Plugged into the Asus Computer USB Port to get lifetime updates, how do I eject the Garmin 2455LMT from my Asus computer?
SOURCE: Garmin Map update 2008
you will need to install the usb driver which should be located on the 2008 disk. When you attach the gps to your computer it should ask where the usb driver is located. If your dvd drive is (D) click browse and go the disk and find usb driver folder. I have purchased the new 2008 disk and had problems with it freezing on loader loading. I then browsed the disk and downloaded and then was able to get to the maps. I did not install it due to it asking what map I want to download. I wanted the whole thing so needless to say I am taking it back to walmart. I hope this helps.
SOURCE: Garmin Nuvi 260w not recognized by computer
Take a look at this site, http://www.garmin.be/missing.html
Download and unzip the software, plug your garmin in the USB and start
the updater.exe program. It gets you started again. Later on you can
use the Webupdater to get possible newer software..
It worked for me and my Zumo550
Goodluck
Auke
SOURCE: Garmin 200 won't turn on, flashes "Garmin" screen when plugged in
I connected the unit to the car charger instead of the USB charger and then held down the reset for 10-15 seconds, after which the system would show the computer connection on the charger and then boot up when not on the charger.
SOURCE: computer won't detect my nuvi 255T when I plug it
go to garmin and down load the web updater in downloads first .........then connect and go to programmes in pc and select garmin then run web updater , if no good try a different usb lead
SOURCE: I just bought a Garmin
Try these steps:-
Note: If your computer still does not detect the unit, make sure that you plug the USB cable directly into the computer USB port and not the USB hub. If the cable is already plugged directly into the computer, try plugging it into a different port.
Also, in some cases the operating system does not support the device. Try upgrading it to the next higher level. In most of the cases windows Xp service pack 2 does not recognise this Garmin device. Try upgrading it to service pack 3.
If you are still experiencing the problem then you will need to contact Garmin for repair.
Thanks for using Fixya.
Good Luck and have a nice day.
