I have a energy e xl-s8 sub and I need to find a site that I can order a fuse and cap that was lost. I dont know exact size of fuse or if the fuse cap can be replaced
  • 14 Answers
SOURCE: dont no wat size fuse for lead
depends what wireing kit you are useing.if you are useing say a 300watt kit then the fuse in the main power lead is normally a 25amp fuse,and this should be installed a maximum of 12 to 18 inches from the batery. hope this helps.
Posted on Mar 08, 2007
  • 12 Answers
SOURCE: Jensen LXA400 Fuse Size and RCA hook up for 2 channel mode?
take it to a stereo shop. there are variables you may not be aware of when hooking up speakers to an amplifier like ohms, very important!
Posted on Dec 10, 2008
kd6rhd56
  • 400 Answers
SOURCE: I replaced distribitor cap and need to know firing order
I recommend you gert an auto maintence /repair manual from your local auto parts store for 20.00 or so for yor truck.
Posted on Jul 12, 2009
SOURCE: I need a new lens cap-need to know size
77MM
Posted on Mar 30, 2010
SOURCE: Fujinon-Mariner WPC-XL Lens Cap replacement
You can order a replacement set at: http://www.bakermarineusa.com/index.php?id=17&cat=38&prod=137
Posted on Jun 29, 2010
Schematic
i have same isue humming like hell ,change 2 power supply capasitor didnt do it ,try to changer 2 mosfest transistor Samsung IRF640 N-channel MOSFET TO-220 200V 18A hope it will do it ,on ebay for a 2.00 each .
i think it is power supply isue ,recterfile circuit not clean it will give you that 60hz humming noise ,good luck
will let you know how it turn out ..
Jul 14, 2013 | Mirage OMNI S8 Speaker
What kind of amp can adequately power P112 S8 subs
you shouldnt run it at 8 ohm it shows what ohms it can handle . to run it at 1 ohm you would need 2 subs to do this. and no i wouldnt run an 8 ohm sub on the amp.
Aug 23, 2012 | Rockford Fosgate Punch Stage P112 S8 Car...
Esw-c10 subwoofer hums and dont work
if you short a sub it will hum try connecting it to a working speaker (no amplifier) if you have access to rear of sub check for wire only needs to be the size of a hair arcing out the speaker, i have a sub that does that on only one output (left rear) its actually the stereo causing it to hum..
Jun 20, 2012 | Energy ESWC10 Subwoofer Speaker
Horn stopped working on 2003 Ford Focus ZTS. I know where the fuse box is, I just don't know which fuse it is. Help please.
Hi
If you take off th cap covering your fuse pannel there should be a list of locations and fuse volt sizes on the reverse side of the cap This should guide you to the exact location of the fuse you need. if that fuse is not burned then the problem is elswhere. good luck...
Aug 07, 2011 | Ford Focus Cars & Trucks
The DLP Projector Toshiba TDP-S8 has consumed the number of hours alloted for the used . Is the bulb of this unit can be replaced?What is appropriate size of bulb for this unit?
yes it can and here is a link to a site with the correct bulb for you http://www.myprojectorlamps.com/projector/Toshiba/TDP-S8.html please let me know if that was helpful
Mar 14, 2011 | Toshiba Computers & Internet
Hello. My mirage sub just started to make a fuzzy noise when playing the bass...it happened after a party that played music on the sub very loud. I don't know what to do....help!
You have damaged the sub by playing it too loud.
Its either the map or speaker that has gone.
You should send it off to get repaired.
Please dont forget to vote this answer was helpful
Many thanks
Feb 20, 2011 | Mirage OMNI S8 Speaker
Firing order
Several engine sizes there, if you have exactly the sizes, send us; check this sample...
1987 Mazda B Series Truck 2.0 liter L4
Hope helps.
Jun 27, 2010 | 1987 Mazda B-Series
Lost my fuse + fuse cap for altec Lansing 621 during a move, does anyone know a place to get one and part #? I would assume they are still using the same fuse cap and fuse in most their other models so if...
Most fuse holders tend to be STANDARD sizes with regard to mounting holes and fuse sizes
Your idea of going to radio shack is the best as the ones they stock are also STANDARD and even though you may end up buying the whole fuse holder just to get the cap the cheap prices would be worth it.
If worst comes to worst you would have a WHOLE holder to replace the one that is in there if you dont mind doing a little soldering.
http://www.parts-express.com/wizards/searchResults.cfm?FTR=fuse+holder&search_type=main&WebPage_ID=3&searchFilter=fuse+holder
Mar 23, 2010 | Altec Lansing 621 Computer Speakers
Princeton monitor
check www.badcaps.net - they have a tutorial on their site for replacing caps, it's for motherboards- but the technique is the same.
I ordered caps for the Princeton Monitor VL1918 from Mouser.com and got their item # 647-UHE1E471MPD6
The 470uf 25v caps size- 10x16 mm
Mar 11, 2008 | Princeton Digital VL1918 Monitor
Celestion S8 Subwoofer
I would check the electroltyc caps in the power supply They general are in the first part of the power supply and there will be two of them . What they do is filter out transformer hum and help stabalize the circuit. I am not saying this is absolutely the problem but the capcitors are relatively inexpensive, Easy to change. And have a habit of going bad after a couple of years in use.
Aug 22, 2006 | Celestion S8 Subwoofer
71 people viewed this question
 Grubhead
Grubhead
