devices plugged in via usb port. Also outdated video and other drivers will do same. i would recommend first of all going to manufacturers site and downloading latest Bios update for your system, once this is done run windows update and make sure pc is restarted once done. After all this go back to your manufacturers site and download all of the driver updates that are available. Hope this helps.
Mar 10, 2011 | Toshiba Satellite A505-S6975 Notebook
My computer runs window 7 and it keeps shutting down for no reason and also it keeps freezes for sometime.
Reboot the computer in "Safe" mode and run it for a while and see if the same problems occur. If it doesn't, then I would suspect it is a software and not a hardware problem.
If you think it is a software problem, reboot the computer into safe mode again. Now click the start button and in the search box type MSCONFIG
When the window pops up click the "Selective Startup" button and then on the startup tab. Deselect all the checked boxes, click apply and ok, reboot the computer normally.
Now only the essential services will load and no programs will automatically load. If the computer continues to run normally, then you can go back into MSCONFIG go to the strat tab and start checking a few boxes to start again, like antivirus and malware first. Reboot the computer and see if it freezes with those programs running....if it does then you know one of those is the culprit, if not click a few more on and reboot until you find the trouble software.
Jul 01, 2010 | Computers & Internet
Going to sleep
check the RAM. Take it out and reseat. also see if it runs good in safe mode. if so then you need new video drivers.
Dec 02, 2007 | Computers & Internet
Jun 12, 2007 | Sony VAIO VGN-FE790GN Notebook
Computers & Internet Logo
David Payne
David Payne
