Question about Microwave Ovens
Replace microwave lamp
Lamp burned out, can I replace that myself?
    President:
  • Microwave Ovens Master
  • 1,922 Answers
Yes,some are replaceable from inside the cooking chamber,but some you need to remove the outer cover and on these you may need a security torx screw driver to remove the screws holding the cover on
Posted on Jan 07, 2013
Hi, The bulb has blown on my Russell Hobbs microwave, and the manual say to call out a technician! I don't have a top cover to open so can't replace it myself, and my manual doesn't show how to replac
The "top cover" is the wraparound sheet metal enclosure. It has to be removed to replace the lamp. The attaching screws often are special and require a special tool for removal. Se sure power is disconnected before beginning removal! Once inside, there are high voltage points to avoid while replacing the lamp. Reverse the procedure to reassemble the enclosure.
Sep 18, 2014 | Microwave Ovens
Replace lamp
Most lamps are replaced from a door on the side of the oven if not then there must be a way from inside
Nov 29, 2013 | Magic Chef MCM1110B
How to replace burned out light bulb
You need to remove the top cover to access the bulb. That is the only way on most microwaves.
Dec 02, 2011 | Emerson MW8107WA Microwave Oven
DEBBILS@COMCAST.NETwhere is my light bulb it burned out. I have a ge compact microwave oven. Model number is JES 1139WLO3
Replacement of the lamp should be carried out by a qualified appliance repair service.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
But here is a basic method if you are mechanically minded and have electrical safety knowledge.
The lamp is sat in a housing and its position is adjacent to the vent holes that it shines through.
If you feel confident, disconnect it from the mains power, remove anything in the cavity.
Remove the microwave cover. Purchasing a new replacement lamp will be useful as it will give you an idea of what it looks like. Locate the dead lamp remove the lamp and fit the new one. Replace the covers. Plug it back in and try the lamp by opening the door.
Hope this helps.
Mar 25, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Light bulb burned out- can I replace myself?
Yes you can. The cover has to come off the microwave to access the bulb. There are several screws around the back and sides. Remove these and the cover should lift off, revealing the bulb. For your own safety, make sure that the microwave has been unplugged from the outlet for several hours before attempting this repair.
Mar 12, 2011 | Daewoo KOR-1B4H Microwave Oven
When I was unscrewing a burnt out hood lamp on
I would not use the lamps. Sounds like there is a shortage in the wiring for the lamps. They lamps should run together, and if one of the sockets have a short or burned wire it will not let it complete the circuit. This could be a fire hazard, so I would replace the whole microwave. It would be more trouble to tear it apart and find the exact problem than it's worth.
Jan 04, 2010 | Maytag MMV4205 Microwave Oven
One surface light bulb on GE Profile microwave keeps burning out
I have the same problem. The left one burns out within a couple of hours use, the other one lasts a couple of months and is then gone. This pattern has repeated over 8 years. I replace them every now and then and then just go without until I get the urge again to fix it. Maybe smaller lower wattage lamps are worth trying...
Jun 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Kitchenaid model:KHMS105B microwave hood combination
hi alan,
it sounds like the transformer is bad, which makes this easy, time for a new one. 12yrs is a good age for a microwave, average life is about 8-10 yrs!
Mar 21, 2008 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Microwave Ovens Logo
27 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
