Question about Hand Tools
Need manual for multi-clamp workstation 057-1627-0
  • june williams Jan 08, 2013
    This is a mastercraft
How to remove the code p1589 with fcar scanner
MULTI-MODE MANUAL TRANSAXLE SYSTEM ADJUSTMENT
1. USING INTELLIGENT TESTER: CLAMP POSITIONADJUSTMENT (CLUTCH POSITIONADJUSTMENT)
Tech Tips
The multi-mode manual transmission system has a load controlled clutch cover (adjustment system). The pressure plate moves depending on the wear
condition of the clutch disc lining.
When removing or installing any parts related to the multi-mode manual transmission system, move the clutch actuator to the clutch clamp position. This is
for normal operation of the load controlled clutch cover (adjustment system).
If the clutch position adjustment operation input fails, perform the operation again from step (a) more than 15 seconds after turning the ignition switch off.
Note
Do not depress the brake pedal while performing the clamp position adjustment using an intelligent tester.
a. Prepare the vehicle:
Stop the vehicle.
Shift the lever into the N position.
Turn the ignition switch off.
Apply the parking brake.
b. Connect the intelligent tester to the DLC3.c. Turn the ignition switch on (IG).
d. Turn the intelligent tester ON.
e. Select the following menu items: Powertrain / Multi-Mode M/T / Utility / Parts Exchange.
f. Read the information.
g. Press the Next key.
h. Read the information.i. After checking the vehicle condition, press the Next key.
j. Read the information.
k. Press the Next key.
l. Read the information.m. Press the Next key.
n. On the Multi-Mode M/T / Utility screen, select Step 1 Clutch Position Adjustment (Clamp Position Adjustment).
o. Press the Next key.
p. Read the information.q. Press the Next key.
r. Complete Clutch Position Adjustment.
s. Turn the intelligent tester OFF.
t. Turn the ignition switch off.
u. Replace the malfunctioning parts.
Tech Tips
Perform [Initialization and Learning] after repairing the multi-mode manual transmission control system .
2. WITHOUT USING INTELLIGENT TESTER: CLAMP POSITIONADJUSTMENT (CLUTCH POSITIONADJUSTMENT)
Tech Tips
If the clutch position adjustment operation input fails, perform the operation again from step (a) more than 15 seconds after turning the ignition switch off.a. Prepare the vehicle.
Stop the vehicle.
b. Using SST, connect terminals TC and CG of the DLC3
SST
09843-18040
c. Turn the ignition switch on (IG) with the brake pedal released.
d. Depress the brake pedal 7 times or more within 3 seconds.i. The buzzer sounds twice with an interval of 0.25 seconds.
e. Depress the brake pedal.
f. Shift the shift lever in the following sequence with the brake pedal depressed: N?E?M?+?M?+?M?+?M?+?M?E?N.
g. Release the brake pedal.
h. Depress the brake pedal again.i. The buzzer sounds at intervals of 0.5 seconds as follows (an interval of 2.5 seconds exists between each cycle).
Once when adjusting the clutch clamp position (one cycle)
Tech Tips
If the buzzer does not sound at this time, wait at least 15 seconds after turning the ignition switch off. Then, perform the procedure from step
(a) again.
i. Depress the brake pedal 3 times or more within 2 seconds.
j. Depress the brake pedal.
k. Shift the shift lever to the [-] position with the brake pedal depressed.
l. Release the brake pedal.
m. Complete clutch position adjustment.
n. Turn the ignition switch off and wait at least 10 seconds.
o. Disconnect the SST from terminals TC and CG of the DLC3.
p. Repair the malfunctioning parts.Tech Tips
May 22, 2015 | 2009 Toyota Yaris
Why does our Lenovo D30 workstation fail to run for more than 1.5 days when parallel processing multi realization runs ( the machine automatically reboots killing the runs)?
You are better off contacting Lenovo Commercial support; these are proprietary units for specialized usage and Dell would be best qualified. There are also licensing limitations built in to some units that may influence ongoing time periods.
Jul 21, 2014 | Lenovo Computers & Internet
Where and how to wire motherboard intel 775
You should be able to get the pin outs and connector specifications from the HP website for that workstation model. Go to the service manual and it will have detailed information on what you need.
May 20, 2014 | HP Workstation Xw4100 PC Desktop
I think i got a mallware issue ive got a dell workstation 470 and it wont do anythink when i turn it on it just goes to a black screen i have tried safe mode but it just comes up...
That sounds right to me.
Unfortunately you will have to purchase a copy of Norton AntiVirus or equivalent as you can't log on and download a free one.
It sounds like a Malware problem.
Jan 19, 2011 | Dell Precision Workstation 470 (204816690)...
I want to buy a Tescam 2488neo. But i got a question before I buy it. Question- Can I record songs or musics multi-times? I mean, record acoustic Guitar first, and then record ...
Here is a link for you to look at:http://www.tascam.com/products/2488mkii.html Look under resources to download the manual or a Beginners Guide to Recording.
Aug 28, 2010 | Tascam 2488mkii 24 Track Recording...
How do Identify a pci multi port erial controller
Assuming one is installed on your machine, look for a card with several nine-pin serial connectors with pins.
Sep 12, 2009 | HP D330 PC Desktop
Aficio 2035
Can't give you the service manual due to legal reasons but you can check on copytech.com and see if you can get one one there. The service doesn't really tell you how to do it either so I can tell you how to do it:
1) Press user tools/counter.
2) Press file transfer.
3) Enter the workgroup name under domain.
4) Exit out to go to Key OP tools.
5) Look for address book management.
6) Select new program.
7) Give it name (name of person or computer)
8) Select File.
9) Select Browse
If it worked you should see computers displayed on the screen. If you don't see any, follow the troubleshooting suggestions below:
For you workstations:
1) Make sure you have a shared folder on each computer that allows for access to all users (or everyone).
2) Each computer needs to be accessed by a user id and password. You will need to type them into the copier.
3) No computer should have any firewalls turned on. Firewall control must be done on the router. Windows Firewall software needs to be disabled from each workstation. You may need to get into administration settings of each workstation to disable it permanently.
4) Certain versions of Norton sottware can block communication regardless or weather or not the firewall is on or not. If that's the case it will have to be disabled to get to work.
5) File and printer sharing should be turned on each workstation.
I do these for customers on a regular basis. I had to find a lot of this out on my own. Hopefully this will help you out.
Oct 19, 2008 | Ricoh Office Equipment & Supplies
Insrtuction manual
I have a manual if you need a copy.
Oct 11, 2007 | Roland Vs-2000CD Digital Studio...
Hand Tools Logo
95 people viewed this question
Top Hand Tools Experts
Don Numinen
Don Numinen
Ivan
Ivan
Level 1 Expert
Bill Boyd
Are you a Hand Tool Expert? Answer questions, earn points and help others
