Question about Proform XT 70 Treadmill
Have proform xt 70. It makes a loud noise when turned on, less noise when walking.
Very loud noise when first turned on, seems to be coming from the front. When walked on noise lessens, but still quite loud. I have no clue what to do...help!
    Top Expert:
  • Proform Master
  • 12,223 Answers
See the video and do it inmediately+ roller bearing Too. God bless you
Posted on Jan 08, 2013
Testimonial: "Thank you ! "
4 Suggested Answers
  • 103 Answers
SOURCE: Proform 400GI Treadmill making a very loud noise,
This definitely sounds like the drive motor. One way to check is to remove the drive belt and run the motor without the walk belt connected. Obviously if you still have the noise it will be a motor issue. If not then it will be one of the 2 rollers. Good Luck! Tim
Posted on Nov 13, 2009
maxtreadmill
  • 832 Answers
SOURCE: Proform 545S needs replacement walking belt
Here is the replacement part page for iconfitness.com
www.iconservice.com/CustomerService/partsModelSearch.do
Posted on Apr 16, 2010
maxtreadmill
  • 832 Answers
SOURCE: my treadmill Proform caliber walk... belts keeps
The deck needs to be lubricated. The lubricant can be purchase @ gympart.com. LUBRICATION PROCEDURE: 1. Turn off and unplug treadmill. 2. Cut off the end of the tube of lubricant. 3. Holding the tube in one hand, insert the tube underneath the treadbelt halfway between front and back and halfway between right and left. 4. Squeeze the full contents of the tube onto the deck in a circular pattern in the center 1/3 of the deck. 5. Plug in2_bing.gif and turn on treadmill, then walk normally on treadmill at 0.5 mph for five minutes
Posted on May 16, 2010
Tap tap tap noise when the belt turns on. consistent.
can you determine where the noise is coming from . under the front hood or back. if you can remove the hood and look at the drive belt for fraying . also look at walking belt for fraying. any loose piece will hit something and make noise with every revolution
Apr 16, 2014 | Proform 400 CT Treadmill - Treadmills
Proform xp 70 stationary bike console is not getting power
IF BATTERIES ARE NEW THEN CHECK THE CABLE AND CONNECTION FROM BATTERIES TO THE CONSOLE.MAKE SURE ALL CONNECTION ARE TIGHT AND CABLES ARE NOT BROKEN,FRAYED,CRACKED,OR CORRODED LOOKING.ALSO MAKE SURE SAFETY DEVICES(KEYS,PINS,CLIPS) ARE IN PLACE .
Oct 13, 2012 | ProForm 70 Perspective Treadmill
I have a Pro-Form XT 70 When I turn it on, it sounds like an airplane is about to take off. And When the seam from the track goes around it makes a ticking noise...
Dear Sir:
Hello, I give thank you by your questions. I will try to help you.
You will need some basics tools; screwdriver, hexagonals, Dvom(Digital Voltmeter)
Here the videos:
http://www.youtube.com/watch?v=qgb2TY3WCkg&feature=related
http://www.youtube.com/watch?NR=1&v=KiEZDNe0F8Q
http://www.youtube.com/watch?v=9o4cI10G_GA&feature=related
http://www.youtube.com/watch?v=AZSMLpXm-tA&feature=related
http://www.youtube.com/watch?v=wjrVjYe2LYQ&feature=related
With this you will fix it.
If you need further assistance, please reach me, sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Oct 19, 2011 | Proform XT 70 Treadmill
Too noisy problem which is annoying during exercise.
The make and model of the treadmill would help. Your treadmill has 100's of moving parts so the noise can be coming from anywhere. Suggest starting the treadmill with no one on it. Does it still make the noise? If so from where? No noise? Then has someone walk on the treadmill and try and isolate the noise. You may need to remove the motor hood.
Jul 28, 2010 | Proform 540ls Treadmill Walking Belt
Making more noise when it is running. Did not make so much noise before.
If the noise is coming from the walking belt this could be due to sand or grit getting under it. These belts are big electro-magnetic generators. The attract sand and grit to them. Usually it will make a high pitched sound when there is sand under the belt, especially if there is a mylar or plastic sheet under it. If this is the case the sheet can easily be replaced.
Jun 15, 2010 | Proform 370E Treadmill Walking Belt
It started making a loud noise and when I turn it on and step on it it doesn't even run...what can I do?
Hi, did you fix you treadmill's loud noise?
I have a 530X Proform and I'm having the same problem with my.
May 21, 2010 | Exercise & Fitness
The belt seems to slide to one side on my Proform Crosswalk 380. How do I fix it?
PROBLEM: The walking belt is off-center or slips when walked on SOLUTION: a. If the walking belt has shifted to the left, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn the left idler roller bolt clockwise 1/2 of a turn. Be careful not to overtighten the walking belt. If the walking belt has shifted to the right, turn the left idler roller bolt counterclockwise 1/2 of a turn. Then, plug in the power cord, insert the key, and run the treadmill for a few minutes. Repeat until the walking belt is centered.
Feb 27, 2010 | Proform 380 CS Treadmill !
Proform 400GI Treadmill making a very loud noise, which is worse when using speeds between 2.7 and 3.1, noise is so loud can't hear tv when turned up to full volume. It makes the noise without anyone...
Nov 04, 2009 | Proform 490GS Treadmill Walking Belt
Treadmill speed control does not work - only max.
visit www.iconfitness.com and enter your full model number to print out a speed calibration procedure. Sounds like it needs it. We are a service dealer for them.
Aug 10, 2009 | Proform Crosswalk 3.0 XT Treadmill
Noise when walking
What kind of noise--where from?
Jul 07, 2009 | Proform Sport 1000 Folding Treadmill...
Proform XT 70 Treadmill Logo
484 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
