Question about DeLonghi Dragon 3 1025 / 1025T Oil Filled Radiator Heater
Oil filled radiator trips the fuse board - DeLonghi Dragon 3 1025 / 1025T Oil Filled Radiator Heater
94 Fleetwood lt1 brown crud in coolant reservoir
Looks like mud ? What type coolant have you added ? Take the radiator cap off an look into it , do you see the same ? Have you ever had the cooling system flushed ? There was a problem with people adding green coolant to GM - Dex-cool ,orange ! Clog's the passages in radiator ,inside the engine , heater cores etc... Pull the oil fill cap on the valve cover an look at the under side of the cap , do you see brown frothy looking goop ? Coolant getting into the oil ! Why it called DexKILL
Sep 19, 2016 | 1994 Cadillac Fleetwood
My heater warms up then it trips out my electrics
Either you have to much on the circuit, like lamps, TV, and running,
or there is a problem with the heater and you should return it.
Try a bedroom outlet, make sure noting is on in all the bedrooms, or the kitchen if you have outlets above the counter, outlets above a kitchen counter are suppose to be on their own circuit.
If you try this and it trips the breaker, return the heater.
Apr 10, 2013 | DeLonghi TRN1015T Solaris Oil-Filled...
My black and decker oil radiator has gone dead all of a sudden
Have you check the electric receptacle it's plugged into, to see if it's still functioning. Do this either with test leads or by plugging in another electric appliance. If it's not working check your homes circuit breaker panel for a tripped breaker. If you find that's the case, make sure nothing is plugged into the receptacle and reset the tripped breaker. Plug your heater back into that receptacle and see if it trips the breaker. If it does, something in your heater is either overheating or there is an electrical short. In either case, buy a new heater.
Feb 15, 2011 | Black & Decker BDOH100 Oil Filled Radiator...
My oil filled radiator trips the mains after a few
Try changing circuits (plug into one not protected by the same breaker.)
While the heater element can fail in your heater, I have had to replace several breakers after only a few years use after they became overly sensitive.
May 24, 2010 | DCS Heating & Cooling
Delonghi Dragon Two, oil filled rad trips the main elec fuse
If it is tripping the breaker in the panel, there is a direct short in the heater. Scrap it before it causes a fire. Seriusly
Oct 24, 2009 | DeLonghi 6707E Oil Filled Radiator Heater
Doesn't do anything
Look under control pannel for a fuse! I am not sure about your model but most of these heater types have a fuse
good luck!
Dec 12, 2008 | Pelonis WM-HO202C Oil Filled Radiator...
DeLonghi Dragon 3 1025 / 1025T Oil Filled Radiator Heater Logo
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
