Question about Medion md40298 Notebook
Arial converter where can i get a converter to convert the arial socket on the tv card to a female tv connection.so that i can use a larger arial when i`m travelling
  • lasiu Apr 30, 2009
    I bought this card without aerial and I was just wandering if anyone know what is the name of the aerial socket so I can find something what I can use with the card.
Tip
System Restore for Windows 7
1. Open the Start Menu.
A) Click on All Programs, Accessories, System Tools, and System Restore.
2. Open the Control Panel (All Items View).
A) Click on the Recovery icon.
B) Click on the Open System Restore button.
A 'System Restore' window will appear. Here you will have to check "Restore computer to an earlier time'
A) Click on the Next button
Now you will find a window with Dates, Description and Type,
Note: It is better if you could remember from which date you are facing the issue, try to select a date prior to that date.
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start. Click on the Finish button and windows will take a reboot.
on Nov 02, 2011 | Microsoft Computers & Internet
HOW I CAN HAVE OUTPUT FRO AUDIO LINE ROM LG 55LH5000???
Hi, sorry but Most LG's no longer have audio outputs. The easiest way to get it ,You need to take the audio output from the source i.e. "cable box output"..if you have of course...
However whether your TV has this output or not we need to make some tests..5 different connections possibilities provided below.
(not by priority..you can start with any of it ).Below ,there is a sample TV back panel picture as well
Possible CONNECTIONS:
1) 2x RCA ports red / white is audio out ( L + R ) of TV to Stereo..
2) You can get also the audio digital output from the TV to a A/V receiver. the tv's optical audio out is stereo only mainly designed for freeview or tv audio to be output,
set the audio ouput on the TV menu to Dolby Digital, connect a digital optical out directly to the A/V receiver to receive audio signals.
3) since your TV has :2 x HDMI, SCART, AV, Component Video, VGA-sub, USB 2.0, connections,you may use the SCART plug to get Audio output for your TV .
TV's SCART connector which has 21 pins and "2x Audio Output " pins should be in it.
you need to buy an adapter called " RGB Scart Male to 3 RCA AV Female Adapter Converter" that can easily be found any electronic Market..one example as found eBay URL is below..
http://cgi.ebay.com/RGB-Scart-Male-3-RCA-AV-Female-Adapter-Converter-/130389078197
After you get this adapter,you need to carry the audio signal from SCART's RCA plugs to your Receiver with a 2x RCA (white/red ) cable.(if this does not work ,mfg should state somewhere in the manual..as your TV's "SCART socket IN only" ) if you properly connect IN/OUT plugs you will able to get the audio signal of the TV thru stereo..I recommend 2 $ value "RGB-Scart-Male-3-RCA-AV-Female-Adapter-Converter" with IN/OUT switch on it.
4) use HDMI connection of TV if you have HDMI input on your stereo of course...
5) if these are not an audio-out on one of these connectors , so you'll need to use the headphone socket if you want to plug it into a stereo. you need a cable 2x RCA to 3.5mm Headphone jack.
( This is the last ditch solution , since it mutes the whole sound.) ..
NOTE: if you connect this, pls be careful,your TV voice level will drive the stereo volume....
Hope this helps!..if more help requires Would you please let me know the result ?
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for us
to continue f
or Helping out the Community :)
Jul 09, 2011 | Televison & Video
Missing plug in cord. The A.C. cord got lost during a move. My speakers are silver in color with a larger round speaker in the center and a smaller one above and below the larger one. The power cord...
this is called a converter jack adapter
http://cgi.ebay.com.au/2-5mm-Female-3-5mm-Male-Audio-Converter-Jack-Adapter-/170592131101?pt=AU_Electronics_Portable_Audio_Accessories&hash=item27b815581d
http://cgi.ebay.com.au/3-5mm-Female-2-5mm-Male-Audio-Converter-Jack-Adapter-/130474893240?pt=AU_Electronics_Portable_Audio_Accessories&hash=item1e60e8dfb8
both are $1 with free postage worldwide
you could get this on Ebay if you dont have an account you will need to create one
Add Email adress
Add Bank Acc
Add Credit Card
also add your postal adress
also add a paypal account
when you get to the paypal login page at the bottom you will see new to paypal sign up tab
paypal to create an account
paypal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a postal adress
be very specific when you type in the search
always ask questions? before you make a purchase and keep the email/s for security reasons if the item arrives and its not as described
you will even see the pictures of your item so you cant make a mistake and get them home delivered
hope this helps
Apr 16, 2011 | Audio Players & Recorders
PH62080 mic has 1/4 jack. Can it be converted to XLR connection?
Yes it can, with a little help from amazon.com
http://www.amazon.co.uk/6m-Female-XLR-jack-cable/dp/B001GE4CV2/ref=sr_1_1?ie=UTF8&qid=1299774085&sr=8-1
They have a range of converters that will help you
Hope this is what you where looking for
Mar 10, 2011 | Philips PH62080 Uni-Directional Microphone...
My ezcap116 is not picking up video or audio from my xbox 360 when i go on arcsoft showbiz 3.5
what you need to do is make sure your connected with everything here is a website on how to set up your capture card easily. You will need 3 female splitters and 2 tri-colored rca sockets all male on both ends Red White and Yellow.
http://www.ezcap.tv/guide.html
Here is the URL if it doesn't help I'm sorry and you may have to get a different capcard or get a computer that supports windows 7 32/64 bit.
Dec 04, 2010 | Sony EzCAP116 USB 20 Video Capture Device...
I was given a GE 27GT616 television but can't figure out how to connect a converter box or dvd player
If your tv has video in socket (yellow color)and audio in socket(white color),you will connect the dvd player audio video output. it will give give clarity picture. your tv have not av socketyou can connect your dvd player audio video output to converter audio video input.And then connect to converter RFout to tv Rf input(antenna socket)and tune the tv you wlii get picture.
Jul 31, 2010 | GE 27GT616 27" TV
How do you connect the outside antennae to both the dvd player and digital converter box and the television
if its a dvd recorder first connect arial to recorder,then connect arial out to arial in on next device,and so on,it will say uhf in and out,on back the tv should be the last one connected,and you can also link them using scart leads and then use av on remote control, hope this helps andy
Jun 22, 2008 | Televison & Video
No signal
I had a similar problem. I then noticed that my antenna has a RG6 cable. This is good. My TV requires RG6 and requires TV(RF) cable that is also RG6. Insignia comes with a TV(RF) cable that is RG59! That's a cable with a smaller diameter center connector than RG6. Consequently, when that smaller RG59 was run from the converter box to the TV's larger RG6 female connector, no signal connection was completed since the center connector made no physical contact with the TV's female connector. I found a RG6 cable to replace the RG59 cable supplied with converter box and all worked then. Also, you must force the antenna's RG6 male plug into the smaller RG59 female connector, but it'll make it.
May 25, 2008 | Insignia Digital-to-Analog Converter for...
Medion md40298 Notebook Logo
132 people viewed this question
Top Medion Computers & Internet Experts
John Anderson
John Anderson
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
