Question about HP iPAQ HX2795 Pocket PC
HP ipaq hx2795 lose sound
I have HP ipaq hx2795 and tomtom navigator 7.450, after tomtom intalation hp lose sound, any suggestions?
  • 60 Answers
Hi there.
Browse to your Windows directory and look for BtCoreIf.dll and BtSdkCE30.dll. Rename them both (for example: "BtCoreIf.old" "BtSdkCE30.old")
then do a soft reset, it should work.
Bye
Posted on Mar 30, 2009
IPAQ HX2795 SYNC ISSUE
Is the time zone correct?
Mar 27, 2009 | HP iPAQ HX2795 Pocket PC
HP iPaq 3715
is this windows compliant and if it is in the control panel check to make sure that your sound that you use is default set some times this can lead to a no sound usuage
May 28, 2008 | HP iPAQ RX3715 Pocket PC
HW6515d Ipaq Sound with TomTom Sat NAv
The ipaq 6515 has a microswitch that will turn off the pda if the battery cover is removed. When you remove the cover and try to turn it on even with the external power supply plugged in, the red led will light up.
Jan 29, 2008 | HP iPAQ hw6515 Pocket PC
NO SOUND AFTER TOMTOM 6
I had the same issues as mentioned installing TomTom Navigator version 7 onto a HP IPAQ 2415 running Windows Mobile 5. As soon as TomTom was installed the sound stopped working.
I did a Hard Reset to restore the IPAQ which got the sound back. I then downloaded the trial version of WinCE Cab Manager http://www.ocpsoftware.com/products.php?nm=cecabmgr and used this to remove the files Btcoreif.dll and Btsdkce30.dll from the TomTom installation CAB. I saved the cab and then ran this again and it installed perfectly and I still had sound. Hope this offers a solution for anyone still having a problem.
Jan 13, 2008 | HP iPAQ HX2490 Pocket PC
GPS on hp6515
Firstly the GPS on this model is not a standard GPS, it uses AGPS which requires an update to be performed either ever 2 or 10 days, depending on the rom version of the ipaq.
This annoying thing normaly occurs when the update is out of date. On the home screen, in the bottom right hand corner, you will see a circular icon with grid lines and a dot in it. If it is blue the update is good, grey means it is out of date.
There are several ways to update this, the easiest being having your iPaq connected to active sync, then tapping the above icon, tapping download now.
However, if you have recently performed a soft reset, you will need to perform a hard reset to resolve the issue (this will wipe all your data so back up first!!!) Then re-install tomtom and try again.
Oct 11, 2007 | HP iPAQ hw6510 Mobile Messenger Smartphone
Ipaq 6515 gps issues
Hello, You may need to go get the update to 5.21 .. heres the link .. http://www.tomtom.com/support/category.php?ID=3&Language=4&FID=3370 Install it and that will help Bob
Jun 10, 2007 | HP iPAQ hw6515 Pocket PC
IPAQ 2795 freezes during boot up.
I had the same problem. Contacted HP customer service chat, and got the following answer that
solved the problem:
1. Remove the battery for 30 minutes.
2. Insert it again in the iPAQ.
3. Perform a clean reset on the iPAQ and at the same time charge the iPAQ.
To perform a clean reset please follow these steps:
Press and hold the Calendar button, the Power button, and the Messaging button.
While holding these buttons, use the stylus to lightly press the Reset button on the bottom of the HP iPAQ.
The problem can also be solved by getting a new battery, and performing the clean reset while charging (using the portable charger, not the cradle).
Nov 16, 2006 | HP iPAQ HX2795 Pocket PC
Using TomTom nevigator
For use with TTN you'll need the following: -A GPS mouse (either wired or wireless if you have bluetooth on your ipaq) -TomTom software -Memory card (usually Secure Digital of Compact Flash) to store the differents maps on it. It's also recommended to have a card reader on your pc to transfer the maps on the expansion card. Good luck and let me know if it works out or not
Sep 19, 2005 | HP (FA162A#AC3) for HP iPAQ 2200/4100...
Cannot copy large files to my SD card
Yes , the Activesync connection is not reliable for large files. You really would be best to get a USB card reader, also it would be MUCH, MUCH faster.
Sep 11, 2005 | HP iPAQ RX3715 Pocket PC
HP iPAQ HX2795 Pocket PC Logo
115 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
