Washer started to smoke during spin cycle then a cracking noise began after that.
When a got the cloths out of the washer they had a smoked smell. I got the washer on test mode "t14" to test the spin speeds then a loud clacking noise can be heard when the spin speed reached the maximum.
  • 8 more comments
  • Roman Garcia Jan 07, 2013
    This machine is a front loader GE Adore Washer
    Can the noise be cause by faulty bearings?
  • B.H. Countryman Jan 07, 2013
    Yes it could be bearing related. Does the spin basket seem to have play in it? Will it move seperate from the tub itself? Stick your hand in at top of tub push up. If there is obvious play your bearings are shot.
    There is really not much play. Could the bearings had caused the smoke inside the tub?
    If very loose the basket could rub against the tub and friction could possibly cause it. But it really doesn't seem likely. However for the life of me i can't imagine another explanation.
    Just found this:http://www.youtube.com/watch?v=Ljww37etY...
    One of the commenters below the video even said his smoked.
    Thanks for your help, I think I will have to take it apart to find out. I will let you know my findings.
  • Roman Garcia Jan 08, 2013
    I am back to report out my findings. I took the washer apart only to find that the Spider arm was broken. This caused some damage to the front tub. I called GE consumer relations and they offered the part at a discounted price. I am looking at a total cost of $300 for Parts no labor since I will be doing the job. Do you recommend going for this repair? Also, should I be concerned about replacing the bearings? Thanks for all the help and advice!
  • B.H. Countryman Jan 08, 2013
    Well i'd definitely replace the inner and outer bearings if i was spending money on the spider arm. I would expect the bearings are messed up from the movement of the tub not running true, and it's hard to say what failed first bearings or spider arm. If your machine is 4 yrs old (like the guy in the video) and it has served you well with no major problems but this, then it might be worth it to fix. Also check prices; my experience is that you can often find parts for about half what equipment manufacturers charge. You will need the model # from inside door (usually.) Try searspartsdirect.com or appliancepartspros.com even eBay.
    Sergeant:
  • 291 Answers
You may just have a defective drive belt. The motor itself will smoke under certain failing circumstances. Can you give me a model # ?
Posted on Jan 07, 2013
  • 2 more comments
    GE Adora WHDVH626 Front Loader
    I checked the belt and there is no visible sign of wear and tear. The smoke came from inside the drum.
    Can you easily spin the tub? It should coast to a stop, no noises should be heard.
    yes, I am able to spin the tub using my hand. There is really not much of a noise.
  • 7 Answers
SOURCE: loud noise during spin cycle
this is my experience repairing the maytag washer Atlantis mav series 9750 aww, I had to replace the spin bearing since it was making a jet engine noise when it was spinning out the water. its not an easy job for my 1st time taking this machine apart, you literally take it all apart to get to this bearing, but now I can show how to do it with pictures making it easier for you to do it. even if you have to replace something other than the spin bearing, this how to tutorial will show you how to get to most of the parts in this machine
tutorial located here tutorial located here https://sites.google.com/site/maytagwasherrepair/maytag-washer-repair
Posted on Apr 08, 2008
  • 77 Answers
SOURCE: model 110 washer will not go into a final high speed spin.
hi, i would suggest the timer/programmer is faultyas it is ok on the other cycles, the noises you have described may have caused some damage,
Posted on Feb 10, 2009
SOURCE: GE washer (wjsr4160gww) makes loud noise during spin cycle
Remove the front panel and you will see two metal guides attached to the front of the frame. One of them will probably be bent and the transmission assembly will have jumped over one or the other of the guides. You need to manually pull it back to center then straighten the bent guide. May have been caused by load being out of balance or machine not properly leveled. Good luck.
Posted on Mar 12, 2009
SOURCE: Noise during spin cycles
GE WPXH214ACC Washer drum makes loud noise when spinning sometimes. We've had it since 2005 & never had this happen before. Washer is level, must stop & redistribute clothes to correct. Just started happening now.
Posted on Apr 06, 2009
  • 7 Answers
SOURCE: Washer won't agitate or spin out.
Well it is ethier Belt, Cluch ,motor ,Or transmission. But it does sound like your transmission . The loud clunk is the brake in the gear case ( Trans.). It might have broken off.
Posted on May 05, 2009
Why does a front loading lg washer smoking in spin cycle
Lg washer smoking - YouTube
? 1:06
https://www.youtube.com/watch?v=vKeIDM78CFI
Mar 29, 2013 - Uploaded by mrsbarney04
Lg washer smoking ... LG Front-Load Washer Disassembly -Washing Machine Repair Help ... Lg Washer model #WM2016CW PARTING OUT! ... Roblox: Chaos Washers -SPINNING IN A GIANT WASHER WITH FANS!
GE Washer Diagnostic - Loud Noise and Smoking ...
? 2:33
https://www.youtube.com/watch?v=a-ONJ2_RQvk
Jul 7, 2013 - Uploaded by ApplianceVideo.com
Service your trusty GE Washer that has these following dilemmas: Loud Noise ... L-G. Samsung Kenmore ,LG, Whirlpool, Electrolux Speed Queen, Amana ... Front Load Washer Repair - Bearing and Seal Failure Mode - Duration: 14:44. ... WasherDiagnostic - Very noisy during spin -GE, General Electric, ...
LG WM1815CS Front Load Washer Smoke burning smell ...
Jan 25, 2016 | LG Washing Machines
Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
LG 4280FR4048L Bearing - AppliancePartsPros.com
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
LG WM2455HW washing machine problem - YouTube
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
Jan 19, 2016 | LG WM2277H Front Load Washer
GE front load washer model number WBVH6240HWW SERIAL NUMBER RM200099T spins freely by hand but started smoking and belt behind looks fine. What could be the problem. Before the smoke started when spin...
Hmm... Kind of difficult to say for sure. Does your inner spin basket wiggle up and down? If so, you've got a main bearing going. Also, put it in a spin cycle for a minute or so and then try smelling the windings on your main motor. If they smell burnt, you'll need to replace the main motor. Also, one last thought, check to see if your drain pump overheats. I say this because the drain pump is active during the spin cycle and a bad drain pump can sound extremely noisy and start overheating.
I hope this helps. Good luck!
Oct 19, 2014 | Washing Machines
I have a Kenmore Oasis Elite 110.280442700. I bought it at the beggining of 2008, never has given me any problem. About a month ago, it started to make a really loud noise during a spinning cycle, as if it...
April, You say you are suspicious that the smoke could have originated from the motor, BUT have you confirmed it? Have you tried running a short cycle without a load to see if the spin cycle rattles the machine or whether the machine works? Watch for smoke and turn off the machine immediately if you see or smell burning. If the motor is burnt, I think replacing should not be an option but rather replacing the machine should be considered.
Mar 01, 2014 | Kenmore 22642 Top Load Washer
Washer make noise doing spin cycle smell smoke make the power cord warm to touch
Thanks for choosing FixYa and welcome to the site Joe. Usually, if a washer makes noises during spinning, it means the drive basket is broken. Make sure your pulley's are not sticking and rubbing the belt. This causes the basket to be unstable during the spin cycle. As far as the smell of smoke, try checking the belt and make sure it is not worn or loose. Inspect the motor to check for noises, grinding, or smoke. Your transmission may be burning up. Usually, the cord will remain warm, but not hot. The washer may be working extra if a belt is sticking or during the spinning process. If you have any other questions Joe, just let me know. Thanks for using FixYa.
Mar 31, 2011 | Kenmore Washing Machines
During spin cycle a grinding noise starts and a burning smell develops if I let it spin on then smoke comes out
could be your motor coupling, clutch or brake linings. if it smells like rubber burning then it is your motor coupling,, ,,,,mine was doing that and found out the clip that holds on the part to disengage the brake had ground off the end of my basket drive tube and the arm fell down thus no spin ,part cost more than the washer is worth! guess i'll be picking up a new 1! yea the grinding noise could be in your clutch,brake area!
Feb 10, 2010 | Kenmore Washing Machines
MOTOR SMELLS OF BURNT MOTOR WINDINGS. iS IT NORMAL
No, the pump works while spinning. The burnt smell is probably the belt, especially if your wife saw smoke. Did she put a big load in it at the time?
The belt will slip until the tub catches up with the motor. If there is a heavy load, it can burn the belt up. I would replace it. Make sure the idler pulley on the motor moves freely also.
http://www.partselect.com/MultiModels.aspx?ModelNum=ALW480DA&searchTerm=&RefineSearch=0
Jan 22, 2010 | Amana ALW480DA Top Load Washer
Um..... not quite sure....
Most likely the transmission on the motor has seized and will need to be repaired. Look under the washer, if there is black grease on the floor then its time to replace the motor and/or the transmission. If you have seen smoke then its probably the case.
Jun 20, 2007 | Whirlpool LSB6200KQ Top Load Washer
Washing Machines Logo
208 people viewed this question
Top Washing Machines Experts
